Chaotic-AUR | Packages | Requests | Recompilation | Reports
ffmpeg-full still needs a rebuild. It fails from Chaotic but works if I compile manually.
Bumped it, will be available in ~45min when the next routine runs:
I would like to recommend ā€œSpeech Noteā€ for chaotic-aur. Current dsnote and dsnote-git are both long compiles with many requirements. The app does text to speech and speech to text as well as translations. All features are available OFFLINE. A quick video on it I found is https://www.youtube.com/watch?v=dYIPyS3F_eU
I’m currently compiling it and it’s reminding me of kernel compiles in ā€œthe good ole days.ā€
As soon as it’s QT6!
Could crystal-dock be added to chaotic-aur? Currently the AUR one is crystal-dock-git but this builds an alpha version. Would like the current release version it github instead:
Not until someone creates it, only -git version exists as of now: AUR (en) - Packages
librewolf needs an update to the latest version (v131.0.2) to address the latest crit level exploit :slight_smile:
Thanks for heads up, we were already on it. But sadly the build failed for yet unknown reasons. See:
sudo pacman -U ā€˜https://cdn-mirror.chaotic.cx/chaotic-aur/chaotic-keyring.pkg.tar.zst’
The requested URL returned error: 404
What’s the problem?
By updating Chaotic-AUR
chaotic-aur/chaotic-mirrorlist 20240306-1 → 20240724-1
error installing repo packages
This issue should be fixed now, give it a test please.
Hi guys!
I’m trying to update the system via gaqruda-update, however I’m getting some errors while doing so:
error: failed retrieving file 'chaotic-mirrorlist-20240724-1-any.pkg.tar.zst' from cdn-mirror.chaotic.cx : Exceeded the maximum allowed file size (3420) with 3420 bytes
And the update is cancelled alltogether.
While trying to re-add Chaotic using the guide on Chaotic-AUR I get the
error: failed retrieving file 'chaotic-mirrorlist.pkg.tar.zst' from cdn-mirror.chaotic.cx : The requested URL returned error: 404
The file is present in here: https://builds.garudalinux.org/repos/chaotic-aur/ , however it returns the 404 while I’m clicking on it. I’ve tried with VPN off / on (Canada, Belgium, Bulgaria) - nothing helps.
I didn’t perform any modifications to the system. Could you please advise? Thanks!
Welcome!
Should be fixed by this. Might want to try another garuda-update to refresh.
If that does not work, there is another way to refresh deeper.
:: Retrieving packages...
chaotic-mirrorlist-20240724-1-any.pkg.tar.zst failed to download
error: failed retrieving file 'chaotic-mirrorlist-20240724-1-any.pkg.tar.zst' from cdn-mirror.chaotic.cx : Exceeded the maximum allowed file size (3408) with 3
408 bytes
error: failed retrieving file 'chaotic-mirrorlist-20240724-1-any.pkg.tar.zst' from geo-mirror.chaotic.cx : The requested URL returned error: 416
error: failed retrieving file 'chaotic-mirrorlist-20240724-1-any.pkg.tar.zst' from br-mirror.chaotic.cx : The requested URL returned error: 416
error: failed retrieving file 'chaotic-mirrorlist-20240724-1-any.pkg.tar.zst' from bg-mirror.chaotic.cx : The requested URL returned error: 416
error: failed retrieving file 'chaotic-mirrorlist-20240724-1-any.pkg.tar.zst' from ca-mirror.chaotic.cx : The requested URL returned error: 416
error: failed retrieving file 'chaotic-mirrorlist-20240724-1-any.pkg.tar.zst' from cl-mirror.chaotic.cx : The requested URL returned error: 416
error: failed retrieving file 'chaotic-mirrorlist-20240724-1-any.pkg.tar.zst' from de-2-mirror.chaotic.cx : The requested URL returned error: 416
error: failed retrieving file 'chaotic-mirrorlist-20240724-1-any.pkg.tar.zst' from de-3-mirror.chaotic.cx : The requested URL returned error: 416
error: failed retrieving file 'chaotic-mirrorlist-20240724-1-any.pkg.tar.zst' from de-4-mirror.chaotic.cx : The requested URL returned error: 416
error: failed retrieving file 'chaotic-mirrorlist-20240724-1-any.pkg.tar.zst' from fr-mirror.chaotic.cx : The requested URL returned error: 416
error: failed retrieving file 'chaotic-mirrorlist-20240724-1-any.pkg.tar.zst' from gr-mirror.chaotic.cx : The requested URL returned error: 416
error: failed retrieving file 'chaotic-mirrorlist-20240724-1-any.pkg.tar.zst' from in-mirror.chaotic.cx : The requested URL returned error: 416
error: failed retrieving file 'chaotic-mirrorlist-20240724-1-any.pkg.tar.zst' from in-2-mirror.chaotic.cx : The requested URL returned error: 416
error: failed retrieving file 'chaotic-mirrorlist-20240724-1-any.pkg.tar.zst' from in-3-mirror.chaotic.cx : The requested URL returned error: 416
error: failed retrieving file 'chaotic-mirrorlist-20240724-1-any.pkg.tar.zst' from in-4-mirror.chaotic.cx : The requested URL returned error: 416
error: failed retrieving file 'chaotic-mirrorlist-20240724-1-any.pkg.tar.zst' from kr-mirror.chaotic.cx : The requested URL returned error: 416
error: failed retrieving file 'chaotic-mirrorlist-20240724-1-any.pkg.tar.zst' from es-mirror.chaotic.cx : The requested URL returned error: 416
error: failed retrieving file 'chaotic-mirrorlist-20240724-1-any.pkg.tar.zst' from es-2-mirror.chaotic.cx : The requested URL returned error: 416
error: failed retrieving file 'chaotic-mirrorlist-20240724-1-any.pkg.tar.zst' from us-mi-mirror.chaotic.cx : The requested URL returned error: 416
error: failed retrieving file 'chaotic-mirrorlist-20240724-1-any.pkg.tar.zst' from us-tx-mirror.chaotic.cx : The requested URL returned error: 416
error: failed retrieving file 'chaotic-mirrorlist-20240724-1-any.pkg.tar.zst' from us-ut-mirror.chaotic.cx : expected download size exceeded
warning: failed to retrieve some files
error: failed to commit transaction (download library error)
Got it first with update, then tried again with update -a, same.
You don’t have skip mirrorlist set in ā€œgaruda-updateā€? as the would affect upd an update etc.
I type in update (same as garuda-update), confirm password, I get the errors, then it stops. I did not do any special setup on the update file.
Seen that one a minute after posting my log. Thought these were connected, thanks for the confirmation SGS. I will wait.
Ungoogled-chromium needs to be updated. Thanks!
paru ungoogled
1 aur/ungoogled-chromium 130.0.6723.58-1
2 aur/ungoogled-chromium-bin 130.0.6723.58-1
130.0.6723.58-1 [Latest]
EDIT:
OK, I’ve now read your other posts on the subject. And itĀ“s only Chaotic AUR here. Consider my post irrelevant. My fault.
