Hey everyone! Today, I was using my chromium web browser just fine, and then did an update, and now no browser will connect to the sound system (I use pipewire). Spotify works great, Reaper is also working (through pw-jack), but Firedragon, Chromium, and firefox won't connect to the sound system. And I have no idea what I did wrong.
I have pipewire, pipewire-pulse, pipewire-alsa, and pipewire-jack all installed. No sound from the browsers.
Pavucontrol-qt doesn't register any browser, and I often use Carla to connect stuff, like browsers, to my pro audio software, both ardour and reaper. The browsers are not showing up there, but Spotify is. Even Steam and games refuse to connect to the audio system. VLC doesn't register to the sound system either.
Any thoughts on what I borked? I'm not looking forward to reinstalling garuda or arch.
Kernel: 5.16.2-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=c1bd2889-b744-4011-8e5e-f5297693bdf0 rw [email protected]
resume=UUID=d20da85b-0fe0-492e-bb74-ed30296cccb9 loglevel=3
Desktop: KDE Plasma 5.23.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop System: Micro-Star product: MS-7B79 v: 2.0
Mobo: Micro-Star model: X470 GAMING PLUS (MS-7B79) v: 2.0
serial: <superuser required> UEFI: American Megatrends v: A.A0
date: 06/18/2019
ID-1: hidpp_battery_0 charge: 68% condition: N/A volts: 3.9 min: N/A
Info: model: AMD Ryzen 7 2700X bits: 64 type: MT MCP arch: Zen+
L3: 16 MiB desc: 2x8 MiB
Speed (MHz): avg: 3087 high: 4257 min/max: 2200/3700 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 2568 2: 2430
3: 3630 4: 3230 5: 3644 6: 2683 7: 4032 8: 4257 9: 2419 10: 2399 11: 2425
12: 2997 13: 2863 14: 3100 15: 2492 16: 4225 bogomips: 118385
STIBP: disabled, RSB filling
Device-1: NVIDIA TU116 [GeForce GTX 1660 Ti] vendor: Gigabyte
driver: nvidia v: 495.46 alternate: nouveau,nvidia_drm bus-ID: 27:00.0
chip-ID: 10de:2182 class-ID: 0300
Device-2: Microdia PC-LM1E type: USB driver: snd-usb-audio,uvcvideo
bus-ID: 7-4.1:3 chip-ID: 0c45:636d class-ID: 0102 serial: <filter>
loaded: nvidia unloaded: modesetting alternate: fbdev,nouveau,nv,vesa
Screen-1: 0 s-res: 2560x1080 s-dpi: 81 s-size: 803x343mm (31.6x13.5")
s-diag: 873mm (34.4")
Monitor-1: DP-4 res: 2560x1080 hz: 60 dpi: 81
size: 798x334mm (31.4x13.1") diag: 865mm (34.1")
OpenGL: renderer: NVIDIA GeForce GTX 1660 Ti/PCIe/SSE2
v: 4.6.0 NVIDIA 495.46 direct render: Yes
Device-1: NVIDIA TU116 High Definition Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel bus-ID: 27:00.1 chip-ID: 10de:1aeb
Device-2: AMD Family 17h HD Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 29:00.3 chip-ID: 1022:1457
Device-3: BEHRINGER UMC404HD 192k type: USB driver: snd-usb-audio
bus-ID: 1-13:3 chip-ID: 1397:0509 class-ID: fe01
Device-4: Microdia PC-LM1E type: USB driver: snd-usb-audio,uvcvideo
Device-5: QinHeng CH345 MIDI adapter type: USB driver: snd-usb-audio
bus-ID: 7-4.2.4:7 chip-ID: 1a86:752d class-ID: 0103
Device-6: M-Audio Oxygen 49 type: USB driver: snd-usb-audio
bus-ID: 7-4.3:5 chip-ID: 0763:0196 class-ID: 0103
Sound Server-1: ALSA v: k5.16.2-zen1-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.43 running: yes
vendor: Micro-Star MSI driver: r8169 v: kernel port: e000 bus-ID: 22:00.0
IF: enp34s0 state: down mac: <filter>
Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel bus-ID: 23:00.0
chip-ID: 8086:2723 class-ID: 0280
IF: wlp35s0 state: up mac: <filter>
Device-3: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet
vendor: TP-LINK TG-3468 driver: r8169 v: kernel port: d000 bus-ID: 24:00.0
IF: enp36s0 state: down mac: <filter>
bus-ID: 1-9:2 chip-ID: 8087:0029 class-ID: e001
Local Storage: total: 7.39 TiB used: 3.6 TiB (48.7%)
model: WDS200T2B0C-00PXH0 size: 1.82 TiB block-size: physical: 512 B
rev: 21705000 temp: 22.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 QVO 1TB
ID-3: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST3000DM001-1ER166
type: HDD rpm: 7200 serial: <filter> rev: CC25 scheme: GPT
ID-4: /dev/sdc maj-min: 8:32 vendor: Samsung model: SSD 840 EVO 120GB
type: SSD serial: <filter> rev: BB6Q scheme: MBR
ID-5: /dev/sdd maj-min: 8:48 vendor: Seagate model: ST2000DM001-9YN164
type: HDD rpm: 7200 serial: <filter> rev: CC4H scheme: MBR
ID-1: / raw-size: 196.88 GiB size: 196.88 GiB (100.00%)
used: 29.41 GiB (14.9%) fs: btrfs dev: /dev/nvme0n1p3 maj-min: 259:3
used: 576 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p4 maj-min: 259:4
ID-3: /home raw-size: 1.61 TiB size: 1.61 TiB (100.00%)
used: 1.2 TiB (74.3%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-4: /var/log raw-size: 196.88 GiB size: 196.88 GiB (100.00%)
ID-5: /var/tmp raw-size: 196.88 GiB size: 196.88 GiB (100.00%)
ID-1: swap-1 type: partition size: 15.82 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p1 maj-min: 259:1
ID-2: swap-2 type: zram size: 15.63 GiB used: 1.2 MiB (0.0%)
System Temperatures: cpu: 34.1 C mobo: N/A gpu: nvidia temp: 32 C
Processes: 492 Uptime: 4m wakeups: 2 Memory: 15.63 GiB
used: 4.04 GiB (25.8%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1637 lib: 430 Shell: fish
Garuda:
System install date: 2021-10-31
Last full system update: 2022-01-25
Using TLP: No
