Hey folks,
I ran into a seemingly identical issue to this issue here, however the posted solutions still have not fixed the problem. I've checked the fonts in KDE Settings, as well as changing fonts in ~/.config/alaritty/alacritty.yml to match the settings in KDE Font Settings. However, spacing in Alacritty is still cursed. Konsole appears to be fine, however. I'm not really sure what else to try from here. Anyone else having this issue?
alacritty.yml
# Any items in the `env` entry below will be added as
# environment variables. Some entries may override variables
# set by alacritty itself.
env:
# TERM variable
# This value is used to set the `$TERM` environment variable for
# each instance of Alacritty. If it is not present, alacritty will
# check the local terminfo database and use `alacritty` if it is
# available, otherwise `xterm-256color` is used.
TERM: xterm-256color
window:
# Window dimensions (changes require restart)
# Specified in number of columns/lines, not pixels.
# If both are `0`, this setting is ignored.
dimensions:
columns: 100
lines: 30
# Window position (changes require restart)
# Specified in number of pixels.
# If the position is not set, the window manager will handle the placement.
#position:
# x: 0
# y: 0
# Window padding (changes require restart)
# Blank space added around the window in pixels. This padding is scaled
# by DPI and the specified value is always added at both opposing sides.
#padding:
# x: 0
# y: 0
# Spread additional padding evenly around the terminal content.
dynamic_padding: true
# Window decorations
# Values for `decorations`:
# - full: Borders and title bar
# - none: Neither borders nor title bar
# Values for `decorations` (macOS only):
# - transparent: Title bar, transparent background and title bar buttons
# - buttonless: Title bar, transparent background, but no title bar buttons
decorations: full
# Startup Mode (changes require restart)
# Values for `startup_mode`:
# - Windowed
# - Maximized
# - Fullscreen
# Values for `startup_mode` (macOS only):
# - SimpleFullscreen
#startup_mode: Windowed
# Window title
title: Alacritty@Garuda
# Opacity
opacity: 0.6
# Window class (Linux/BSD only):
class:
# Application instance name
instance: Alacritty
# General application class
general: Alacritty
# GTK theme variant (Linux/BSD only)
# Override the variant of the GTK theme. Commonly supported values are `dark` and `light`.
# Set this to `None` to use the default theme variant.
decorations_theme_variant: Dark
scrolling:
# Maximum number of lines in the scrollback buffer.
# Specifying '0' will disable scrolling.
history: 10000
# Scrolling distance multiplier.
multiplier: 3
# Font configuration
font:
# Normal (roman) font face
normal:
# Font family
# Default:
# - (macOS) Menlo
# - (Linux/BSD) monospace
# - (Windows) Consolas
family: FantasqueSansMono Nerd Font Mono
# The `style` can be specified to pick a specific face.
#style: Regular
# Bold font face
bold:
# Font family
# If the bold family is not specified, it will fall back to the
# value specified for the normal font.
#style: Bold
# Italic font face
italic:
# Font family
# If the italic family is not specified, it will fall back to the
#style: Italic
# Bold italic font face
bold_italic:
# Font family
# If the bold italic family is not specified, it will fall back to the
#style: Bold Italic
# Point size
# Offset is the extra space around each character. `offset.y` can be thought of
# as modifying the line spacing, and `offset.x` as modifying the letter spacing.
#offset:
# x: 0
# y: 0
# Glyph offset determines the locations of the glyphs within their cells with
# the default being at the bottom. Increasing `x` moves the glyph to the right,
# increasing `y` moves the glyph upwards.
#glyph_offset:
# x: 0
# y: 0
# Thin stroke font rendering (macOS only)
# Thin strokes are suitable for retina displays, but for non-retina screens
# it is recommended to set `use_thin_strokes` to `false`.
#use_thin_strokes: true
# If `true`, bold text is drawn using the bright color variants.
draw_bold_text_with_bright_colors: true
# Colors (Tomorrow Night)
#colors:
# Default colors
#primary:
# background: '#1d1f21'
# foreground: '#c5c8c6'
# Bright and dim foreground colors
# The dimmed foreground color is calculated automatically if it is not present.
# If the bright foreground color is not set, or `draw_bold_text_with_bright_colors`
# is `false`, the normal foreground color will be used.
#dim_foreground: '#828482'
#bright_foreground: '#eaeaea'
# Cursor colors
# Colors which should be used to draw the terminal cursor. If these are
# unset, the cursor color will be the inverse of the cell color.
#cursor:
