Can't mount hard drive after system crash
Hello.
My system crashed because I have accidentally overloaded ram and cpu, I restarted my system and my second drive is detected but not mountable, here is the error message:
An error occurred while accessing 'Home', the system responded: The requested operation has failed: Error mounting /dev/sda2 at /run/media/res0nance/Data: wrong fs type, bad option, bad superblock on /dev/sda2, missing codepage or helper program, or other error
How to do it?
What did your Whoogle search on the ERROR DESCRIPTION yield?
You can not post your garuda-inxi?
Not even from the live ISO?
Please don't say NTFS.
After you fix your drive issue you should really assess what yielded in your crash so you will know how not to reproduce it. :slight_smile: Personally I am very interested in knowing what happened so that the RAM and CPU overloaded and made your system crash, I would want to learn from your [bad] experience.
Just had too many things open and I think that nohang killed a vital process because I still haven't configured it yet.
I searched and it led me to a unix stack exchange ubuntu issue without a fix.
Here is the garuda-inxi:
Device-1: Intel CoffeeLake-S GT2 [UHD Graphics 630] driver: i915 v: kernel
Device-2: NVIDIA GP107 [GeForce GTX 1050 Ti] driver: nvidia v: 510.54
Display: x11 server: X.Org v: 1.21.1.3 driver: X: loaded: intel,nvidia
unloaded: modesetting,nouveau gpu: i915,nvidia resolution: 1920x1080
OpenGL: renderer: NVIDIA GeForce GTX 1050 Ti/PCIe/SSE2
v: 4.6.0 NVIDIA 510.54
Device-1: Intel Cannon Lake PCH cAVS driver: snd_hda_intel
Device-2: NVIDIA GP107GL High Definition Audio driver: snd_hda_intel
Device-3: Razer USA RZ19-0229 Gaming Microphone type: USB
Sound Server-2: PipeWire v: 0.3.48 running: yes
╭─[email protected] in ~ took 335ms
╰─λ man inxi
╭─[email protected] in ~ took 4s
╰─λ inxi -A -G
╭─[email protected] in ~ took 304ms
╰─λ garuda-inxi
Kernel: 5.16.16-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=a5e2e2df-0d5c-4bb8-b258-cf884294fc62 rw [email protected]
Desktop: KDE Plasma v: 5.24.3 tk: Qt v: 5.15.3 info: latte-dock
Type: Desktop System: LENOVO product: 90JL00KTIX v: Legion T530-28ICB
serial: Chassis: type: 3 serial:
Mobo: LENOVO model: 36E7 v: SDK0J40700 WIN 3258131453720
serial: UEFI: LENOVO v: O3LKT17A date: 10/23/2018
Info: model: Intel Core i5-8400 bits: 64 type: MCP arch: Coffee Lake
family: 6 model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xEC
Topology: cpus: 1x cores: 6 smt: cache: L1: 384 KiB
desc: 1x9 MiB
Speed (MHz): avg: 3870 high: 3993 min/max: 800/4000 scaling:
driver: intel_pstate governor: performance cores: 1: 3993 2: 3987 3: 3898
4: 3933 5: 3480 6: 3930 bogomips: 33599
Type: l1tf
STIBP: disabled, RSB filling
Device-1: Intel CoffeeLake-S GT2 [UHD Graphics 630] vendor: Lenovo
driver: i915 v: kernel ports: active: none empty: HDMI-A-1 bus-ID: 00:02.0
chip-ID: 8086:3e92 class-ID: 0380
Device-2: NVIDIA GP107 [GeForce GTX 1050 Ti] vendor: Micro-Star MSI
driver: nvidia v: 510.54 alternate: nouveau,nvidia_drm pcie: gen: 3
speed: 8 GT/s lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:1c82 class-ID: 0300
loaded: intel,nvidia unloaded: modesetting,nouveau alternate: fbdev,nv,vesa
gpu: i915,nvidia display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 81 s-size: 602x343mm (23.70x13.50")
s-diag: 693mm (27.28")
Monitor-1: DP-0 res: 1920x1080 dpi: 82 size: 598x336mm (23.54x13.23")
diag: 686mm (27.01") modes: N/A
v: 4.6.0 NVIDIA 510.54 direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: Lenovo driver: snd_hda_intel
