Can't reinstall packages using Garuda Assistant
I am reinstalling all the packages using the button in the Garuda Assistant.
But when I get an error regarding the signature being invalid?
zvbi-0.2.41-1  zxing-cpp-2.0.0-2  zziplib-0.13.72-2
Total Download Size:     822,48 MiB
Total Installed Size:  24394,73 MiB
Net Upgrade Size:          2,65 MiB
:: Retrieving packages...
ttf-google-fonts-git-1:r5411.0bd...   822,5 MiB  21,8 MiB/s 00:38 [------------------------------------] 100%
(1990/1990) checking keys in keyring                               [------------------------------------] 100%
(1990/1990) checking package integrity                             [------------------------------------] 100%
error: pamac-aur: signature from "Nico Jensch (Chaotic-AUR) <dr460nf1r3@garudalinux.org>" is invalid
:: File /var/cache/pacman/pkg/pamac-aur-10.5.1-2-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package(PGP signature)).
I’ve already looked at this thread:
garuda-inxi:
  Kernel: 6.3.5-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
    root=UUID=f421b3e9-feb7-49ce-885d-088d8fed2dde rw rootflags=subvol=@
    loglevel=3 module_blacklist=hid_sensor_hub nvme.noacpi=1 ibt=off
  Desktop: KDE Plasma v: 5.27.5 tk: Qt v: 5.15.9 wm: kwin_wayland vt: 2
  Type: Laptop System: Framework product: Laptop (12th Gen Intel Core) v: A4
  Mobo: Framework model: FRANMACP04 v: A4 serial: <superuser required>
    UEFI: INSYDE v: 03.05 date: 08/23/2022
  ID-1: BAT1 charge: 21.8 Wh (43.1%) condition: 50.6/55.0 Wh (92.0%)
    volts: 15.6 min: 15.4 model: NVT Framewo type: Li-ion serial: <filter>
    status: charging cycles: 47
  Device-1: hidpp_battery_0 model: Logitech Wireless Mouse MX Master
  Info: model: 12th Gen Intel Core i5-1240P bits: 64 type: MST AMCP
    arch: Alder Lake level: v3 note: check built: 2021+
    microcode: 0x42A
  Topology: cpus: 1x cores: 12 mt: 4 tpc: 2 st: 8 threads: 16 smt: enabled
    cache: L1: 1.1 MiB desc: d-8x32 KiB, 4x48 KiB; i-4x32 KiB, 8x64 KiB
    L2: 9 MiB desc: 4x1.2 MiB, 2x2 MiB L3: 12 MiB desc: 1x12 MiB
  Speed (MHz): avg: 1905 high: 2670 min/max: 400/4400:3300 scaling:
    driver: intel_pstate governor: powersave cores: 1: 2217 2: 2100 3: 1926
    4: 2100 5: 400 6: 942 7: 2100 8: 2100 9: 2670 10: 2100 11: 2100 12: 2100
    13: 1329 14: 2100 15: 2100 16: 2100 bogomips: 67584
  Device-1: Intel Alder Lake-P Integrated Graphics driver: i915 v: kernel
    arch: Gen-12.2 process: Intel 10nm built: 2021-22+ ports: active: eDP-1
    empty: DP-1, DP-2, DP-3, DP-4 bus-ID: 00:02.0 chip-ID: 8086:46a6
  Display: wayland server: X.org v: 1.21.1.8 with: Xwayland v: 23.1.1
  Monitor-1: eDP-1 res: 2256x1504 size: N/A modes: N/A
  API: OpenGL v: 4.6 Mesa 23.1.1 renderer: Mesa Intel Graphics (ADL GT2)
    direct-render: Yes
  Device-1: Intel Alder Lake PCH-P High Definition Audio driver: snd_hda_intel
    chip-ID: 8086:51c8 class-ID: 0403
  API: ALSA v: k6.3.5-zen1-1-zen status: kernel-api tools: N/A
    pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: a6:00.0 chip-ID: 8086:2725
  IF: wlp166s0 state: up mac: <filter>
  IF-ID-2: tailscale0 state: unknown speed: -1 duplex: full mac: N/A
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:3 chip-ID: 8087:0032
