Password request works but then
╭─sgs@sway in ~ as 🧙
╰─λ btrfs-assistant
Authorization required, but no authorization protocol specified
qt.qpa.xcb: could not connect to display :0
qt.qpa.plugin: Could not load the Qt platform plugin "xcb" in "" even though it was found.
This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
Available platform plugins are: eglfs, linuxfb, minimal, minimalegl, offscreen, vnc, wayland-egl, wayland, wayland-xcomposite-egl, wayland-xcomposite-glx, xcb.
Same xcb-XY files installed like in i3wm. Reinstalling the application dos not fix this problem.
╰─λ sudo -H DIFFPROG=meld pacdiff
==> pacnew file found for /etc/locale.gen
:: (V)iew, (S)kip, (R)emove pacnew, (O)verwrite with pacnew, (Q)uit: [v/s/r/o/q] v
2022-02-25 22:25:11,268 CRITICAL Gtk: gtk_icon_theme_get_for_screen: assertion 'GDK_IS_SCREEN (screen)' failed
File "/usr/bin/meld", line 384, in <module>
setup_resources()
File "/usr/bin/meld", line 236, in setup_resources
Gtk.IconTheme.get_default().append_search_path(icon_dir)
AttributeError: 'NoneType' object has no attribute 'append_search_path'
╰─λ garuda-inxi
Kernel: 5.16.11-zen1-1-zen x86_64 bits: 64 compiler: gcc
v: 11.2.0 parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen
root=UUID=cc8c3427-2bdc-407e-ae93-4105b6795059 rw
rootflags=subvol=@ quiet splash rd.udev.log_priority=3
vt.global_cursor_default=0 loglevel=3
Desktop: sway 1.7 info: waybar vt: 1 dm: greetd
Type: Laptop System: LENOVO product: 82MS
v: Yoga Slim 7 Pro 14ACH5 serial: <superuser required> Chassis:
type: 10 v: Yoga Slim 7 Pro 14ACH5 serial: <superuser required>
Mobo: LENOVO model: LNVNB161216 v: SDK0R32862WIN
serial: <superuser required> UEFI: LENOVO v: GZCN23WW
date: 10/11/2021
ID-1: BAT0 charge: 29.4 Wh (49.4%)
condition: 59.5/61.0 Wh (97.5%) volts: 15.2 min: 15.4
model: Sunwoda L19D4PH3 type: Li-poly serial: <filter>
status: Discharging cycles: 50
Info: model: AMD Ryzen 9 5900HX with Radeon Graphics bits: 64
type: MT MCP arch: Zen 3 family: 0x19 (25) model-id: 0x50 (80)
stepping: 0 microcode: 0xA50000B
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled
cache: L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB
Speed (MHz): avg: 1309 high: 2652 min/max: 1200/4679
boost: enabled scaling: driver: acpi-cpufreq governor: schedutil
cores: 1: 2652 2: 1395 3: 1195 4: 1195 5: 1197 6: 1197 7: 1196
8: 1196 9: 1196 10: 1195 11: 1197 12: 1197 13: 1196 14: 1197
15: 1351 16: 1197 bogomips: 105400
Flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a
ssse3 svm
Type: spectre_v1 mitigation: usercopy/swapgs barriers and
__user pointer sanitization
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB:
conditional, IBRS_FW, STIBP: always-on, RSB filling
Device-1: AMD Cezanne vendor: Lenovo driver: amdgpu v: kernel
pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s ports: active: eDP-1 empty: DP-1,DP-2
bus-ID: 03:00.0 chip-ID: 1002:1638 class-ID: 0300
Device-2: IMC Networks Integrated Camera type: USB
driver: uvcvideo bus-ID: 1-3:2 chip-ID: 13d3:5419 class-ID: fe01
Display: wayland server: Xwayland v: 22.1.0 compositor: sway
v: 1.7 driver: gpu: amdgpu display-ID: 1
Monitor-1: eDP-1 model: 0x1402 built: 2020 res: 2880x1800
hz: 90 dpi: 242 gamma: 1.2 scale: 2 size: 302x188mm (11.9x7.4")
diag: 356mm (14") ratio: 16:10 modes: max: 2880x1800
min: 640x480
Message: Wayland GBM/EGL data currently not available.
driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s
lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 03:00.1
Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor
vendor: Lenovo driver: N/A alternate: snd_pci_acp3x,
snd_rn_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x
speed: 16 GT/s bus-ID: 03:00.5 chip-ID: 1022:15e2
class-ID: 0480
Device-3: AMD Family 17h HD Audio vendor: Lenovo
lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 03:00.6
Sound Server-1: ALSA v: k5.16.11-zen1-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.47 running: yes
Device-1: Realtek RTL8852AE 802.11ax PCIe Wireless Network Adapter vendor: Lenovo driver: rtw89_pci v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: 2000 bus-ID: 01:00.0
chip-ID: 10ec:8852 class-ID: 0280
bus-ID: 3-4:2 chip-ID: 0bda:4852 class-ID: e001 serial: <filter>
address: <filter>
Local Storage: total: 953.87 GiB used: 9.67 GiB (1.0%)
SMART Message: Required tool smartctl not installed. Check
--recommends
model: MZVLB1T0HBLR-000L2 size: 953.87 GiB block-size:
physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4
type: SSD serial: <filter> rev: 3L1QEXF7 temp: 32.9 C
ID-1: / raw-size: 351.51 GiB size: 351.51 GiB (100.00%)
used: 9.64 GiB (2.7%) fs: btrfs dev: /dev/nvme0n1p6
maj-min: 259:6
used: 28.9 MiB (11.3%) fs: vfat dev: /dev/nvme0n1p1
maj-min: 259:1
ID-3: /home raw-size: 351.51 GiB size: 351.51 GiB (100.00%)
maj-min: 259:6
ID-4: /var/log raw-size: 351.51 GiB size: 351.51 GiB (100.00%)
maj-min: 259:6
ID-5: /var/tmp raw-size: 351.51 GiB size: 351.51 GiB (100.00%)
maj-min: 259:6
Kernel: swappiness: 133 (default 60)
cache-pressure: 100 (default)
ID-1: swap-1 type: zram size: 13.58 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: N/A mobo: N/A gpu: amdgpu temp: 37.0 C
Processes: 351 Uptime: 11m wakeups: 1 Memory: 13.58 GiB
used: 2.42 GiB (17.8%) Init: systemd v: 250 tool: systemctl
Compilers: gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 1179
lib: 306 Shell: fish v: 3.3.1 default: Bash v: 5.1.16
running-in: xfce4-terminal inxi: 3.3.13
Garuda (2.5.5-1):
System install date: 2022-02-18
Last full system update: 2022-02-25
If necessary, I will split the post.
