Please be careful with your statements.
Upstream is dead or nonexistent, therefore unusable & unbuildable. It can be explored again when itās public. Please refrain from these comments. https://github.com/ghostty-org/ghostty
I think this package is from chaotic-aur:
:: installing wine-stable (9.0-15) breaks dependency 'wine>=4.0rc1' required by dxvk-mingw-git
:: installing wine-stable (9.0-15) breaks dependency 'wine' required by wine-gecko
:: installing wine-stable (9.0-15) breaks dependency 'wine' required by wine-installer
:: installing wine-stable (9.0-15) breaks dependency 'wine' required by wine-meta
:: installing wine-stable (9.0-15) breaks dependency 'wine' required by wine-mono
:: installing wine-stable (9.0-15) breaks dependency 'wine' required by wine-nine
:: installing wine-stable (9.0-15) breaks dependency 'wine' required by wineasio
:: installing wine-stable (9.0-15) breaks dependency 'wine' required by winetricks
:: installing wine-stable (9.0-15) breaks dependency 'wine' required by yabridge
@z3n this should be resolved by the changes shown here:
Can we get updates in the Choatic-AUR for these packages, please:
python-tokenizers: GitHub - huggingface/tokenizers: š„ Fast State-of-the-Art Tokenizers optimized for Research and Production
python-transformers: GitHub - huggingface/transformers: š¤ Transformers: State-of-the-art Machine Learning for Pytorch, TensorFlow, and JAX.
python-safetensors: GitHub - huggingface/safetensors: Simple, safe way to store and distribute tensors
We cannot, since these packages do not belong. They would be considered dangling dependencies, as they arenāt required directly by something we already provide. To quote our guidelines listed on the GitHub repository:
Dependencies without any dependents: Such packages are useless by themselves. Maintaining them wastes effort that is better spent elsewhere.
I understand that python-transformers
and others take a long time to install because of slowly resolving the dependency trees, it sucks, and you want it to suck less, thatās fair. The most appropriate way to get them is within a virtual environment, though that doesnāt help speed.
Luckily, the speed issue can be mitigated my using something else for dependency resolution. Iāve been having an EXCELLENT experience with UV recently, and would encourage taking a look at it, especially as you get into the large & messy world of AI dependencies. Itās replaced poetry for me in a few places:
In the very very rare case that something isnāt supported by UV yet, it will definitely work via pyenv:
If you are doing something for work, and cannot use third-party dependencies, hereās the documentation for the built-in (official) module for virtual environments:
Also note, when you research virtual environments, virtualenv
should no longer be used at all. Thereās still many guides recommending it, but theyāre old and wrong, donāt let your time be wasted:
Looks like one more bug we have here.
āāastro@garuda in ~
ā°āĪ» cpu-x
cpu-x: error while loading shared libraries: libcpuid.so.16: cannot open shared object file: No such file or directory
Believe it just needs to be updated. I attempted to run it yesterday and it wouldnāt launch, so I removed it and installed the recently updated cpu-x-git from the AUR and it works perfectly. The Chaotic cpu-x-git errored out during attempted install.
Right, for testing I installed cpu-x and point it up.
The chaotic git version works.
chaotic-aur/cpu-x-git 5.0.4.r77.gd27244f-1 14,76 MiB 4,68 MiB
This maintainer is known to not bump pkgrel when others normally would, and instead recommends people to rebuild per their pinned comment. That means someone from Chaotic-AUR needs to manually intervene and bump for rebuild any time a shared library updates. Please do report the same in the future since this will definitely continue to occur: AUR (en) - cpu-x
Iāve rebuilt it, thanks: Finished making: cpu-x 5.0.4-1.1 (Tue 03 Sep 2024 11:07:15 PM CEST)
Requesting testers for minq-ananicy-git
If you are already using ananicy-cpp, you may not be a good candidate to do a āfast testā, since you would likely want to swap back.
Apparently there is a bug on launch which causes a crash, but I canāt reproduce it on my machine. Simply installing then starting the service should be enough to test. The related pull request is here:
A post was merged into an existing topic: Pacman 7.0.0 breaks dependency
Since this is a gaming-focused distro, could we add G13 driver from: https://github.com/jtgans/g13gui.
I followed the build instructions but I keep getting an error related to āb_pieā.
I think ffmpeg-full
needs a rebuild. Both ffmpeg and spectacle are broken atm.
ffmpeg: error while loading shared libraries: libjxl.so.0.10: cannot open shared object file: No such file or
directory
It was bumped, should be available sometime soon
What is the full specific error? I donāt know anything about that device, but I see this exists on the AUR (though flagged), it may be useful since thereās seemingly a fix in comments? GitHub - khampf/g13: libusb driver for the g13 / AUR (en) - g13
If something doesnāt build, then we canāt add it.
Hereās the output I get when running make:
āālumbergh@Initech in repo: g13gui on ļ master [!] via ī v3.12.6
ā°āĪ» make
Makefile:24: Building on archlinux
mkdir -p build
makepkg --nodeps
==> Making package: g13gui 3d94e8e-1 (Tue 24 Sep 2024 11:08:19 AM PDT)
==> WARNING: Skipping dependency checks.
==> Retrieving sources...
-> Updating g13gui-git git repo...
warning: redirecting to https://github.com/jtgans/g13gui.git/
==> Validating source files with sha256sums...
g13gui-git ... Skipped
==> Extracting sources...
-> Creating working copy of g13gui-git git repo...
Reset branch 'makepkg'
==> Starting prepare()...
M Makefile
M PKGBUILD
Already on 'master'
Your branch is up to date with 'origin/master'.
==> Starting pkgver()...
==> Removing existing $pkgdir/ directory...
==> Starting build()...
+ exec meson setup --prefix /usr --libexecdir lib --sbindir bin --buildtype plain --auto-features enabled --wrap-mode nodownload -D b_pie=true -D python.bytecompile=1 /home/lumbergh/g13gui/src/g13gui-git build
Directory already configured.
Just run your build command (e.g. ninja) and Meson will regenerate as necessary.
Run "meson setup --reconfigure to force Meson to regenerate.
If build failures persist, run "meson setup --wipe" to rebuild from scratch
using the same options as passed when configuring the build.
ERROR: Unknown options: "b_pie"
==> ERROR: A failure occurred in build().
Aborting...
make: *** [Makefile:36: archlinux] Error 4
It seems this is a somewhat new known issue with meson
itself, and may be fixed with some time
Try to add a new line here
which has
'c',
To be very clear, it should look like
project(
'g13gui',
'c',
license: 'MIT'
can you add : AUR (en) - spacedrive , a new rust file manager
It must be updated first.
