It seems as if you may be running into a similar error from within your Virtual Machine. From my understanding, the issue is happening from either an invalid or corrupted package or from conflicting files.
I noticed the searxng-git package installs fine from chaotic, but running searxng-run doesnāt work without extra/python-typer and aur/python-msgspec.
Could those be added as dependencies in the pkgbuild, and the latter to chaotic? That would be wonderful.
The aur package was updated to 133.0-1 on 2024-11-29 21:26 (UTC)
yay -Ss librewolf
chaotic-aur/librewolf 132.0-1 (86.1 MiB 236.6 MiB)
Community-maintained fork of Firefox, focused on privacy, security and freedom.
aur/librewolf 133.0-1 (+144 6.03)
Is there a specific reason why this package is not automatically compiled at times? Iām asking that because on 2024-08-07 exactly the same happened (see above).
Am Iām supposed to open a github issue instead?
For future reference, you can have a look this page to see whatās going on:
Simply search for the package name to see when a build happened and its outcome. Packages should be updated and started building every hour full hour in most cases.
Hello, I need a package on Chaotic if possible
amd-zen-ucode-platomav
In contains right ucode for my cpu, without it i have a system freez every hour or so because the amd-ucode on the bios or on the kernel is older and not well compatible with linux
when I try to install amd-zen.ucode-platomav wit paru I have this error
āCannot find the strip binary required for object file strippingā
so I canāt install it using AUR
It will be good if it is on Chaotic, installong it can save my laptop form force restar every hour
Previously i was able to laod a good amd-ucode on /root but since november it seems kernel doesnāt load microcode that are not on the kernel so I have all those freez every hour of use.
Thanks
Here is my feedback request⦠Ungoogled Chromiumā¦please get that back on Chaotic-Aur. Iām getting sick of compining this over and over each month for a week strate >.<
