Chaotic-AUR | Packages | Requests | Recompilation | Reports
I did.
Obviously you are compiling with cuda, because this is an nvidia-cuda error message. The cause should be on your side and not the AUR. Check if your cuda paths are correct.
New emulator for Nintendo Switch
https://git.citron-emu.org/Citron/Citron
Hello lovely eagle maintainers;
In the chaotic-aur. Wings 3D is marked as 2.4.1, but installs wings-2.3.x.y.WINGS
Edit: All fixed! Thank you, wondrous chaos-infused maintainers of treasure!
This should be fixed finally! Maintainer now has everything in a virtual environment, as it should have been before: AUR (en) - searxng-git
I’ve opened 2 issues regarding these requests. Keep an eye out here:
For future reference, these depended on the AUR maintainer to update, and those packages were all updated 8 days late.
There hasn’t been any progress on this code in quite a while (2 years). It doesn’t seem like the Linux support is actually WIP, as much as it’s paused. There’s not even Linux build instructions, so I won’t consider packaging until someone else does a lot more work: AirPodsDesktop/Docs/Build.md at main · SpriteOvO/AirPodsDesktop · GitHub
This has been done in Garuda Gamer, and is now provided by Chaotic-AUR. Thanks for pointing it out.
I looked into this, and it doesn’t seem to be actively updated as much as something this critical should be (2 versions out of date as of this moment), so it won’t make it available in repos. Hopefully you shouldn’t have to rely on it in the very near future, maybe you don’t already.
If that’s the case, then you probably didn’t need the package in the first place, but go ahead.
For anyone else seeing this error, that may not have seen the reply or understood the reason. You need base-devel installed to start building things from the AUR: Arch User Repository - ArchWiki
garuda-update -- base-devel
We also got annoyed, ungoogled-chromium-bin is now available, it’s unlikely but not impossible we move back from -bin someday:
I still haven’t figured out how to properly turn on that systemd service (uswgi@searxng). I tried using the step in JanH’s comment in AUR:
For reference, I did cp /etc/uwsgi/vassals/searxng.ini /etc/uwsgi/, changed the port number in that file to :8080, and then could start it successfully with your command.
But the port is not responsive.
Anyone got it working?
Hi, requesting chiaki-ng to be added to chaotic aur please. Seems like a fresher version of chiaki.
https://aur.archlinux.org/packages/chiaki-ng
Looks excellent, I think this will even make it into the next release of Garuda Gamer!
If anyone wants to use Autodesk Fusion 360 in the future, there is now a successfully merged a PR for CachyOS support, and it seems easy enough to add support for Garuda for someone motivated.
I’m not personally going to put time in to make this particular proprietary software that I don’t use work, but seems like the right place to let some others know. It would be a good first-time contribution if you’re looking for somewhere to practice and wish to install this software.
Big thanks to @ptr1337 for making it easier for everyone! :partying_face:
Hello team,
Not sure if this can be considered but, I would like to request this package to be included “freetype2-qdoled”
https://aur.archlinux.org/packages/freetype2-qdoled
Basically what it does, it modifies the default “none” subpixel geometry of freetype2 specifically made for QDOLED monitors. Which gets rid of text fringing, caused by the nonstandard QDOLED pixel layout.
I tested it and it really does a difference.
To see better the difference here are some Zoomed examples.
Non-Patched Freetype2 best outcome RGB layout 800x zoom
Patched Freetype2 best outcome NONE (default) layout 800x zoom
This as well makes smaller text much more clearer, visible and readable when using white on dark background, and the HALO effect effectively reduced/gone.
I know I am maybe one of 5 people here using a QDOLED :smiley: , but maybe its worth a consideration.
Considering (as you said) there are not very many people at all with this display, and an even lesser amount that would be using Chaotic-AUR, I think it’s not the best to add at this point. Makes it even harder if maintainers can’t easily test breakage. Luckily it seems to update very infrequently, and a test build completed before I could notice, so it shouldn’t be much effort to install.
Many thanks for the answer and Indeed as you said.
I installed it currently using paru (tried as well the manual way makepkg both worked)
One note tho maybe for future if somebody has QDOLED and deals with text fringing and HALO effects on text. Even if this package is targeted primarily for 34", the subpixel layout created should match as well other screen-sizes of QDOLED. Because most if not all QDOLED panels are coming with the same physical pixel layout (and I read as well same manufacturer currently)
So, if there will be by chance someone dealing with this ,maybe at least this post will come handy :slight_smile:
