Currently booted from usb because i can’t boot after an update and i was tired of logging into snapshot before the garuda-update. I also hoped that my issue could be resolved somehow before restoring the snapshot.
misobasedir=garuda root=miso:LABEL=GARUDA_GNOME_RAPTOR quiet
systemd.show_status=1 ibt=off driver=free nouveau.modeset=1
Desktop: GNOME v: 43.5 tk: GTK v: 3.24.37 wm: gnome-shell dm: GDM v: 44.0
Type: Laptop System: LENOVO product: 81VW v: Lenovo IdeaPad S340-15IIL
serial: <superuser required> Chassis: type: 10 v: Lenovo IdeaPad S340-15IIL
Mobo: LENOVO model: LNVNB161216 v: SDK0J40709 WIN
serial: <superuser required> UEFI: LENOVO v: CUCN27WW(V1.16)
date: 06/15/2021
ID-1: BAT1 charge: 30.1 Wh (100.0%) condition: 30.1/36.0 Wh (83.5%)
volts: 12.8 min: 11.2 model: Celxpert L18C3PF6 type: Li-ion serial: <filter>
status: full cycles: 1130
Info: model: Intel Core i7-1065G7 bits: 64 type: MT MCP arch: Ice Lake
gen: core 10 level: v4 note: check built: 2019-21 process: Intel 10nm
family: 6 model-id: 0x7E (126) stepping: 5 microcode: 0xB8
L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 2 MiB desc: 4x512 KiB L3: 8 MiB
desc: 1x8 MiB
Speed (MHz): avg: 1440 high: 1500 min/max: 400/3900 scaling:
driver: intel_pstate governor: powersave cores: 1: 1500 2: 1500 3: 1024
4: 1500 5: 1500 6: 1500 7: 1500 8: 1500 bogomips: 23961
Device-1: Intel Iris Plus Graphics G7 vendor: Lenovo driver: i915 v: kernel
arch: Gen-11 process: Intel 10nm built: 2019-21 ports: active: eDP-1
empty: HDMI-A-1 bus-ID: 0000:00:02.0 chip-ID: 8086:8a52 class-ID: 0300
Device-2: Syntek Integrated Camera type: USB driver: uvcvideo
bus-ID: 1-6:4 chip-ID: 174f:2426 class-ID: 0e02 serial: <filter>
Display: wayland server: X.org v: 1.21.1.8 with: Xwayland v: 23.1.1
compositor: gnome-shell driver: gpu: i915 display-ID: 0
Monitor-1: eDP-1 model: ChiMei InnoLux 0x15f5 built: 2017 res: 1920x1080
dpi: 142 gamma: 1.2 size: 344x193mm (13.54x7.6") diag: 394mm (15.5")
ratio: 16:9 modes: 1920x1080
API: EGL/GBM Message: No known Wayland EGL/GBM data sources.
Device-1: Intel Ice Lake-LP Smart Sound Audio vendor: Lenovo
driver: snd_hda_intel v: kernel alternate: snd_sof_pci_intel_icl
bus-ID: 0000:00:1f.3 chip-ID: 8086:34c8 class-ID: 0403
API: ALSA v: k6.2.13-zen-1-zen status: kernel-api tools: N/A
Device-1: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter
vendor: Lenovo driver: ath10k_pci v: kernel bus-ID: 0000:02:00.0
chip-ID: 168c:0042 class-ID: 0280
Device-1: Qualcomm Atheros type: USB driver: btusb v: 0.8 bus-ID: 1-10:5
chip-ID: 0cf3:e500 class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 4 state: up address: <filter>
driver: intel_nvme_remap v: N/A port: 3060 bus-ID: 0000:00:17.0
chip-ID: 8086:282a rev: N/A class-ID: 0104
Local Storage: total: 281.66 GiB used: 14.69 GiB (5.2%)
model: MZVLB256HBHQ-000L2 size: 238.47 GiB block-size: physical: 512 B
logical: 512 B type: SSD serial: <filter> rev: 3L1QEXH7 temp: 35.9 C
ID-2: /dev/sda maj-min: 8:0 type: USB vendor: SanDisk model: USB 3.2Gen1
size: 28.67 GiB block-size: physical: 512 B logical: 512 B type: N/A
ID-3: /dev/sdb maj-min: 8:16 type: USB vendor: Silicon Power
model: UFD 2.0 16G size: 14.51 GiB block-size: physical: 512 B
logical: 512 B type: N/A serial: <filter> rev: PMAP scheme: GPT
ID-1: swap-1 type: zram size: 7.45 GiB used: 1.85 GiB (24.8%)
System Temperatures: cpu: 52.0 C mobo: N/A
Processes: 274 Uptime: 1h 26m wakeups: 3 Memory: 7.45 GiB
used: 4.81 GiB (64.6%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 Packages: pm: pacman pkgs: 1160
libs: 341 tools: pamac,paru Shell: fish v: 3.6.1 default: Bash v: 5.1.16
running-in: gnome-terminal inxi: 3.3.26
System install date: 2023-10-25
Last full system update: 2023-10-25 ↻
Anyway, my question is: Have you tried fresh installing garuda (gnome-desktop version) , performing full system upgrade (likely linux-zen kernel problem ) and then rebooting? It has been 6 months or something since this is happening. The system doesn’t boot after the update.
