Hello everybody,
Following the release of GCC11 in ArchLinux's core repository, the idea now is to follow the official ArchLinux's project trend and have everything optimized for "x86-64-v3" or falling back to the "v1".
As the first move, we're now dropping all "architecture-specific" packages of the beloved "linux-tkg". You'll find in the repo either the generic one (e.g: "linux-tkg-bmq"), and a v3-optimized one (e.g: "linux-tkg-bmq-generic_v3").
Thanks to that PDS and CFS builds are back!
NOTE: In the future, once ArchLinux has the new v3 repos working well, we'll then move the v3-optimized under our v3 repos without the "-generic_v3" suffix.
dr460nf1r3:
can i use for my specs and i get an error
Fehler: linux-tkg-bmq-generic_v3: Signatur von “Pedro Henrique Lara Campos root@pedrohlc.com ” ist ungültig
Vorgang konnte nicht abgeschlossen werden:
Ungültiges oder beschädigtes Paket:
specs are System:
v: 11.1.0
root=UUID=xxxxxxxx-xxxxxx-xxxxxx rw rootflags=subvol=@
Desktop: KDE Plasma 5.21.5 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11
Type: Convertible System: HP product: HP ENVY x360 Convertible
v: Type1ProductConfigId serial: <superuser required> Chassis: type: 31
Mobo: HP model: 81AD v: 58.54 serial: <superuser required>
UEFI-[Legacy]: Insyde v: F.59 date: 12/18/2019
ID-1: BAT0 charge: 47.8 Wh (100.0%) condition: 47.8/47.8 Wh (100.0%)
volts: 16.9 min: 15.4 model: 313-54-41 MB04055XL type: Li-ion
serial: 43855 status: Full
Info: Dual Core model: Intel Core i5-7200U bits: 64 type: MT MCP
arch: Amber/Kaby Lake note: check family: 6 model-id: 8E (142)
stepping: 9 microcode: DE cache: L2: 3 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
bogomips: 21623
Speed: 1259 MHz min/max: 400/3100 MHz Core speeds (MHz): 1: 1259 2: 1338
3: 1163 4: 1200
Type: l1tf
Device-1: Intel HD Graphics 620 vendor: Hewlett-Packard driver: i915
v: kernel bus-ID: 00:02.0 chip-ID: 8086:5916 class-ID: 0300
Device-2: Cheng Uei Precision Industry (Foxlink) HP Wide Vision HD
integrated webcam
type: USB driver: uvcvideo bus-ID: 1-4:4 chip-ID: 05c8:038e
class-ID: 0e02 serial: 200901010001
Display: x11 server: X.Org 1.20.11 compositor: kwin_x11 driver:
loaded: intel unloaded: modesetting alternate: fbdev,vesa display-ID: :0
Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1013x285mm (39.9x11.2")
s-diag: 1052mm (41.4")
Monitor-1: eDP1 res: 1920x1080 hz: 60 dpi: 143
size: 340x190mm (13.4x7.5") diag: 389mm (15.3")
Monitor-2: HDMI1 res: 1920x1080 hz: 60 dpi: 40
size: 1210x680mm (47.6x26.8") diag: 1388mm (54.6")
OpenGL: renderer: Mesa Intel HD Graphics 620 (KBL GT2) v: 4.6 Mesa 21.1.0
direct render: Yes
Sound Server-1: ALSA v: k5.12.5-158-tkg-bmq running: yes
Sound Server-4: PipeWire v: 0.3.28 running: yes
Device-1: Intel Wireless 7265 driver: iwlwifi v: kernel port: 3040
bus-ID: 01:00.0 chip-ID: 8086:095a class-ID: 0280
IF: wlo1 state: up mac: c6:24:51:8f:fa:08
IF-ID-1: virbr0 state: down mac: 52:54:00:dc:59:76
Device-1: Intel Bluetooth wireless interface type: USB driver: btusb
v: 0.8 bus-ID: 1-6:6 chip-ID: 8087:0a2a class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 1 state: up
address: D0:57:7B:85:99:99
Local Storage: total: 1.5 TiB used: 923.41 GiB (60.0%)
model: WDS500G2B0B-00YS70 size: 465.76 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s rotation: SSD serial: 19186D806758
rev: 00WD scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: SanDisk model: SDSSDH3 1T00
speed: 6.0 Gb/s rotation: SSD serial: 200820A0155B rev: 40RL scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 type: USB vendor: Sabrent model: SABRENT
size: 111.79 GiB block-size: physical: 4096 B logical: 512 B
serial: DB9876543214E rev: 0204 scheme: MBR
ID-4: /dev/sdf maj-min: 8:80 type: USB model: USB Disk 3.0 size: 29 GiB
block-size: physical: 512 B logical: 512 B serial: 7192810848585790
rev: 0009 scheme: MBR
ID-1: / raw-size: 465.76 GiB size: 465.76 GiB (100.00%)
used: 285.63 GiB (61.3%) fs: btrfs dev: /dev/sda1 maj-min: 8:1
ID-2: /home raw-size: 465.76 GiB size: 465.76 GiB (100.00%)
ID-3: /var/log raw-size: 465.76 GiB size: 465.76 GiB (100.00%)
ID-4: /var/tmp raw-size: 465.76 GiB size: 465.76 GiB (100.00%)
Kernel: swappiness: 10 (default 60) cache-pressure: 75 (default 100)
ID-1: swap-1 type: zram size: 4.86 GiB used: 9.2 MiB (0.2%)
priority: 32767 dev: /dev/zram0
ID-2: swap-2 type: zram size: 4.86 GiB used: 9.3 MiB (0.2%)
priority: 32767 dev: /dev/zram1
ID-3: swap-3 type: zram size: 4.86 GiB used: 9.6 MiB (0.2%)
priority: 32767 dev: /dev/zram2
ID-4: swap-4 type: zram size: 4.86 GiB used: 9.6 MiB (0.2%)
priority: 32767 dev: /dev/zram3
System Temperatures: cpu: 52.0 C mobo: 40.0 C
Processes: 276 Uptime: 11h 47m wakeups: 1 Memory: 19.42 GiB
used: 12.3 GiB (63.3%) Init: systemd v: 248 tool: systemctl Compilers:
gcc: 11.1.0 clang: 11.1.0 Packages: 1648 pacman: 1627 lib: 383
flatpak: 11 snap: 10 Shell: fish v: 3.2.2 running-in: konsole
inxi: 3.3.04~~~
sorry i get many errors in /usr/lib/modules exists in linux-tkg-bmq as also in linux-tkg-bmq-generic_v3
https://bin.garudalinux.org/?6ec7fbce4bf4cd8d#Hcvob21cgKdyiz1E4DtK4UiAkDyBuq9FyCdCKAHeUaY5
Well its one and the same package, just for compiled with other flags so thats to be expected
I am running into the same problems. I think that you will need to uninstall linux-tkg-bmq, reboot and then install the v3. I would really like if v3 just replaced v1 so that there was a smoother transition. Sounds like this will be happening in the future.
yes it functions i just deinstall v1 and install v3 it works
but you must first and only deinstall v1 there are some warnings and then you can install v3 thanks
did you notice any difference in speed between v1 and v3?
