I can't post the output becuase it has the links to the keys and I have a max of 5 links.
The point is :
error: key "Christian Rebischke (Archlinux Security Team-Member) <chris.rebischke@archlinux.org>" could not be imported
error: required key missing from keyring
error: failed to commit transaction (unexpected error)
What I tried to :
reinstalling archlinux-keyring : did not work
This is what I get
sudo pacman -S archlinux-keyring
warning: archlinux-keyring-20220125-1 is up to date -- reinstalling
resolving dependencies...
Packages (1) archlinux-keyring-20220125-1
Total Download Size: 1,01 MiB
Total Installed Size: 1,43 MiB
Net Upgrade Size: 0,00 MiB
:: Retrieving packages...
archlinux-keyring-20220125-1-any 1036,5 KiB 5,01 MiB/s 00:00 [----------------------------------------------------------------------------------------] 100%
(1/1) checking keys in keyring [----------------------------------------------------------------------------------------] 100%
(1/1) checking package integrity [----------------------------------------------------------------------------------------] 100%
error: archlinux-keyring: signature from "Christian Hesse <eworm@archlinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/archlinux-keyring-20220125-1-any.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
Do you want to delete it? [Y/n]
error: failed to commit transaction (invalid or corrupted package (PGP signature))
refreshing the keys : did not work
At some point it halts
error: failed retrieving file 'chaotic-aur.db' from geo-mirror.chaotic.cx : The requested URL returned error: 404
error: key "Nico Jensch (Chaotic-AUR) <dr460nf1r3@garudalinux.org>" could not be imported
[2022-02-19 01:15:58] WARNING: failed to rate http(s) download (https://archmirror.it/repos/community/os/x86_64/community.db): HTTP Error 403: Forbidden
[2022-02-19 01:15:58] WARNING: failed to rate http(s) download (https://mirror.cyberbits.asia/archlinux/community/os/x86_64/community.db): <urlopen error [Errno 101] Network is unreachable>
warning: archlinux-keyring-20220125-1 is up to date -- skipping
garuda-update
core is up to date
extra is up to date
community is up to date
multilib is up to date
chaotic-aur is up to date
Packages (1) garuda-update-2.0.6-1
Total Installed Size: 0,01 MiB
(1/1) checking keys in keyring [----------------------------------------] 100%
downloading required keys...
:: Import PGP key 0706B90D37D9B881, "Chaotic-AUR Wild Bear Node <wildbear.node@chaotic.cx>"? [Y/n]
--> Refreshing mirrorlists using reflector, please be patient..
[2022-02-19 01:17:25] WARNING: failed to rate http(s) download (<archmirror>.it/repos/community/os/x86_64/community.db): HTTP Error 403: Forbidden
[2022-02-19 01:17:26] WARNING: failed to rate http(s) download (mirror.cyberbits.asia/archlinux/community/os/x86_64/community.db): <urlopen error [Errno 101] Network is unreachable>
################# Arch Linux mirrorlist generated by Reflector #################
# With: reflector --latest 5 --age 2 --fastest 5 --protocol https --sort rate --save /etc/pacman.d/mirrorlist
# When: 2022-02-19 00:17:26 UTC
# From: <archlinux>.org/mirrors/status/json/
# Retrieved: 2022-02-19 00:15:11 UTC
# Last Check: 2022-02-18 23:51:43 UTC
// links below are modifed
Server = <>.mirror.chaoticum.net/arch/$repo/os/$arch
Server = mirror.cyberbits.eu/archlinux/$repo/os/$arch
Server = <>.phinau.de/arch/$repo/os/$arch
Server = archmirror.it/repos/$repo/os/$arch
Server = mirror.cyberbits.asia/archlinux/$repo/os/$arch
core 133,4 KiB 677 KiB/s 00:00 [----------------------------------------] 100%
extra 1542,2 KiB 1396 KiB/s 00:01 [----------------------------------------] 100%
community 6,1 MiB 1450 KiB/s 00:04 [----------------------------------------] 100%
multilib 149,6 KiB 629 KiB/s 00:00 [----------------------------------------] 100%
chaotic-aur 1781,2 KiB 2,20 MiB/s 00:01 [----------------------------------------] 100%
--> Applying keyring updates before starting full system update..
Packages (2) chaotic-keyring-20220130-1 garuda-hotfixes-1.1.1-1
Total Installed Size: 0,02 MiB
(2/2) checking keys in keyring [----------------------------------------] 100%
:: Import PGP key 0706B90D37D9B881, "Nico Jensch <dr460nf1r3@chaotic.cx>"? [Y/n]
error: key "Nico Jensch (Chaotic-AUR) <<>/dr460nf1r3@garudalinux.org>" could not be imported
I have never had this problem. I guess because this time I did not update the system for a long time ?
Could you please explain what it did / why the problem occurred ?
