Hello…
I have two versions of Garuda installed on different drives on the same desktop (Garuda Dragonized on /dev/nvme0n1 and Garuda Sway on /dev/nvme1n1) and so I have two entries named “Garuda” in the grub boot menu. I use the Dragonized version most often. It isn’t a very descriptive name, unfortunately, and it seems like since the Sway version is what I installed last, that’s always what boots, even if I change the boot order in the Garuda Boot Options app in the Dragonized installation.
I’ve looked at these topics and there seem to be varying degrees of success changing the boot order, but unfortunately setting GRUB_DEFAULT=2 nor GRUB_SAVEDEFAULT=true seems to work after a sudo update-grub, and none of them seem to talk about changing the names:
https://forum.garudalinux.org/t/garuda-boot-options-not-applying/2681/26
I also saw this, but I don’t know that I need to change it from UEFI since technically grub can boot both of them:
And then there’s this, but when I look at the files in /etc/grub.d in Dragonized, they all seem to be generated with variables which are defined somewhere, and I can’t figure out where it’s getting the names.
https://wiki.archlinux.org/title/GRUB
So, how do I change at least the names of the entries in the grub menu?
Following is the garuda-inxi output:
Kernel: 6.12.7-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=79bebd74-6c02-4148-b1e5-1bed3e4c4274 rw rootflags=subvol=@
quiet resume=UUID=03ba1005-a576-46de-bba3-38f9d149082e loglevel=3 ibt=off
Desktop: KDE Plasma v: 6.2.5 tk: Qt v: N/A info: frameworks v: 6.9.0
Type: Desktop Mobo: ASRock model: B550 Taichi Razer Edition
Megatrends LLC. v: L3.46 date: 08/20/2024
Info: model: AMD Ryzen 7 5800X3D bits: 64 type: MT MCP arch: Zen 3+ gen: 3
desc: 8x512 KiB L3: 96 MiB desc: 1x96 MiB
Speed (MHz): avg: 3595 min/max: 550/4550 boost: enabled scaling:
driver: amd-pstate-epp governor: performance cores: 1: 3595 2: 3595 3: 3595
4: 3595 5: 3595 6: 3595 7: 3595 8: 3595 9: 3595 10: 3595 11: 3595 12: 3595
13: 3595 14: 3595 15: 3595 16: 3595 bogomips: 108588
Device-1: Intel DG2 [Arc A770] vendor: ASRock driver: i915 v: kernel
alternate: xe arch: Gen-12.7 code: Alchemist process: TSMC n6 (7nm)
built: 2022+ pcie: gen: 1 speed: 2.5 GT/s lanes: 1 ports: active: DP-1
off: HDMI-A-4 empty: DP-2, DP-3, DP-4, HDMI-A-1, HDMI-A-2, HDMI-A-3
bus-ID: 0e:00.0 chip-ID: 8086:56a0 class-ID: 0300
Device-2: Advanced Micro Devices [AMD/ATI] Navi 31 [Radeon RX 7900
XT/7900 XTX/7900 GRE/7900M] vendor: Yeston driver: amdgpu v: kernel
arch: RDNA-3 code: Navi-3x process: TSMC n5 (5nm) built: 2022+ pcie:
gen: 4 speed: 16 GT/s lanes: 16 ports: active: none off: DP-5,HDMI-A-5
empty: DP-6,DP-7,Writeback-1 bus-ID: 12:00.0 chip-ID: 1002:744c
compositor: kwin_wayland driver: X: loaded: amdgpu,modesetting
unloaded: radeon alternate: fbdev,intel,vesa dri: iris,radeonsi
gpu: i915,amdgpu display-ID: 0
Monitor-1: DP-1 res: 1920x1080 size: N/A modes: N/A
API: EGL v: 1.5 hw: drv: intel iris drv: amd radeonsi platforms: device: 0
drv: iris device: 1 drv: radeonsi device: 2 drv: swrast gbm: drv: iris
surfaceless: drv: iris wayland: drv: iris x11: drv: iris
