Sorry if this has been asked before but i’ve searched through the forums and have found nothing that has worked in my use case.
I currently have a 2 Monitor set-up (HDMI-2-A (VERTICAL), DP-3 (LANDSCAPE)) and would like for sddm to only appear on my main monitor (DP-3)
I’ve tried the basic apply plasma settings to sddm after disabling monitor, tried Xsetup in a number of different ways but to no avail. Tried disabling integrated graphics on the off chance that it was a weird Nvidia driver issue but nope.
Was hoping someone could give me a hand or point me in the right direction with this.
Thanks!
GARUDA-INXI
Kernel: 6.17.9-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
root=UUID=9d512a78-1a5d-4d0f-ba9e-8de2d43b986d rw rootflags=subvol=@ ...
acpi_enforce_resources=lax quiet loglevel=3
Desktop: KDE Plasma v: 6.5.4 tk: Qt v: N/A info: frameworks v: 6.20.0
Type: Desktop Mobo: Gigabyte model: B650M AORUS ELITE AX v: x.x
serial: <superuser required> uuid: <superuser required> Firmware: UEFI
vendor: American Megatrends LLC. v: F33 date: 03/12/2025
Info: model: AMD Ryzen 7 9800X3D bits: 64 type: MCP arch: Zen 5 gen: 5
level: v4 note: check built: 2024+ process: TSMC n4 (4nm) family: 0x1A (26)
model-id: 0x44 (68) stepping: 0 microcode: 0xB404023
Topology: cpus: 1x dies: 1 clusters: 1 cores: 8 smt: <unsupported> cache:
L1: 640 KiB desc: d-8x48 KiB; i-8x32 KiB L2: 8 MiB desc: 8x1024 KiB
L3: 96 MiB desc: 1x96 MiB
Speed (MHz): avg: 5188 min/max: 603/5272 boost: enabled scaling:
driver: amd-pstate-epp governor: performance cores: 1: 5188 2: 5188 3: 5188
4: 5188 5: 5188 6: 5188 7: 5188 8: 5188 bogomips: 75054
ssse3 svm
Device-1: NVIDIA GA102 [GeForce RTX 3080 Ti] vendor: Gigabyte driver: nvidia
v: 580.105.08 alternate: nouveau,nvidia_drm non-free: 550-580.xx+
status: current (as of 2025-11; EOL~2026-12-xx) arch: Ampere code: GAxxx
lanes: 16 ports: active: DP-3,HDMI-A-2 empty: DP-1,DP-2,HDMI-A-1
bus-ID: 01:00.0 chip-ID: 10de:2208 class-ID: 0300
Device-2: Elgato Systems GmbH Game Capture HD60 S+
driver: hid-generic,snd-usb-audio,usbhid,uvcvideo type: USB rev: 2.1
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 7-1.1:3 chip-ID: 0fd9:006b
Device-3: Razer USA Kiyo Pro driver: snd-usb-audio,uvcvideo type: USB
rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 7-1.2.1.1:7
chip-ID: 1532:0e05 class-ID: 0102
alternate: fbdev,nouveau,nv,vesa gpu: nv_platform,nvidia,nvidia-nvswitch
d-rect: 5360x2520 display-ID: 0
Monitor-1: DP-3 pos: bottom-l model: Samsung Odyssey G85SB
serial: <filter> built: 2022 res: mode: 3440x1440 hz: 175 scale: 100% (1)
dpi: 108 gamma: 1.2 size: 810x350mm (31.85x13.94") diag: 883mm (34.8")
modes: max: 3440x1440 min: 640x480
Monitor-2: HDMI-A-2 pos: top-right model: AOC 27B2 serial: <filter>
built: 2021 res: mode: 1920x1080 hz: 60 scale: 178% (1.78) to: 1080x1920
dpi: 82 gamma: 1.2 size: 598x336mm (23.54x13.23") diag: 686mm (27")
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 580.105.08
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 3080 Ti/PCIe/SSE2
API: Vulkan v: 1.4.328 layers: 19 device: 0 type: discrete-gpu name: NVIDIA
