You can try ntfsfix–kind of a hail mary, to be fair. If it doesn’t work you’ll need to fix it on a Windows box.
Give it a shot, paste the output here in the thread.
sudo ntfsfix /dev/sda2
Thanks for the answer, but where do I get it?
The Windows Store, of course. This is Linux, and ntfsfix is a command.
Type 'man ntfsfix' in a terminal and it will tell you the usage.
You already have ntfsfix. My understanding is it is part of the ntfs-3g package you already installed. Go ahead and try to run it.
Thanks! I have ran the previous command and now I can mount it properly.
