I was trying to change the default boot kernel from zen to cacule. I was able to add a kernel option and timer without any issues. It is just not allowing me to change which is the default kernel. I was hoping I could change the order in /boot/grub/grub.cfg and run sudo update-grub but that doesn't work either. Here is the output:
╭─xxxx@xxxx in ~
╰─λ sudo garuda-boot-options
[sudo] password for xxxx:
QStandardPaths: XDG_RUNTIME_DIR not set, defaulting to '/tmp/runtime-root'
garuda-boot-options version: 0.1
Exec #1: "logname"
Exit #1: 0 QProcess::NormalExit
Exec #2: "mountpoint -q /live/aufs"
Exit #2: 1 QProcess::NormalExit
Exec #3: "plymouth-set-default-theme -l"
Exit #3: 0 QProcess::NormalExit
Exec #4: "plymouth-set-default-theme"
Exit #4: 0 QProcess::NormalExit
Exec #5: "pacman -Qq plymouth"
Exit #5: 0 QProcess::NormalExit
Exec #6: "pacman -Qq plymouth"
Exit #6: 0 QProcess::NormalExit
Exec #7: "test -z \"$(lspci -d 80ee:beef)\""
Exit #7: 0 QProcess::NormalExit
Exec #8: "df -T / |tail -n1 |awk '{print $2}'"
Exit #8: 0 QProcess::NormalExit
Exec #9: "update-grub"
SErr #9: "Generating grub configuration file ...\nFound theme: /usr/share/grub/themes/garuda-dr460nized/theme.txt\nFound linux image: /boot/vmlinuz-linux-zen\nFound initrd image: /boot/intel-ucode.img /boot/initramfs-linux-zen.img\nFound fallback initrd image(s) in /boot: intel-ucode.img initramfs-linux-zen-fallback.img\nFound linux image: /boot/vmlinuz-linux-lts\nFound initrd image: /boot/intel-ucode.img /boot/initramfs-linux-lts.img\nFound fallback initrd image(s) in /boot: intel-ucode.img initramfs-linux-lts-fallback.img\nFound linux image: /boot/vmlinuz-linux-cacule\nFound initrd image: /boot/intel-ucode.img /boot/initramfs-linux-cacule.img\nFound fallback initrd image(s) in /boot: intel-ucode.img initramfs-linux-cacule-fallback.img\nFound linux image: /boot/vmlinuz-linux\nFound initrd image: /boot/intel-ucode.img /boot/initramfs-linux.img\nFound fallback initrd image(s) in /boot: intel-ucode.img initramfs-linux-fallback.img\nWarning: os-prober will be executed to detect other bootable partitions.\nIts output will be used to detect bootable binaries on them and create new boot entries.\nAdding boot menu entry for UEFI Firmware Settings ...\nDetecting snapshots ...\nInfo: Separate boot partition not detected \nFound snapshot: 2021-09-25 22:15:29 | timeshift-btrfs/snapshots/2021-09-25_22-15-29/@\nFound snapshot: 2021-09-25 20:00:01 | timeshift-btrfs/snapshots/2021-09-25_20-00-01/@\nFound snapshot: 2021-09-24 20:00:01 | timeshift-btrfs/snapshots/2021-09-24_20-00-01/@\nFound snapshot: 2021-09-24 10:35:20 | timeshift-btrfs/snapshots/2021-09-24_10-35-20/@\nFound snapshot: 2021-09-24 08:04:44 | timeshift-btrfs/snapshots/2021-09-24_08-04-44/@\nFound snapshot: 2021-09-23 23:48:19 | timeshift-btrfs/snapshots/2021-09-23_23-48-19/@\nFound snapshot: 2021-09-23 23:45:49 | timeshift-btrfs/snapshots/2021-09-23_23-45-49/@\nFound snapshot: 2021-09-23 20:00:01 | timeshift-btrfs/snapshots/2021-09-23_20-00-01/@\nFound 8 snapshot(s)\nUnmount /tmp/grub-btrfs.yAOfgIhFNQ .. Success\nFound memtest86+ image: /boot/memtest86+/memtest.bin\ndone\n"
Exit #9: 0 QProcess::NormalExit
Exec #10: "grub-editenv /boot/grub/grubenv unset next_entry"
Exit #10: 0 QProcess::NormalExit
Exec #11: "update-grub"
