Hi Everyone. Newbie Python/C# dev here making my first ever windows escape attempt, and first I'd just like to say thank you to the Garuda team for creating such an awesome out-of-the-box thing here! Very impressed so far!
I am having an issue with my setting from the "colors" control panel reverting back to the original magenta upon restart. I'll change it to the blue, but after restart it's back to the magenta for the highlight/selection color.
All other customization settings seem to be retained fine from what I can see, it's just that color setting that is reverting.
Few other minor issues but I'm still trying to solve them on my own before starting threads.
Thanks!
> Blockquote
Kernel: 5.16.5-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=d5af581e-eff8-4b35-b8db-4838c1055d5d rw rootflags=subvol=@
cryptdevice=UUID=46b8c56b-d7cf-4e46-a6d9-d6ac2ee0a757:luks-46b8c56b-d7cf-4e46-a6d9-d6ac2ee0a757
root=/dev/mapper/luks-46b8c56b-d7cf-4e46-a6d9-d6ac2ee0a757 quiet splash
Type: Laptop System: Razer product: Blade v: 2.04
Mobo: Razer model: Razer CH20 serial: <superuser required> UEFI: Razer
v: 1.05 date: 05/16/2019
ID-1: BAT0 charge: 82.1 Wh (99.9%) condition: 82.2/80.2 Wh (102.5%)
volts: 17.3 min: 15.4 model: Razer Blade type: Unknown serial: <filter>
status: Full
Info: model: Intel Core i7-8750H bits: 64 type: MT MCP arch: Coffee Lake
family: 6 model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xEA
L3: 9 MiB desc: 1x9 MiB
Speed (MHz): avg: 4048 high: 4101 min/max: 800/4100 scaling:
driver: intel_pstate governor: performance cores: 1: 3907 2: 4059 3: 4052
4: 4097 5: 4071 6: 3977 7: 4050 8: 4100 9: 4036 10: 4038 11: 4099
12: 4101 bogomips: 52799
Type: l1tf
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: Razer USA
driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:3e9b class-ID: 0300
Device-2: NVIDIA TU104M [GeForce RTX 2080 Mobile] vendor: Razer USA
driver: nvidia v: 510.47.03 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
chip-ID: 10de:1e90 class-ID: 0300
Device-3: Microdia NexiGo HD Webcam type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 1-2.1.4:13 chip-ID: 0c45:2690
Device-4: IMC Networks Integrated Camera type: USB driver: uvcvideo
bus-ID: 1-7:7 chip-ID: 13d3:56d5 class-ID: 0e02 serial: <filter>
loaded: modesetting,nvidia display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1015x285mm (40.0x11.2")
s-diag: 1054mm (41.5")
Monitor-1: HDMI-0 res: 1920x1080 hz: 120 dpi: 30
size: 1600x900mm (63.0x35.4") diag: 1836mm (72.3")
Monitor-2: DP-1 res: 1920x1080 hz: 120 dpi: 30
OpenGL: renderer: NVIDIA GeForce RTX 2080 with Max-Q Design/PCIe/SSE2
v: 4.6.0 NVIDIA 510.47.03 direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: Razer USA
Device-2: NVIDIA TU104 HD Audio vendor: Razer USA driver: snd_hda_intel
v: kernel bus-ID: 01:00.1 chip-ID: 10de:10f8 class-ID: 0403
Device-3: XMOS JDS Labs UAC2 DAC (XU208) type: USB driver: snd-usb-audio
bus-ID: 1-2.1.1:10 chip-ID: 20b1:30da class-ID: fe01
Device-4: Microdia NexiGo HD Webcam type: USB
Sound Server-1: ALSA v: k5.16.5-zen1-1-zen running: yes
IF-ID-1: tun0 state: unknown speed: 10 Mbps duplex: full mac: N/A
driver: btusb v: 0.8 bus-ID: 1-14:14 chip-ID: 8087:0aaa class-ID: e001
Local Storage: total: 11.38 TiB used: 162.57 GiB (1.4%)
model: MZVLB512HAJQ-00000 size: 476.94 GiB block-size: physical: 512 B
rev: EXA7301Q temp: 51.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 type: USB vendor: Western Digital
model: WD20NMVW-11EDZS3 size: 1.82 TiB block-size: physical: 512 B
logical: 512 B type: HDD rpm: 5200 serial: <filter> rev: 1072 scheme: MBR
ID-3: /dev/sdb maj-min: 8:16 type: USB vendor: Western Digital
model: WD Game Drive size: 4.55 TiB block-size: physical: 4096 B
logical: 512 B type: N/A serial: <filter> rev: 5002 scheme: GPT
ID-4: /dev/sdc maj-min: 8:32 type: USB vendor: Western Digital
used: 162.57 GiB (34.1%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
mapped: luks-46b8c56b-d7cf-4e46-a6d9-d6ac2ee0a757
ID-1: swap-1 type: zram size: 15.52 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 65.0 C pch: 70.0 C mobo: N/A gpu: nvidia
temp: 60 C
Processes: 356 Uptime: 5m wakeups: 1 Memory: 15.52 GiB
used: 3.08 GiB (19.8%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1916 lib: 562 Shell: fish
Garuda (2.5.4-2):
System install date: 2022-02-01
Last full system update: 2022-02-03