GeForce RTX 3080 Ti driver: nvidia v: 580.105.08 device-ID: 10de:2208
surfaces: N/A device: 1 type: cpu name: llvmpipe (LLVM 21.1.6 256 bits)
driver: mesa llvmpipe v: 25.3.1-arch1.2 (LLVM 21.1.6)
de: kscreen-console,kscreen-doctor gpu: corectrl,nvidia-smi
wl: wayland-info,wlr-randr x11: xdpyinfo, xprop, xrandr
Device-1: NVIDIA GA102 High Definition Audio vendor: Gigabyte
Device-2: Advanced Micro Devices [AMD] Ryzen HD Audio vendor: Gigabyte
bus-ID: 10:00.6 chip-ID: 1022:15e3 class-ID: 0403
Device-3: Elgato Systems GmbH Game Capture HD60 S+
Device-4: Razer USA Kiyo Pro driver: snd-usb-audio,uvcvideo type: USB
Device-5: Audio-Technica AT2020USB+
lanes: 1 mode: 1.1 bus-ID: 7-1.2.1.2:8 chip-ID: 0909:001c class-ID: 0300
API: ALSA v: k6.17.9-zen1-1-zen status: kernel-api with: aoss
Device-1: Realtek RTL8852CE PCIe 802.11ax Wireless Network
port: e000 bus-ID: 07:00.0 chip-ID: 10ec:c852 class-ID: 0280
IF: wlp7s0 state: down mac: <filter>
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: d000 bus-ID: 08:00.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-6:3 chip-ID: 0bda:0852
Local Storage: total: 3.68 TiB used: 241.52 GiB (6.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SKC3000D2048G
size: 1.86 TiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: EIFK51.2 temp: 48.9 C
ID-2: /dev/sda maj-min: 8:0 vendor: Crucial model: CT2000MX500SSD1
tech: SSD serial: <filter> fw-rev: 043 scheme: GPT
ID-1: / raw-size: 1.41 TiB size: 1.41 TiB (100.00%) used: 96.32 GiB (6.7%)
fs: btrfs dev: /dev/nvme0n1p6 maj-min: 259:6
used: 31.5 MiB (32.9%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 1.41 TiB size: 1.41 TiB (100.00%)
used: 96.32 GiB (6.7%) fs: btrfs dev: /dev/nvme0n1p6 maj-min: 259:6
ID-4: /var/log raw-size: 1.41 TiB size: 1.41 TiB (100.00%)
ID-5: /var/tmp raw-size: 1.41 TiB size: 1.41 TiB (100.00%)
ID-1: swap-1 type: zram size: 30.95 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 48.1 C mobo: 40.5 C
Memory: total: 32 GiB note: est. available: 30.95 GiB used: 5.2 GiB (16.8%)
Processes: 344 Power: uptime: 26m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.33 GiB services: org_kde_powerdevil,
Packages: 1912 pm: pacman pkgs: 1903 libs: 500 tools: octopi,pamac,paru
pm: flatpak pkgs: 9 Compilers: clang: 21.1.6 gcc: 15.2.1 Shell: Bash
v: 5.3.8 default: fish v: 4.2.1 running-in: konsole inxi: 3.3.40
Garuda (2.11.1-1):
System install date: 2025-11-20
Garuda release: 251103
Last full system update: 2025-12-10
Relevant software: snapper NetworkManager dracut nvidia-utils nvidia-open-dkms garuda-hardware-profile-nvidia garuda-hardware-profile-standard
25/26 checks run in 0.40 seconds ⌛
Powered by garuda-health 🦅
I feel like i should also add that whenever I use the ‘Log out’ feature on KDE, it goes to a black screen with the flashing text cursor and i can activate the terminal with CTRL+ALT+F2, which seems like it might be causing the DE to crash or something, and wont start back up with systemctl commands. Not sure if this may be related but i thought i would add this info in case it is.