Device-2: NVIDIA GP107GL High Definition Audio vendor: Micro-Star MSI
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-4:4 chip-ID: 1532:0511
class-ID: 0300 serial:
Device-1: Intel Dual Band Wireless-AC 3165 Plus Bluetooth driver: iwlwifi
chip-ID: 8086:3166 class-ID: 0280
IF: wlp3s0 state: up mac:
vendor: Lenovo driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: 3000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp4s0 state: down mac:
bus-ID: 1-14:6 chip-ID: 8087:0a2a class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 0 state: up address:
Local Storage: total: 1.03 TiB used: 52.66 GiB (5.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix
model: HFM128GDHTNG-8310B size: 119.24 GiB block-size: physical: 512 B
logical: 512 B speed: 15.8 Gb/s lanes: 2 type: SSD serial:
rev: 80070C00 temp: 38.9 C scheme: GPT
model: WD10EZEX-08WN4A0 size: 931.51 GiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 7200 serial:
rev: 1A02 scheme: GPT
ID-1: / raw-size: 118.95 GiB size: 118.95 GiB (100.00%)
used: 52.66 GiB (44.3%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 118.95 GiB size: 118.95 GiB (100.00%)
ID-4: /var/log raw-size: 118.95 GiB size: 118.95 GiB (100.00%)
ID-5: /var/tmp raw-size: 118.95 GiB size: 118.95 GiB (100.00%)
ID-1: swap-1 type: zram size: 7.64 GiB used: 2.5 MiB (0.0%) priority: 100
System Temperatures: cpu: 27.8 C pch: 59.0 C mobo: N/A gpu: nvidia
temp: 53 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 29%
Processes: 259 Uptime: 10m wakeups: 0 Memory: 7.64 GiB
used: 2.71 GiB (35.5%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 Packages: 1790 pacman: 1783 lib: 538 flatpak: 7 Shell: fish
v: 3.3.1 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.14
Garuda (2.5.6-2):
System install date: 2022-03-23
Last full system update: 2022-03-26
I will try the live one rn.
Edit: The live USB is stuck on boot so I can't check.
Try mounting the NTFS drive in fstab using the ntfs-3g flag.
see my example below:
UUID=7C1A71921A714A62 /mnt/7C1A71921A714A62 ntfs-3g nofail,noatime,rw,user,uid=1000,gid=1000,dmask=022,fmask=133,windows_names,auto 0 0
Obviously, you need to substitute your drives UUID in my example.
Mounting using ntfs-3g flag in /etc/fstab appears to work.
man fstab
Be sure to copy a backup of fstab before editing:
sudo cp /etc/fstab  /etc/fstab.bak
I'm sorry, I didn't understand what command to run.
https://wiki.archlinux.org/title/fstab
https://wiki.archlinux.org/title/NTFS-3G
Linux fstab mount drive ntfs-3g
man fstab
If you are using an NTFS drive and it will not mount, then install the ntfs-3g package if it is not already installed. If you are not comfortable modifying fstab, then you can mount the drive manually.
You can use a command similar to below to mount your NTFS drive:
sudo mount -t ntfs-3g /dev/sdXY /mnt/ntfs-junk
You can use the command sudo blkid -o list to find your NTFS drive's designation to substitute for "XY" in the above command. Please post the output of the blkid -o list command.
Then substitute your NTFS drive's designation into the command. For example if your NTFS drive is sda1 then the command to use would be:
sudo mount -t ntfs-3g /dev/sda1 /mnt/ntfs-junk
YMMV, but you at least won't need to modify fstab to try mounting your NTFS drive this way. If the drive you are having issues accessing is not formatted as NTFS then you can disregard all my prior posts.
Alright, I tried executing
sudo mount -t ntfs-3g /dev/sda2 /mnt/4E92D99992D9863D
But the terminal replied with:
mount: /mnt/4E92D99992D9863D: mount point does not exist.
