An error occurred while accessing 'Data', the system responded: The requested operation has failed: Error mounting system-managed device /dev/sda1: Unknown error when mounting none
this error happen after i upgrade garuda
Kernel: 6.3.3-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=31d21ee4-0d3c-4fc6-a639-3034a407e460
rw [email protected] quiet quiet splash rd.udev.log_priority=3 vt.global_cursor_default=0
resume=UUID=6d1b534f-dfa7-4c43-8fcf-29f0b210fdd2 loglevel=3 ibt=off
Desktop: KDE Plasma v: 5.27.5 tk: Qt v: 5.15.9 wm: kwin_x11 vt: 1 dm: SDDM Distro: Garuda Linux
Type: Laptop System: Acer product: Nitro AN515-45 v: V1.10 serial: <superuser required>
Mobo: CZ model: Scala_CAS v: V1.10 serial: <superuser required> UEFI: Insyde v: 1.10
date: 08/02/2022
ID-1: BAT1 charge: 44.4 Wh (85.7%) condition: 51.8/58.8 Wh (88.1%) volts: 17.3 min: 15.4
model: SMP AP18E7M type: Li-ion serial: <filter> status: charging
Info: model: AMD Ryzen 7 5800H with Radeon Graphics bits: 64 type: MT MCP arch: Zen 3 gen: 4
level: v3 note: check built: 2021-22 process: TSMC n7 (7nm) family: 0x19 (25) model-id: 0x50 (80)
stepping: 0 microcode: 0xA50000C
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache: L1: 512 KiB
desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 3408 high: 4316 min/max: 1200/4462 boost: enabled scaling:
driver: acpi-cpufreq governor: performance cores: 1: 3451 2: 3444 3: 4316 4: 3200 5: 3445 6: 3200
7: 3200 8: 3442 9: 3451 10: 3433 11: 3200 12: 3488 13: 3434 14: 3200 15: 3200 16: 3424
bogomips: 102218
Device-1: NVIDIA GA106M [GeForce RTX 3060 Mobile / Max-Q] vendor: Acer Incorporated ALI
status: current (as of 2023-05) arch: Ampere code: GAxxx process: TSMC n7 (7nm) built: 2020-22
pcie: gen: 1 speed: 2.5 GT/s lanes: 8 link-max: gen: 4 speed: 16 GT/s lanes: 16 ports:
active: none empty: HDMI-A-1 bus-ID: 01:00.0 chip-ID: 10de:2520 class-ID: 0300
Device-2: AMD Cezanne [Radeon Vega Series / Radeon Mobile Series] vendor: Acer Incorporated ALI
driver: amdgpu v: kernel arch: GCN-5 code: Vega process: GF 14nm built: 2017-20 pcie: gen: 3
speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s ports: active: eDP-1 empty: none
bus-ID: 05:00.0 chip-ID: 1002:1638 class-ID: 0300 temp: 48.0 C
Device-3: Quanta HD User Facing driver: uvcvideo type: USB rev: 2.0 speed: 480 Mb/s lanes: 1
mode: 2.0 bus-ID: 3-3:2 chip-ID: 0408:a061 class-ID: 0e02
Display: x11 server: X.Org v: 21.1.8 with: Xwayland v: 23.1.1 compositor: kwin_x11 driver: X:
loaded: modesetting,nvidia dri: radeonsi gpu: amdgpu display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x285mm (20.00x11.22") s-diag: 582mm (22.93")
Monitor-1: eDP-1 model: ChiMei InnoLux 0x1521 built: 2020 res: 1920x1080 hz: 144 dpi: 142
gamma: 1.2 size: 344x193mm (13.54x7.6") diag: 394mm (15.5") ratio: 16:9 modes: max: 1920x1080
min: 640x480
API: OpenGL v: 4.6 Mesa 23.0.3 renderer: AMD Radeon Graphics (renoir LLVM 15.0.7 DRM 3.52
6.3.3-zen1-1-zen) direct-render: Yes
Device-1: NVIDIA GA106 High Definition Audio vendor: Acer Incorporated ALI driver: snd_hda_intel
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 8 link-max: gen: 4 speed: 16 GT/s lanes: 16
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Acer Incorporated ALI driver: N/A
alternate: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x, snd_acp_pci,
snd_rpl_pci_acp6x, snd_pci_ps, snd_sof_amd_renoir, snd_sof_amd_rembrandt pcie: gen: 3
speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 05:00.5 chip-ID: 1022:15e2