  Local Storage: total: 1.82 TiB used: 109.82 GiB (5.9%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO 2TB
    lanes: 4 tech: SSD serial: <filter> fw-rev: 5B2QGXA7 temp: 53.9 C
  ID-1: / raw-size: 177.08 GiB size: 177.08 GiB (100.00%)
    used: 109.82 GiB (62.0%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:5
  ID-2: /boot/efi raw-size: 2 GiB size: 2 GiB (99.80%) used: 576 KiB (0.0%)
    fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
  ID-3: /home raw-size: 177.08 GiB size: 177.08 GiB (100.00%)
  ID-4: /var/log raw-size: 177.08 GiB size: 177.08 GiB (100.00%)
  ID-5: /var/tmp raw-size: 177.08 GiB size: 177.08 GiB (100.00%)
  ID-1: swap-1 type: zram size: 31.06 GiB used: 0 KiB (0.0%) priority: 100
  System Temperatures: cpu: 67.0 C mobo: N/A
  Processes: 413 Uptime: 22m wakeups: 7109 Memory: available: 31.06 GiB
  used: 10.44 GiB (33.6%) Init: systemd v: 253 default: graphical
  tool: systemctl Compilers: gcc: 13.1.1 clang: 15.0.7 Packages: 2012
  pm: pacman pkgs: 2003 libs: 432 tools: gnome-software,octopi,pamac,paru
  pm: rpm pkgs: 0 pm: flatpak pkgs: 9 Shell: fish v: 3.6.1 default: Bash
  v: 5.1.16 running-in: konsole inxi: 3.3.27
  System install date:     2023-05-04
  Last full system update: 2023-06-02
Saw this Setup Assistant errors out "Invalid sigantures from Nico Jensch"
but that's fixed supposedly?
Seems like running garuda-update remote keyring has fixed it.
But now I'm getting this error. which is weird cause I don't have ttf-carlito installed
...xorg-xdpyinfo-1.3.4-1  xorg-xeyes-1.2.0-1  xorg-xhost-1.0.9-1  xorg-xinit-1.4.2-1
xorg-xinput-1.6.4-1  xorg-xkbcomp-1.4.6-1  xorg-xmessage-1.0.6-1  xorg-xmodmap-1.0.11-1
xorg-xprop-1.2.6-1  xorg-xrandr-1.5.2-1  xorg-xrdb-1.2.1-1  xorg-xset-1.2.5-1
xorg-xsetroot-1.1.3-1  xorg-xwayland-23.1.1-1  xorg-xwininfo-1.1.6-1  xorgproto-2022.2-1
xournalpp-1.1.3-1  xsel-1.2.1-1  xvidcore-1.3.7-2  xxhash-0.8.1-4  xz-5.4.3-1  yad-12.3-1
yajl-2.1.0-5  yaml-cpp-0.7.0-2  yasm-1.3.0-6  yelp-tools-42.1-1  yelp-xsl-42.1-1
yt-dlp-2023.03.04-2  zbar-0.23.90-3  zeromq-4.3.4-3  zimg-3.0.4-1  zip-3.0-10
zita-convolver-4.0.3-3  zlib-1:1.2.13-2  zoom-5.14.7-1  zram-generator-1.1.2-1  zstd-1.5.5-1
Net Upgrade Size:          2,63 MiB
(1990/1990) loading package files                                  [------------------------------------] 100%
(1990/1990) checking for file conflicts                            [------------------------------------] 100%
/usr/share/fonts/carlito/Carlito-Bold.ttf exists in both 'ttf-google-fonts-git' and 'ttf-carlito'
/usr/share/fonts/carlito/Carlito-BoldItalic.ttf exists in both 'ttf-google-fonts-git' and 'ttf-carlito'
/usr/share/fonts/carlito/Carlito-Italic.ttf exists in both 'ttf-google-fonts-git' and 'ttf-carlito'
/usr/share/fonts/carlito/Carlito-Regular.ttf exists in both 'ttf-google-fonts-git' and 'ttf-carlito'
Press enter to exit
I recall reading about it some time ago: Conflicts between font packages - Garuda Setup Assistant.
I thought that was sorted out but apparently not.
Ah yeah, that thread is exactly my problem.
What confuses me is that I don't have ttf-carlito installed.
Does the garuda assistant somehow try to install ttf-carlito as a dependency from some other package?
I think so.
Yeah, afaik it is. It finally worked for me, at least. Your mileage may vary?
