I have recently installed Garuda Linux (Dragonised Gaming Edition) and have been setting things up. With my setup I have two monitors, both 1440. The main monitor is on the right and in normal landscape mode, the second monitor is on the left in portrait mode.
On my login screen, the left hand monitor displays sideways as if it was in landscape mode.
The display works correctly once I have loaded into the desktop, but whenever I start the PC or logout the SDDM is in the wrong orientation for the left monitor.
I have tried using a different SDDM theme (Breeze including ones I have downloaded) but this had no effect (I don’t know if it is relevant but when I download some themes they give error messages about missing KDE plasma modules, but no such error messages appear on Breeze or the Dragonized theme)
I have pressed the ‘Apply Plasma Settings’ button but this seems to have no effect either (This was the solution in my previous KDE distro).
I have searched and read various wikis but I don’t have the understanding to take it further. I tried setting up some sddm.conf.d files but again this seemed to have no effect at all.
I would appreciate any assistance in either getting the monitor to rotate properly, or having the login screen only appear on the main monitor. Either would be acceptable.
Thank you
╭─lee@Gilgamesh in ~
╰─λ garuda-inxi
Kernel: 6.18.0-rc4-1-mainline arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-mainline
root=UUID=7bccce8b-51b5-4255-acdb-3cae91fe3055 rw rootflags=subvol=@
quiet loglevel=3
Desktop: KDE Plasma v: 6.5.2 tk: Qt v: N/A info: frameworks v: 6.19.0
Mobo: ASUSTeK model: PRIME X870-P v: Rev 1.xx serial: <superuser required>
part-nu: SKU uuid: <superuser required> UEFI: American Megatrends v: 1087
date: 09/19/2025
Info: model: AMD Ryzen 7 9800X3D bits: 64 type: MT MCP arch: Zen 5 gen: 5
level: v4 note: check built: 2024+ process: TSMC n4 (4nm) family: 0x1A (26)
model-id: 0x44 (68) stepping: 0 microcode: 0xB404032
smt: enabled cache: L1: 640 KiB desc: d-8x48 KiB; i-8x32 KiB L2: 8 MiB
desc: 8x1024 KiB L3: 96 MiB desc: 1x96 MiB
Speed (MHz): avg: 5232 min/max: 603/5272 boost: enabled scaling:
driver: amd-pstate-epp governor: performance cores: 1: 5232 2: 5232 3: 5232
4: 5232 5: 5232 6: 5232 7: 5232 8: 5232 9: 5232 10: 5232 11: 5232 12: 5232
13: 5232 14: 5232 15: 5232 16: 5232 bogomips: 150399
ssse3 svm
Device-1: Advanced Micro Devices [AMD/ATI] Navi 48 [Radeon RX 9070/9070
XT/9070 GRE] vendor: Tul / PowerColor Reaper driver: amdgpu v: kernel
arch: RDNA-4 code: Navi-4x process: TSMC n4 (4nm) built: 2025+ pcie:
gen: 5 speed: 32 GT/s lanes: 16 ports: active: DP-1,DP-2
empty: DP-3,HDMI-A-1,Writeback-1 bus-ID: 03:00.0 chip-ID: 1002:7550
vendor: ASUSTeK driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
lanes: 16 ports: active: none empty: DP-4, DP-5, HDMI-A-2, Writeback-2
bus-ID: 75:00.0 chip-ID: 1002:13c0 class-ID: 0300 temp: 44.0 C
alternate: fbdev,vesa dri: radeonsi gpu: amdgpu d-rect: 5120x2880
display-ID: 0
Monitor-1: DP-1 pos: bottom-r model: Acer XB273U V3 serial: <filter>
built: 2023 res: mode: 2560x1440 hz: 144 scale: 100% (1) dpi: 109 gamma: 1.2
max: 2560x1440 min: 720x400