class-ID: 0480
Device-3: AMD Family 17h/19h HD Audio vendor: Acer Incorporated ALI driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 05:00.6
API: ALSA v: k6.3.3-zen1-1-zen status: kernel-api with: aoss type: oss-emulator tools: N/A
Server-1: PipeWire v: 0.3.70 status: active with: 1: pipewire-pulse status: active
Device-1: Realtek vendor: Acer Incorporated ALI driver: r8169 v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: 2000 bus-ID: 03:00.0 chip-ID: 10ec:2600 class-ID: 0200
Device-2: MEDIATEK MT7921 802.11ax PCI Express Wireless Network Adapter vendor: Lite-On
driver: mt7921e v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 04:00.0 chip-ID: 14c3:7961
Device-1: Lite-On Wireless_Device driver: btusb v: 0.8 type: USB rev: 2.1 speed: 480 Mb/s
lanes: 1 mode: 2.0 bus-ID: 1-4:3 chip-ID: 04ca:3802 class-ID: e001 serial: <filter>
Local Storage: total: 1.38 TiB used: 19.23 GiB (1.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZVLQ512HBLU-00B00 size: 476.94 GiB
fw-rev: FXM7201Q temp: 43.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Toshiba model: HDWL110 size: 931.51 GiB block-size:
physical: 4096 B logical: 512 B speed: 6.0 Gb/s tech: HDD rpm: 5400 serial: <filter> fw-rev: 0A
ID-1: / raw-size: 442.79 GiB size: 442.79 GiB (100.00%) used: 19.23 GiB (4.3%) fs: btrfs
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 576 KiB (0.2%) fs: vfat
ID-3: /home raw-size: 442.79 GiB size: 442.79 GiB (100.00%) used: 19.23 GiB (4.3%) fs: btrfs
ID-4: /var/log raw-size: 442.79 GiB size: 442.79 GiB (100.00%) used: 19.23 GiB (4.3%) fs: btrfs
ID-5: /var/tmp raw-size: 442.79 GiB size: 442.79 GiB (100.00%) used: 19.23 GiB (4.3%) fs: btrfs
ID-1: swap-1 type: zram size: 30.71 GiB used: 0 KiB (0.0%) priority: 100 dev: /dev/zram0
ID-2: swap-2 type: partition size: 33.85 GiB used: 0 KiB (0.0%) priority: -2
System Temperatures: cpu: 66.9 C mobo: N/A gpu: amdgpu temp: 48.0 C
Processes: 353 Uptime: 13m wakeups: 1 Memory: available: 30.71 GiB used: 3.48 GiB (11.3%)
Init: systemd v: 253 default: graphical tool: systemctl Compilers: gcc: 13.1.1 Packages:
pm: pacman pkgs: 2150 libs: 555 tools: gnome-software,octopi,pamac,paru pm: flatpak pkgs: 0
Client: shell wrapper v: 5.1.16-release inxi: 3.3.27
System install date: 2023-05-22
Last full system update: 2023-05-23 ↻
Either...
NTFS is not native to Linux and using it may be perilous for your data.
i have try usb drive including garuda linux installation for test and i found that i can mount and use data disk ntfs . I think dolphin have few issue
Do you now have the ntfs-3g driver installed in your current system?
i have already install
Then the problem lies within your installed system. Have you tried rebooting? And if it still persists you might try rolling back to a previous snapshot that worked.
I notice you do not have Windows installed. If it were my data I would seriously think about converting it to a Linux filesystem.
Had the same thing happen to me, did an upgrade and dolphin can't mount the NTFS drive anymore. After going through the packages that I had to update, I found out that it's the util-linux-2.39-1 package that is the culprit.
i think it because of dork change from old to new and it cause malfunction
You installed 2 days ago. The "dork" change has no bearing whatsoever, as long as you installed from a recent ISO.
Could be this bug:
This has been fixed as of version 2.39.3 of util-linux and associated util-linux-lib. At least fixed for me now.
