Kernel: 6.0.12-1-bore arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-bore
root=UUID=541682ad-7c99-4d5b-8c70-e576d1fc9479 rw rootflags=subvol=@
loglevel=3 ibt=off
Type: Laptop System: HP product: HP Laptop 14-bs0xx v: Type1ProductConfigId
Mobo: HP model: 831E v: 17.42 serial: <superuser required> UEFI: Insyde
v: F.48 date: 06/16/2020
ID-1: BAT0 charge: 35.5 Wh (92.7%) condition: 38.3/38.3 Wh (100.0%)
volts: 15.8 min: 14.6 model: HP Primary type: Li-ion serial: N/A
Info: model: Intel Core i3-7020U bits: 64 type: MT MCP arch: Coffee Lake
gen: core 7 level: v3 note: check built: 2017 process: Intel 14nm family: 6
model-id: 0x8E (142) stepping: 0xA (10) microcode: 0xF0
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 2187 high: 2300 min/max: 400/2300 scaling:
driver: intel_pstate governor: powersave cores: 1: 2300 2: 2300 3: 2241
4: 1910 bogomips: 18416
PBRSB-eIBRS: Not affected
Device-1: Intel HD Graphics 620 vendor: Hewlett-Packard driver: i915
active: eDP-1 empty: DP-1,HDMI-A-1,HDMI-A-2 bus-ID: 00:02.0
Device-2: Cheng Uei Precision Industry (Foxlink) HP TrueVision HD Camera
type: USB driver: uvcvideo bus-ID: 1-3:2 chip-ID: 05c8:03ac class-ID: 0e02
s-diag: 414mm (16.31")
Monitor-1: eDP-1 model: AU Optronics 0x2d3c built: 2015 res: 1366x768
ratio: 16:9 modes: 1366x768
API: OpenGL v: 4.6 Mesa 22.3.1 renderer: Mesa Intel HD Graphics 620 (KBL
GT2) direct render: Yes
Sound API: ALSA v: k6.0.12-1-bore running: yes
lanes: 1 port: 4000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Realtek RTL8723DE 802.11b/g/n PCIe Adapter
vendor: Hewlett-Packard driver: rtw_8723de v: N/A modules: rtw88_8723de
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 03:00.0
chip-ID: 10ec:d723 class-ID: 0280
Device-1: Realtek Bluetooth 4.2 Adapter type: USB driver: btusb v: 0.8
bus-ID: 1-7:4 chip-ID: 0bda:b009 class-ID: e001 serial: <filter>
Local Storage: total: 223.57 GiB used: 15.21 GiB (6.8%)
model: WDS240G2G0B-00EPW0 size: 223.57 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 0400
used: 15.21 GiB (6.8%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-1: swap-1 type: zram size: 3.72 GiB used: 193 MiB (5.1%) priority: 100
System Temperatures: cpu: 48.0 C pch: 40.5 C mobo: N/A
Processes: 223 Uptime: 22m wakeups: 1 Memory: 3.72 GiB
used: 2.71 GiB (73.0%) Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.0 Packages: pm: pacman pkgs: 1258
libs: 319 tools: gnome-software,octopi,paru Shell: fish v: 3.5.1
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.24
Garuda (2.6.12-1):
System install date: 2022-12-21
Last full system update: 2022-12-25
recently after update the default kernal hangs after booting and i have found the bore kernal is stable im a newbie and am trying out garuda after switching from mint then pop.
I have looked at this forum who sorta gets the problem but i’d like a more step by step guide as to where and what to edit…
im sorry for the inconvenience but id really appreciate the support
here is the link to the forum
