Natron 2.3.15-1 build gives the error "failed to prepare transaction" when I try to build it from the AUR.
There's three popups all showing:
could not satisfy dependencies:
- unable to satisfy dependency 'sip=4.19.22' required by seexpr1-2
- unable to satisfy dependency 'seexpr1-2' required by openfx-io
- unable to satisfy dependency 'openfx-io' required by natron
I'm not savvy enough to know if this is really a problem with the AUR package or something else, but since I can find seexprl1-2 and openfx-io in the AUR, I can probably fix those two dependencies by installing those first and trying the build again. But, sip=4.19.22 isn't in the AUR, there are other versions of sip, but I don't know if having other versions would fix this if Natron is calling for a specific version.
Any ideas?
Here's the build script:
# Maintainer: Tércio Martins <echo dGVyY2lvd2VuZGVsQGdtYWlsLmNvbQo= | base64 -d>
# Contributor: Luca Weiss <luca (at) z3ntu (dot) xyz>
# Contributor: Özgür Sarıer <echo b3pndXJzYXJpZXIxMDExNjAxMTE1QGdtYWlsLmNvbQo= | base64 -d>
# Contributor: liberodark
_google_breakpad_commit=9474c3f
_google_mock_commit=17945db
_google_test_commit=50d6fc3
_SequenceParsing_commit=1bbcd07
_tinydir_commit=3aae922
pkgname=natron
_pkgname=Natron
pkgver=2.3.15
pkgrel=1
pkgdesc="Open source compositing software"
arch=('i686' 'pentium4' 'x86_64')
url="https://natrongithub.github.io/"
_url="https://github.com/NatronGitHub"
license=('GPL')
depends=('openfx-arena' 'openfx-gmic' 'openfx-io' 'openfx-misc' 'python2-pyside')
makedepends=('boost' 'glfw-x11' 'openmp')
optdepends=('natron-plugins-git: Extra Python plugins')
source=("${_pkgname}-${pkgver}.tar.gz::${_url}/${_pkgname}/archive/v${pkgver}.tar.gz"
"google-breakpad-${_google_breakpad_commit}.tar.gz::${_url}/google-breakpad/tarball/${_google_breakpad_commit}"
"google-mock-${_google_mock_commit}.tar.gz::${_url}/google-mock/tarball/${_google_mock_commit}"
"google-test-${_google_test_commit}.tar.gz::${_url}/google-test/tarball/${_google_test_commit}"
"SequenceParsing-${_SequenceParsing_commit}.tar.gz::${_url}/SequenceParsing/tarball/${_SequenceParsing_commit}"
"tinydir-${_tinydir_commit}.tar.gz::${_url}/tinydir/tarball/${_tinydir_commit}"
"OpenColorIO-Configs-${_pkgname}-v${pkgver%.??}.tar.gz::${_url}/OpenColorIO-Configs/archive/${_pkgname}-v${pkgver%.??}.tar.gz"
"openfx-${_pkgname}-${pkgver}.tar.gz::${_url}/openfx/archive/${_pkgname}-${pkgver}.tar.gz"
"config.pri")
sha512sums=('10492d698124fee5ade0806a094534846a0b6a4ee1f0e5683eb6f93570eecb5c39792eb393f387deeb484513c37bfe1e635f509d51a682937f0c77f26af76c6f'
'SKIP'
'SKIP'
'SKIP'
'SKIP'
'SKIP'
'0c63a5f52aa7b8d32ed068a1f9f1092082f70e9a95b916b33213d899fd9dd4e487af3baa4d6bfbd9eb4d5051e6efef15155e3a22897f8ec32330d0825df643be'
'86aa7a675b64c6d7c100ecc4f49c29e834ccf08246e6ce11c4b92b51bb2fce73304a78e91f06c7eb72b18ca89084357816dd09238fdefb1998da57196e723b0d'
'48017b7b9cd1854064b9ddffecedef89a4d38070f9a7d2cd506aad481a8061c5cffe5e5c84fc9b0ac5216fc99e093481db367e91ce52cb2a8a66223c4209402a')
prepare() {
cd "${srcdir}/${_pkgname}-${pkgver}"
if [ -d OpenColorIO-Configs ]; then
rm -rf OpenColorIO-Configs
fi
mv "${srcdir}/OpenColorIO-Configs-Natron-v${pkgver%.??}" \
"${srcdir}/${_pkgname}-${pkgver}/OpenColorIO-Configs"
tar -xzf "${srcdir}/google-breakpad-${_google_breakpad_commit}.tar.gz" --strip 1 \
-C "${srcdir}/${_pkgname}-${pkgver}/libs/google-breakpad/"
tar -xzf "${srcdir}/SequenceParsing-${_SequenceParsing_commit}.tar.gz" --strip 1 \
-C "${srcdir}/${_pkgname}-${pkgver}/libs/SequenceParsing/"
tar -xzf "${srcdir}/tinydir-${_tinydir_commit}.tar.gz" --strip 1 \
-C "${srcdir}/${_pkgname}-${pkgver}/libs/SequenceParsing/tinydir/"
tar -xzf "${srcdir}/google-mock-${_google_mock_commit}.tar.gz" --strip 1 \
-C "${srcdir}/${_pkgname}-${pkgver}/Tests/google-mock/"
tar -xzf "${srcdir}/google-test-${_google_test_commit}.tar.gz" --strip 1 \
-C "${srcdir}/${_pkgname}-${pkgver}/Tests/google-test/"
tar -xzf "${srcdir}/openfx-${_pkgname}-${pkgver}.tar.gz" --strip 1 \
-C "${srcdir}/${_pkgname}-${pkgver}/libs/OpenFX/"
mv "${srcdir}/config.pri" \
"${srcdir}/${_pkgname}-${pkgver}/config.pri"
build() {
[[ -d build ]] && rm -r build; mkdir build; cd build
qmake-qt4 -r "${srcdir}/${_pkgname}-${pkgver}/Project.pro" \
PREFIX=/usr \
BUILD_USER_NAME="Arch_Linux" \
CONFIG+=custombuild \
CONFIG+=openmp \
DEFINES+=QT_NO_DEBUG_OUTPUT \
QMAKE_CFLAGS_RELEASE="${CFLAGS}" \
QMAKE_CXXFLAGS_RELEASE="${CXXFLAGS}" \
QMAKE_LFLAGS_RELEASE="${LDFLAGS}"
make
package() {
cd "${srcdir}/${_pkgname}-${pkgver}/build"
make INSTALL_ROOT="${pkgdir}" install
install -d "${pkgdir}/usr/share/Natron/Plugins/"
cp -r "${srcdir}/${_pkgname}-${pkgver}/Gui/Resources/PyPlugs" \
install -d "${pkgdir}/etc/profile.d"
echo -e "export FONTCONFIG_PATH=/etc/fonts\n" > "${pkgdir}/etc/profile.d/${pkgname}.sh"
echo -e "setenv FONTCONFIG_PATH /etc/fonts\n" > "${pkgdir}/etc/profile.d/${pkgname}.csh"