SErr #11: "Generating grub configuration file ...\nFound theme: /usr/share/grub/themes/garuda-dr460nized/theme.txt\nFound linux image: /boot/vmlinuz-linux-zen\nFound initrd image: /boot/intel-ucode.img /boot/initramfs-linux-zen.img\nFound fallback initrd image(s) in /boot: intel-ucode.img initramfs-linux-zen-fallback.img\nFound linux image: /boot/vmlinuz-linux-lts\nFound initrd image: /boot/intel-ucode.img /boot/initramfs-linux-lts.img\nFound fallback initrd image(s) in /boot: intel-ucode.img initramfs-linux-lts-fallback.img\nFound linux image: /boot/vmlinuz-linux-cacule\nFound initrd image: /boot/intel-ucode.img /boot/initramfs-linux-cacule.img\nFound fallback initrd image(s) in /boot: intel-ucode.img initramfs-linux-cacule-fallback.img\nFound linux image: /boot/vmlinuz-linux\nFound initrd image: /boot/intel-ucode.img /boot/initramfs-linux.img\nFound fallback initrd image(s) in /boot: intel-ucode.img initramfs-linux-fallback.img\nWarning: os-prober will be executed to detect other bootable partitions.\nIts output will be used to detect bootable binaries on them and create new boot entries.\nAdding boot menu entry for UEFI Firmware Settings ...\nDetecting snapshots ...\nInfo: Separate boot partition not detected \nFound snapshot: 2021-09-25 22:15:29 | timeshift-btrfs/snapshots/2021-09-25_22-15-29/@\nFound snapshot: 2021-09-25 20:00:01 | timeshift-btrfs/snapshots/2021-09-25_20-00-01/@\nFound snapshot: 2021-09-24 20:00:01 | timeshift-btrfs/snapshots/2021-09-24_20-00-01/@\nFound snapshot: 2021-09-24 10:35:20 | timeshift-btrfs/snapshots/2021-09-24_10-35-20/@\nFound snapshot: 2021-09-24 08:04:44 | timeshift-btrfs/snapshots/2021-09-24_08-04-44/@\nFound snapshot: 2021-09-23 23:48:19 | timeshift-btrfs/snapshots/2021-09-23_23-48-19/@\nFound snapshot: 2021-09-23 23:45:49 | timeshift-btrfs/snapshots/2021-09-23_23-45-49/@\nFound snapshot: 2021-09-23 20:00:01 | timeshift-btrfs/snapshots/2021-09-23_20-00-01/@\nFound 8 snapshot(s)\nUnmount /tmp/grub-btrfs.7klMvGsPJP .. Success\nFound memtest86+ image: /boot/memtest86+/memtest.bin\ndone\n"
Exit #11: 0 QProcess::NormalExit
qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 1594, resource id: 12583854, major code: 40 (TranslateCoords), minor code: 0
Running GarudaBO cleanup code
╭─xxxx@xxxx in ~ took 1s
╰─λ sudo -E garuda-boot-options
QStandardPaths: runtime directory '/run/user/1000' is not owned by UID 0, but a directory permissions 0700 owned by UID 1000 GID 1000
Exec #1: "logname"
Exec #9: "grub-editenv /boot/grub/grubenv unset next_entry"
Exec #10: "update-grub"
SErr #10: "Generating grub configuration file ...\nFound theme: /usr/share/grub/themes/garuda-dr460nized/theme.txt\nFound linux image: /boot/vmlinuz-linux-zen\nFound initrd image: /boot/intel-ucode.img /boot/initramfs-linux-zen.img\nFound fallback initrd image(s) in /boot: intel-ucode.img initramfs-linux-zen-fallback.img\nFound linux image: /boot/vmlinuz-linux-lts\nFound initrd image: /boot/intel-ucode.img /boot/initramfs-linux-lts.img\nFound fallback initrd image(s) in /boot: intel-ucode.img initramfs-linux-lts-fallback.img\nFound linux image: /boot/vmlinuz-linux-cacule\nFound initrd image: /boot/intel-ucode.img /boot/initramfs-linux-cacule.img\nFound fallback initrd image(s) in /boot: intel-ucode.img initramfs-linux-cacule-fallback.img\nFound linux image: /boot/vmlinuz-linux\nFound initrd image: /boot/intel-ucode.img /boot/initramfs-linux.img\nFound fallback initrd image(s) in /boot: intel-ucode.img initramfs-linux-fallback.img\nWarning: os-prober will be executed to detect other bootable partitions.\nIts output will be used to detect bootable binaries on them and create new boot entries.\nAdding boot menu entry for UEFI Firmware Settings ...\nDetecting snapshots ...