Monitor-2: DP-2 pos: primary,top-left model: Acer XB271HU serial: <filter>
built: 2018 res: mode: 2560x1440 hz: 144 scale: 178% (1.78) to: 1440x2560
dpi: 109 gamma: 1.2 size: 598x336mm (23.54x13.23") diag: 686mm (27")
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.2.6-arch1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 9070 XT (radeonsi
gfx1201 LLVM 21.1.4 DRM 3.64 6.18.0-rc4-1-mainline) device-ID: 1002:7550
API: Vulkan v: 1.4.328 layers: 13 device: 0 type: discrete-gpu name: AMD
Radeon RX 9070 XT (RADV GFX1201) driver: mesa radv v: 25.2.6-arch1.1
device-ID: 1002:7550 surfaces: N/A device: 1 type: integrated-gpu name: AMD
Ryzen 7 9800X3D 8-Core Processor (RADV RAPHAEL_MENDOCINO)
driver: mesa radv v: 25.2.6-arch1.1 device-ID: 1002:13c0 surfaces: N/A
device: 2 type: cpu name: llvmpipe (LLVM 21.1.4 256 bits)
driver: mesa llvmpipe v: 25.2.6-arch1.1 (LLVM 21.1.4)
de: kscreen-console,kscreen-doctor gpu: corectrl,lact wl: wayland-info
Device-1: Advanced Micro Devices [AMD/ATI] Navi 48 HDMI/DP Audio
driver: snd_hda_intel v: kernel pcie: gen: 5 speed: 32 GT/s lanes: 16
bus-ID: 03:00.1 chip-ID: 1002:ab40 class-ID: 0403
[Rembrandt/Strix] vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie:
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 75:00.1 chip-ID: 1002:1640
lanes: 16 bus-ID: 75:00.6 chip-ID: 1022:15e3 class-ID: 0403
Device-4: SteelSeries ApS Arctis Nova 7
lanes: 1 mode: 1.1 bus-ID: 7-2:2 chip-ID: 1038:2202 class-ID: 0300
API: ALSA v: k6.18.0-rc4-1-mainline status: kernel-api with: aoss
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: e000 bus-ID: 08:00.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-8:3 chip-ID: 2b89:8761
Local Storage: total: 4.55 TiB used: 1.32 TiB (29.0%)
model: SSD 990 EVO Plus 1TB size: 931.51 GiB block-size: physical: 512 B
logical: 512 B speed: 126 Gb/s lanes: 4 tech: SSD serial: <filter>
fw-rev: 2B2QKXG7 temp: 39.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:3 vendor: Samsung
fw-rev: 2B2QKXG7 temp: 35.9 C scheme: GPT
ID-3: /dev/nvme2n1 maj-min: 259:4 vendor: Samsung
fw-rev: 2B2QKXG7 temp: 34.9 C scheme: GPT
ID-4: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 QVO 2TB
used: 97.7 GiB (10.5%) fs: btrfs dev: /dev/nvme2n1p2 maj-min: 259:10
used: 6.1 MiB (2.0%) fs: vfat dev: /dev/nvme2n1p1 maj-min: 259:9
ID-1: swap-1 type: zram size: 30.49 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 51.5 C mobo: N/A
GPU: device: amdgpu temp: 45.0 C device: amdgpu temp: 53.0 C mem: 56.0 C
fan: 0 watts: 48.00
Memory: total: 32 GiB note: est. available: 30.49 GiB used: 5.58 GiB (18.3%)
Processes: 518 Power: uptime: 2m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.18 GiB services: org_kde_powerdevil,
Packages: 1882 pm: pacman pkgs: 1871 libs: 498 tools: octopi,paru
pm: flatpak pkgs: 11 Compilers: clang: 21.1.5 gcc: 15.2.1 Shell: Bash
v: 5.3.3 default: fish v: 4.1.2 running-in: konsole inxi: 3.3.39
Garuda (2.11.1-1):
System install date: 2025-11-08
Garuda release: 251103
Last full system update: 2025-11-09
Relevant software: snapper NetworkManager dracut garuda-hardware-profile-standard
24/25 checks run in 0.51 seconds ⌛
Powered by garuda-health 🦅