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.3.2-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Arc A770 Graphics (DG2)
device-ID: 8086:56a0 memory: 15.53 GiB unified: no display-ID: :1.0
API: Vulkan v: 1.4.303 layers: 14 device: 0 type: discrete-gpu name: Intel
Arc A770 Graphics (DG2) driver: N/A device-ID: 8086:56a0
surfaces: xcb,xlib,wayland device: 1 type: discrete-gpu name: AMD Radeon
RX 7900 XTX (RADV NAVI31) driver: N/A device-ID: 1002:744c
Device-1: Intel DG2 Audio vendor: ASRock driver: snd_hda_intel v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 0f:00.0 chip-ID: 8086:4f90
Device-2: Advanced Micro Devices [AMD/ATI] Navi 31 HDMI/DP Audio
bus-ID: 12:00.1 chip-ID: 1002:ab30 class-ID: 0403
Device-3: Advanced Micro Devices [AMD] Starship/Matisse HD Audio
vendor: ASRock driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
lanes: 16 bus-ID: 14:00.4 chip-ID: 1022:1487 class-ID: 0403
API: ALSA v: k6.12.7-zen1-1-zen status: kernel-api with: aoss
Device-1: Intel driver: igc v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1
port: N/A bus-ID: 05:00.0 chip-ID: 8086:3102 class-ID: 0200
Device-2: Intel Wi-Fi 6 AX200 vendor: Rivet Networks Killer
driver: iwlwifi v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1
bus-ID: 08:00.0 chip-ID: 8086:2723 class-ID: 0280
IF: wlp8s0 state: up mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-9:5 chip-ID: 8087:0029
Local Storage: total: 3.68 TiB used: 407.99 GiB (10.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 model: NX-2TB 2280 size: 1.86 TiB
tech: SSD serial: <filter> fw-rev: H240129a temp: 41.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:4 vendor: SanDisk model: Extreme 2TB X3N
lanes: 4 tech: SSD serial: <filter> fw-rev: 731100WD temp: 42.9 C
ID-1: / raw-size: 1.8 TiB size: 1.8 TiB (100.00%) used: 407.99 GiB (22.2%)
used: 407.99 GiB (22.2%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 62.72 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 68.99 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 45.6 C mobo: N/A gpu: amdgpu temp: 32.0 C
mem: 60.0 C
Fan Speeds (rpm): fan-1: 366 gpu: amdgpu fan: 0
Memory: total: 64 GiB note: est. available: 62.72 GiB used: 7.94 GiB (12.7%)
Processes: 443 Power: uptime: 20h 38m states: freeze,mem,disk
reboot, suspend, test_resume image: 25.08 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1952 libs: 578 tools: octopi,paru,pikaur
Compilers: clang: 18.1.8 gcc: 14.2.1 alt: 13 Shell: garuda-inxi
default: fish v: 3.7.1 running-in: konsole inxi: 3.3.36
System install date: 2024-12-03
Last full system update: 2025-01-03 ↻
uname -a:
Linux purple 6.12.7-zen1-1-zen #1 ZEN SMP PREEMPT_DYNAMIC Fri, 27 Dec 2024 14:24:32 +0000 x86_64 GNU/Linux
The contents of /etc/default/grub:
File: /etc/default/grub
# GRUB boot loader configuration
GRUB_DEFAULT="2"
GRUB_TIMEOUT=5
GRUB_DISTRIBUTOR='Garuda'
GRUB_CMDLINE_LINUX_DEFAULT="quiet resume=UUID=03ba1005-a576-46de-bba3-38f9d149082e loglevel=3"
GRUB_CMDLINE_LINUX=""
# Preload both GPT and MBR modules so that they are not missed
GRUB_PRELOAD_MODULES="part_gpt part_msdos"
# Uncomment to enable booting from LUKS encrypted devices
#GRUB_ENABLE_CRYPTODISK=y
# Set to 'countdown' or 'hidden' to change timeout behavior,
# press ESC key to display menu.
GRUB_TIMEOUT=5
# Uncomment to use basic console
GRUB_TERMINAL_INPUT=console
# Uncomment to disable graphical terminal
#GRUB_TERMINAL_OUTPUT=console
# The resolution used on graphical terminal
# note that you can use only modes which your graphic card supports via VBE
# you can see them in real GRUB with the command `videoinfo'
GRUB_GFXMODE=auto
# Uncomment to allow the kernel use the same resolution used by grub
GRUB_GFXPAYLOAD_LINUX=keep
# Uncomment if you want GRUB to pass to the Linux kernel the old parameter
# format "root=/dev/xxx" instead of "root=/dev/disk/by-uuid/xxx"
#GRUB_DISABLE_LINUX_UUID=true
# Uncomment to disable generation of recovery mode menu entries
#GRUB_DISABLE_RECOVERY=true
# Uncomment and set to the desired menu colors. Used by normal and wallpaper
# modes only. Entries specified as foreground/background.
#GRUB_COLOR_NORMAL="light-blue/black"
#GRUB_COLOR_HIGHLIGHT="light-cyan/blue"
# Uncomment one of them for the gfx desired, a image background or a gfxtheme
#GRUB_BACKGROUND="/path/to/wallpaper"
GRUB_THEME="/usr/share/grub/themes/garuda-dr460nized/theme.txt"
# Uncomment to get a beep at GRUB start
#GRUB_INIT_TUNE="480 440 1"
# Uncomment to make GRUB remember the last selection. This requires
# setting 'GRUB_DEFAULT=saved' above.
# Uncomment to disable submenus in boot menu
#GRUB_DISABLE_SUBMENU=y
# Probing for other operating systems is disabled for security reasons. Read
# documentation on GRUB_DISABLE_OS_PROBER, if still want to enable this
# functionality install os-prober and uncomment to detect and include other
# operating systems.
GRUB_DISABLE_OS_PROBER=false
# This config file imports drop-in files from /etc/default/grub.d/.
for garuda_grub_d in ${sysconfdir}/default/grub.d/*.cfg ; do if [ -e "${garuda_grub_d}" ]; then source "${garu
da_grub_d}"; fi; done
GRUB_EARLY_INITRD_LINUX_STOCK=''
inxi --recommends:
inxi will now begin checking for the programs it needs to operate.
Check inxi --help or the man page (man inxi) to see what options are
available.
Test: core tools:
Perl version: 5.040000
Current shell: fish 3.7.1
Default shell: fish
sh links to: /usr/bin/bash
Package manager: pacman
Test: required system directories:
/proc: ........................................................... Present
/sys: ............................................................ Present
All required system directories are present
Test: recommended system programs:
Note: IPMI sensors are generally only found on servers. To access that data,
you only need one of the ipmi items.
blockdev: --admin -p/-P (filesystem blocksize).................... Present
bt-adapter: -E bluetooth data (if no hciconfig, btmgmt)........... Present
btmgmt: -E bluetooth data (if no hciconfig)....................... Present
dig: -i wlan IP................................................... Present
dmidecode: -M if no sys machine data; -m.......................... Present
doas: -Dx hddtemp-user; -o file-user (alt for sudo)............... Missing
fdisk: -D partition scheme (fallback)............................. Present
file: -o unmounted file system (if no lsblk)...................... Present
fruid_print: -M machine data, Elbrus only......................... Missing
hciconfig: -E bluetooth data (deprecated, good report)............ Missing
hddtemp: -Dx show hdd temp, if no drivetemp module................ Missing
ifconfig: -i ip LAN (deprecated, ip preferred).................... Present
ip: -i ip LAN..................................................... Present
ipmitool: -s IPMI sensors (servers)............................... Missing
ipmi-sensors: -s IPMI sensors (servers)........................... Missing
lsblk: -L LUKS/bcache; -o unmounted file system (best option)..... Present
lspci: -A,-E,-G,-N,-R PCI Device data (/sys supplies much)........ Present
lsusb: -A,-E,-G,-J,-N USB Device data (/sys supplies much)........ Present
lvs: -L LVM data.................................................. Present
mdadm: -Ra advanced mdraid data................................... Present
modinfo: Ax; -Nx module version................................... Present
ps: -G,-I,-n,-S,-t process/programs............................... Present
runlevel: -I fallback to Perl..................................... Missing
sensors: -s sensors output (optional, /sys supplies most)......... Present
smartctl: -Da advanced data....................................... Present
strings: -I sysvinit version...................................... Present
sudo: -Dx hddtemp-user; -o file-user (try doas!).................. Present
tree: --debugger 20,21 /sys tree.................................. Missing
udevadm: -m ram data for non-root, or no dmidecode................ Present
upower: -sx attached device battery info.......................... Present
uptime: -I uptime................................................. Present
The following recommended system programs are missing:
doas
pacman: doas
fruid_print
pacman: N/A
hciconfig
pacman: bluez-utils-compat (frugalware: bluez-utils)
hddtemp
pacman: hddtemp
ipmitool
pacman: ipmitool
ipmi-sensors
pacman: freeipmi
runlevel
pacman: systemd
tree
pacman: tree
Test: recommended display information programs:
eglinfo: -G X11/Wayland EGL info.................................. Present
glxinfo: -G X11 GLX info.......................................... Present
vulkaninfo: -G Vulkan API info.................................... Present
wayland-info: -G Wayland data (not for X)......................... Present
wmctrl: -S active window manager (fallback)....................... Missing
xdpyinfo: -G (X) Screen resolution, dpi; -Ga Screen size.......... Present
xprop: -S (X) desktop data........................................ Present
xdriinfo: -G (X) DRI driver (if missing, fallback to Xorg log).... Missing
xrandr: -G (X) monitors(s) resolution; -Ga monitor data........... Present
The following recommended display information programs are missing:
wmctrl
pacman: wmctrl
xdriinfo
pacman: xorg-xdriinfo
Test: recommended downloader programs (You only need one of these):
Perl HTTP::Tiny is the default downloader tool if IO::Socket::SSL is present.
