Hello all,
I am a total newbie to Linux but I have not been able to find a forum post or wiki resource to help me with my Dell XPS 13 not being able to even detect my bluetooth headphones. My laptop can recognized other devices, it works with my dualshock 3 but none of my headphones. Any help or resource is appreciated.
Kernel: 5.14.16-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=44a32cbf-aba4-4b1d-94a4-86b5d4a46482
Desktop: KDE Plasma 5.23.3 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Machine: Type: Laptop System: Dell product: XPS 13 9343 v: N/A serial: <filter> Chassis: type: 9
Mobo: Dell model: 0TM99H v: A00 serial: <filter> UEFI: Dell v: A20 date: 06/06/2019
Battery: ID-1: BAT0 charge: 13.7 Wh (59.1%) condition: 23.2/52.7 Wh (44.1%) volts: 7.5 min: 7.6
model: SMP DELL RWT1R43 type: Li-poly serial: <filter> status: Discharging
CPU: Info: Dual Core model: Intel Core i5-5200U bits: 64 type: MT MCP arch: Broadwell family: 6
model-id: 3D (61) stepping: 4 microcode: 2F cache: L2: 3 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 17558
Speed: 2195 MHz min/max: 500/2700 MHz Core speeds (MHz): 1: 2195 2: 2195 3: 2211 4: 2195
Graphics: Device-1: Intel HD Graphics 5500 vendor: Dell driver: i915 v: kernel bus-ID: 00:02.0
chip-ID: 8086:1616 class-ID: 0300
Device-2: Realtek Integrated_Webcam_HD type: USB driver: uvcvideo bus-ID: 2-5:3
chip-ID: 0bda:5682 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org 1.21.1.1 compositor: kwin_x11 driver: loaded: intel
Screen-1: 0 s-res: 1920x1080 s-dpi: 168 s-size: 290x170mm (11.4x6.7") s-diag: 336mm (13.2")
Monitor-1: eDP1 res: 1920x1080 dpi: 168 size: 290x170mm (11.4x6.7") diag: 336mm (13.2")
OpenGL: renderer: Mesa Intel HD Graphics 5500 (BDW GT2) v: 4.6 Mesa 21.2.4 direct render: Yes
Audio: Device-1: Intel Broadwell-U Audio vendor: Dell driver: snd_hda_intel v: kernel bus-ID: 00:03.0
chip-ID: 8086:160c class-ID: 0403
Device-2: Intel Wildcat Point-LP High Definition Audio vendor: Dell driver: snd_hda_intel
v: kernel bus-ID: 00:1b.0 chip-ID: 8086:9ca0 class-ID: 0403
Sound Server-1: ALSA v: k5.14.16-zen1-1-zen running: yes
Network: Device-1: Broadcom BCM4352 802.11ac Wireless Network Adapter vendor: Dell driver: wl v: kernel
modules: bcma bus-ID: 02:00.0 chip-ID: 14e4:43b1 class-ID: 0280
Bluetooth: Device-1: Broadcom BCM20702A0 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 2-3:2
chip-ID: 0a5c:216f class-ID: fe01 serial: <filter>
Drives: Local Storage: total: 238.47 GiB used: 38.49 GiB (16.1%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD PM851 M.2 2280 256GB size: 238.47 GiB
block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 5D0Q
Partition: ID-1: / raw-size: 238.21 GiB size: 238.21 GiB (100.00%) used: 38.49 GiB (16.2%) fs: btrfs
dev: /dev/sda2 maj-min: 8:2
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.45%) used: 562 KiB (0.2%) fs: vfat
dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 238.21 GiB size: 238.21 GiB (100.00%) used: 38.49 GiB (16.2%) fs: btrfs
ID-4: /var/log raw-size: 238.21 GiB size: 238.21 GiB (100.00%) used: 38.49 GiB (16.2%)
ID-5: /var/tmp raw-size: 238.21 GiB size: 238.21 GiB (100.00%) used: 38.49 GiB (16.2%)
ID-1: swap-1 type: zram size: 7.67 GiB used: 2 MiB (0.0%) priority: 100 dev: /dev/zram0
Sensors: System Temperatures: cpu: 65.0 C mobo: 46.0 C sodimm: SODIMM C
Fan Speeds (RPM): cpu: 0
Info: Processes: 207 Uptime: 5m wakeups: 1 Memory: 7.67 GiB used: 2.84 GiB (37.0%) Init: systemd
v: 249 tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: pacman: 1442 lib: 444