\nInfo: Separate boot partition not detected \nFound snapshot: 2021-09-25 22:15:29 | timeshift-btrfs/snapshots/2021-09-25_22-15-29/@\nFound snapshot: 2021-09-25 20:00:01 | timeshift-btrfs/snapshots/2021-09-25_20-00-01/@\nFound snapshot: 2021-09-24 20:00:01 | timeshift-btrfs/snapshots/2021-09-24_20-00-01/@\nFound snapshot: 2021-09-24 10:35:20 | timeshift-btrfs/snapshots/2021-09-24_10-35-20/@\nFound snapshot: 2021-09-24 08:04:44 | timeshift-btrfs/snapshots/2021-09-24_08-04-44/@\nFound snapshot: 2021-09-23 23:48:19 | timeshift-btrfs/snapshots/2021-09-23_23-48-19/@\nFound snapshot: 2021-09-23 23:45:49 | timeshift-btrfs/snapshots/2021-09-23_23-45-49/@\nFound snapshot: 2021-09-23 20:00:01 | timeshift-btrfs/snapshots/2021-09-23_20-00-01/@\nFound 8 snapshot(s)\nUnmount /tmp/grub-btrfs.piRL3Wf9vo .. Success\nFound memtest86+ image: /boot/memtest86+/memtest.bin\ndone\n"
╰─λ inxi -Fxzd
System: Kernel: 5.14.7-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0 Desktop: KDE Plasma 5.22.5 Distro: Garuda Linux
Machine: Type: Desktop System: Micro-Star product: MS-7C75 v: 2.0 serial: <filter>
Mobo: Micro-Star model: MPG Z490 GAMING PLUS (MS-7C75) v: 2.0 serial: <filter> UEFI: American Megatrends v: A.70
date: 04/20/2021
Battery: Device-1: hidpp_battery_0 model: Logitech K850 Performance Wireless Keyboard charge: 100% (should be ignored)
status: Discharging
Device-2: hidpp_battery_1 model: Logitech M585/M590 Multi-Device Mouse charge: 55% (should be ignored)
status: Discharging
CPU: Info: 6-Core model: Intel Core i5-10600K bits: 64 type: MT MCP arch: Comet Lake rev: 5 cache: L2: 12 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 98397
Speed: 4593 MHz min/max: 800/4800 MHz Core speeds (MHz): 1: 4593 2: 4706 3: 4556 4: 4789 5: 4688 6: 4556 7: 4593
8: 4747 9: 4789 10: 4803 11: 4749 12: 4757
Graphics: Device-1: NVIDIA GP108 [GeForce GT 1030] vendor: Micro-Star MSI driver: nvidia v: 470.74 bus-ID: 01:00.0
Device-2: Microsoft LifeCam Cinema type: USB driver: snd-usb-audio,uvcvideo bus-ID: 1-2.1.4:8
Display: x11 server: X.Org 1.20.13 driver: loaded: nvidia resolution: 2560x1080~60Hz
OpenGL: renderer: NVIDIA GeForce GT 1030/PCIe/SSE2 v: 4.6.0 NVIDIA 470.74 direct render: Yes
Audio: Device-1: Intel Comet Lake PCH cAVS vendor: Micro-Star MSI driver: snd_hda_intel v: kernel bus-ID: 00:1f.3
Device-2: NVIDIA GP108 High Definition Audio vendor: Micro-Star MSI driver: snd_hda_intel v: kernel bus-ID: 01:00.1
Device-3: Microsoft LifeCam Cinema type: USB driver: snd-usb-audio,uvcvideo bus-ID: 1-2.1.4:8
Device-4: Pyle USB Sound Card Pyle USB Sound Card type: USB driver: hid-generic,snd-usb-audio,usbhid
bus-ID: 1-2.2:6
Sound Server-1: ALSA v: k5.14.7-zen1-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.37 running: yes
Network: Device-1: Realtek RTL8125 2.5GbE vendor: Micro-Star MSI driver: r8169 v: kernel port: 3000 bus-ID: 03:00.0
Drives: Local Storage: total: 931.51 GiB used: 24.36 GiB (2.6%)
ID-1: /dev/sda vendor: Western Digital model: WDS100T2B0B-00YS70 size: 931.51 GiB
Message: No optical or floppy data found.
Partition: ID-1: / size: 931.26 GiB used: 24.36 GiB (2.6%) fs: btrfs dev: /dev/sda2
ID-2: /boot/efi size: 256 MiB used: 562 KiB (0.2%) fs: vfat dev: /dev/sda1
ID-3: /home size: 931.26 GiB used: 24.36 GiB (2.6%) fs: btrfs dev: /dev/sda2
ID-4: /var/log size: 931.26 GiB used: 24.36 GiB (2.6%) fs: btrfs dev: /dev/sda2
ID-5: /var/tmp size: 931.26 GiB used: 24.36 GiB (2.6%) fs: btrfs dev: /dev/sda2
Swap: ID-1: swap-1 type: zram size: 15.55 GiB used: 0 KiB (0.0%) dev: /dev/zram0
Sensors: System Temperatures: cpu: 34.0 C mobo: N/A gpu: nvidia temp: 48 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 38%
Info: Processes: 355 Uptime: 17m Memory: 15.55 GiB used: 3.38 GiB (21.7%) Init: systemd Compilers: gcc: 11.1.0
Packages: 2010 Shell: fish v: 3.3.1 inxi: 3.3.06
PS bonus question, is the default shell bash now? This is a fresh install and I think the previous install was fish default. Thanks!