See --help --alt 40-44 options for how to override default downloader(s) in
case of issues.
If dig is installed, it is the default for WAN IP data. Strongly recommended.
Dig is fast and accurate.
curl: -i (if no dig); -w,-W; -U................................... Present
wget: -i (if no dig); -w,-W; -U................................... Present
All recommended downloader programs are present
Test: recommended kernel modules:
GPU modules are only needed if applicable. NVMe drives do not need drivetemp
but other types do.
To load a module: modprobe <module-name> - To permanently load add to
/etc/modules or /etc/modules-load.d/modules.conf (check your system paths for
exact file/directory names).
amdgpu: -s, -G AMD GPU sensor data (newer GPUs)................... Present
drivetemp: -Dx drive temperature (kernel >= 5.6).................. Missing
nouveau: -s, -G Nvidia GPU sensor data (if using free driver)..... Missing
radeon: -s, -G AMD GPU sensor data (older GPUs)................... Missing
The following recommended kernel modules are missing:
drivetemp
nouveau
radeon
Test: recommended Perl modules (Optional):
None of these are strictly required, but if you have them all, you can
eliminate some recommended non Perl programs from the install.
HTTP::Tiny and IO::Socket::SSL must both be present to use as a downloader
option. For json export Cpanel::JSON::XS is preferred over JSON::XS, but
JSON::PP is in core modules. To run --debug 20-22 File::Copy, File::Find, and
File::Spec::Functions must be present (most distros have these in Core
Modules).
File::Copy: --debug 20-22 - required for debugger................. Present
File::Find: --debug 20-22 - required for debugger................. Present
File::Spec::Functions: --debug 20-22 - required for debugger...... Present
HTTP::Tiny: -U; -w,-W; -i (if dig not installed).................. Present
IO::Socket::SSL: -U; -w,-W; -i (if dig not installed)............. Missing
Time::HiRes: -C cpu sleep (not required); --debug timers.......... Present
JSON::PP: -G wayland, --output json (in CoreModules, slower)...... Present
Cpanel::JSON::XS: -G wayland, --output json (faster).............. Missing
JSON::XS: -G wayland, --output json (legacy)...................... Missing
XML::Dumper: --output xml - Crude and raw......................... Missing
Net::FTP: --debug 21,22........................................... Present
The following recommended Perl modules are missing:
IO::Socket::SSL
pacman: perl-io-socket-ssl
Cpanel::JSON::XS
pacman: perl-cpanel-json-xs
JSON::XS
pacman: perl-json-xs
XML::Dumper
pacman: perl-xml-dumper
Test: recommended directories:
/dev: -l,-u,-o,-p,-P,-D disk partition data....................... Present
/dev/disk/by-id: -D serial numbers................................ Present
/dev/disk/by-label: -l,-o,-p,-P partition labels.................. Present
/dev/disk/by-path: -D extra data.................................. Present
/dev/disk/by-uuid: -u,-o,-p,-P partition uuid..................... Present
/sys/class/dmi/id: -M system, motherboard, bios................... Present
/sys/class/hwmon: -s sensor data (fallback if no lm-sensors)...... Present
All recommended directories are present
Test: recommended files:
Note that not all of these are used by every system, so if one is missing it's
usually not a big deal.
/etc/lsb-release: -S distro version data (older version).......... Present
/etc/os-release: -S distro version data (newer version)........... Present
/proc/asound/cards: -A sound card data............................ Present
/proc/asound/version: -A ALSA data................................ Present
/proc/cpuinfo: -C cpu data........................................ Present
/proc/mdstat: -R mdraid data (if you use dm-raid)................. Missing
/proc/meminfo: -I,-tm, -m memory data............................. Present
/proc/modules: -G module data (sometimes)......................... Present
/proc/mounts: -P,-p partition advanced data....................... Present
/proc/scsi/scsi: -D Advanced hard disk data (used rarely)......... Present
/var/log/Xorg.0.log: -G graphics driver load status............... Present
The following recommended files are missing:
/proc/mdstat
Ok, all done with the checks. Have a nice day.