I also tried to run what you asked me to do before:
UUID=4E92D99992D9863D /mnt/4E92D99992D9863D ntfs-3g nofail,noatime,rw,user,uid=1000,gid=1000,dmask=022,fmask=133,window-names,auto 0 0
And the terminal replied with
find-the-command: "/mnt/4E92D99992D9863D" is not found locally, searching in repositories...
error: No repo files found. Please run `pkgfile --update'.
find-the-command: command not found: /mnt/4E92D99992D9863D
fish:
You do not run this command. It is a load line for your drive that must be added to /etc/fstab. Unfortunately, this will likely not work as well if the mount command didn't.
You should try to correct the drives errors in Windows. If that doesn't work, your last option is to use testdisk to repair the partition tables or recover any data you require.
You still have not posted your full drive information from the above command. Your damaged drive may or may not show up with this command, but it would be good to have the output posted.
Oh sorry I forgot to add that, here is the drive that i can't mount.
/dev/sda2 ntfs Data (not mounted) 4E92D99992D9863D
While is is the full output
device fs_type label mount point UUID
/dev/nvme0n1p2 btrfs (in use) a5e2e2df-0d5c-4bb8-b258-cf884294fc62
/dev/nvme0n1p1 vfat NO_LABEL /boot/efi 7964-EEA5
/dev/sda1 (not mounted)
/dev/zram0 swap zram0 [SWAP] e9a4b78d-b535-4b2c-a8fa-46835c455b79
The mount command didn't work because you tried mounting to a non-existing directory. Try this
sudo mkdir /mnt/ntfs-broken
sudo mount -t ntfs-3g /dev/sda2 /mnt/ntfs-broken
The terminal replied with
mount: /mnt/4E92D99992D9863D: unknown filesystem type 'ntfs-3g'.
Did you install the ntfs-3g package?
sudo pacman -S ntfs-3g
Post input & output please.
[sudo] password for res0nance:
resolving dependencies...
:: ntfs-3g and ntfsprogs-ntfs3 are in conflict (ntfsprogs). Remove ntfsprogs-ntfs3? [y/N] y
Packages (2) ntfsprogs-ntfs3-2021.8.22-9 [removal]  ntfs-3g-2021.8.22-1
Total Download Size:   0,54 MiB
Total Installed Size:  1,76 MiB
Net Upgrade Size:      0,22 MiB
:: Retrieving packages...
ntfs-3g-2021.8.22-1-x86_64            557,4 KiB  1363 KiB/s 00:00 [------------------------------------] 100%
(1/1) checking keys in keyring                                     [------------------------------------] 100%
(1/1) checking package integrity                                   [------------------------------------] 100%
(1/1) loading package files                                        [------------------------------------] 100%
(1/1) checking for file conflicts                                  [------------------------------------] 100%
(2/2) checking available disk space                                [------------------------------------] 100%
==> root: 33
(1/1) removing ntfsprogs-ntfs3                                     [------------------------------------] 100%
(1/1) installing ntfs-3g                                           [------------------------------------] 100%
(1/7) Reloading device manager configuration...
(2/7) Arming ConditionNeedsUpdate...
(3/7) Foreign/AUR package notification
=> No foreign/AUR packages found.
(4/7) Orphaned package notification...
nm-connection-editor 1.26.0-1
(5/7) Checking for .pacnew and .pacsave files...
.pac* files found:
/etc/paru.conf.pacnew
Please check and merge
(6/7) Performing snapper post snapshots for the following configurations...
==> root: 34
(7/7) Syncing all file systems...
Try again this:
Executing the first command makes the terminal reply by telling me that the directory already exists: mkdir: cannot create directory ā€˜/mnt/4E92D99992D9863D’: File exists
While the second command leads to this error message:
$MFTMirr does not match $MFT (record 3).
Failed to mount '/dev/sda2': Input/output error
NTFS is either inconsistent, or there is a hardware fault, or it's a
SoftRAID/FakeRAID hardware. In the first case run chkdsk /f on Windows
then reboot into Windows twice. The usage of the /f parameter is very
important! If the device is a SoftRAID/FakeRAID then first activate
it and mount a different device under the /dev/mapper/ directory, (e.g.
/dev/mapper/nvidia_eahaabcc1). Please see the 'dmraid' documentation
for more details
Why does the response ask me to boot into windows and run a command on there, is there any way to do it without windows?
It looks like there isn't. But you can run the mentioned command from an install/recovery media so having Windows installed is not necessary.