# text: '#000000'
# cursor: '#ffffff'
# Vi mode cursor colors
# Colors for the cursor when the vi mode is active. If these are unset, the
# cursor color will be the inverse of the cell color.
#vi_mode_cursor:
# text: '#000000'
# cursor: '#ffffff'
# Selection colors
# Colors which should be used to draw the selection area. If selection
# background is unset, selection color will be the inverse of the cell colors.
# If only text is unset the cell text color will remain the same.
#selection:
# text: '#eaeaea'
# background: '#404040'
# Normal colors
#normal:
# black: '#1d1f21'
# red: '#cc6666'
# green: '#b5bd68'
# yellow: '#f0c674'
# blue: '#81a2be'
# magenta: '#b294bb'
# cyan: '#8abeb7'
# white: '#c5c8c6'
# Bright colors
#bright:
# black: '#666666'
# red: '#d54e53'
# green: '#b9ca4a'
# yellow: '#e7c547'
# blue: '#7aa6da'
# magenta: '#c397d8'
# cyan: '#70c0b1'
# white: '#eaeaea'
# Dim colors
# If the dim colors are not set, they will be calculated automatically based
# on the `normal` colors.
#dim:
# black: '#131415'
# red: '#864343'
# green: '#777c44'
# yellow: '#9e824c'
# blue: '#556a7d'
# magenta: '#75617b'
# cyan: '#5b7d78'
# white: '#828482'
# Indexed Colors
# The indexed colors include all colors from 16 to 256.
# When these are not set, they're filled with sensible defaults.
# Example:
# `- { index: 16, color: '#ff00ff' }`
#indexed_colors: []
# Visual Bell
# Any time the BEL code is received, Alacritty "rings" the visual bell. Once
# rung, the terminal background will be set to white and transition back to the
# default background color. You can control the rate of this transition by
# setting the `duration` property (represented in milliseconds). You can also
# configure the transition function by setting the `animation` property.
# Values for `animation`:
# - Ease
# - EaseOut
# - EaseOutSine
# - EaseOutQuad
# - EaseOutCubic
# - EaseOutQuart
# - EaseOutQuint
# - EaseOutExpo
# - EaseOutCirc
# - Linear
# Specifying a `duration` of `0` will disable the visual bell.
#visual_bell:
# animation: EaseOutExpo
# duration: 0
# color: '#ffffff'
#selection:
#semantic_escape_chars: ",│`|:\"' ()[]{}<>\t"
# When set to `true`, selected text will be copied to the primary clipboard.
save_to_clipboard: true
# Allow terminal applications to change Alacritty's window title.
window.dynamic_title: true
cursor:
# Cursor style
# Values for `style`:
# - ▇ Block
# - _ Underline
# - | Beam
style: Underline
# Vi mode cursor style
# If the vi mode cursor style is `None` or not specified, it will fall back to
# the style of the active value of the normal cursor.
# See `cursor.style` for available options.
#vi_mode_style: None
# If this is `true`, the cursor will be rendered as a hollow box when the
# window is not focused.
#unfocused_hollow: true
# Thickness of the cursor relative to the cell width as floating point number
# from `0.0` to `1.0`.
#thickness: 0.15
# Live config reload (changes require restart)
live_config_reload: true
# Shell
# You can set `shell.program` to the path of your favorite shell, e.g. `/bin/fish`.
# Entries in `shell.args` are passed unmodified as arguments to the shell.
# Default:
# - (macOS) /bin/bash --login
# - (Linux/BSD) user login shell
# - (Windows) powershell
shell:
program: /usr/bin/fish
args:
- --login
# Startup directory
# Directory the shell is started in. If this is unset, or `None`, the working
# directory of the parent process will be used.
#working_directory: None
# WinPTY backend (Windows only)
# Alacritty defaults to using the newer ConPTY backend if it is available,
# since it resolves a lot of bugs and is quite a bit faster. If it is not
# available, the the WinPTY backend will be used instead.
# Setting this option to `true` makes Alacritty use the legacy WinPTY backend,
# even if the ConPTY backend is available.
#winpty_backend: false
# Send ESC (\x1b) before characters when alt is pressed.
#alt_send_esc: true
mouse:
# Click settings
# The `double_click` and `triple_click` settings control the time
# alacritty should wait for accepting multiple clicks as one double
# or triple click.
#double_click: { threshold: 300 }
#triple_click: { threshold: 300 }
# If this is `true`, the cursor is temporarily hidden when typing.
hide_when_typing: true
#url:
# URL launcher
# This program is executed when clicking on a text which is recognized as a URL.
# The URL is always added to the command as the last parameter.
# When set to `launcher: None`, URL launching will be disabled completely.
# Default:
# - (macOS) open
# - (Linux/BSD) xdg-open
# - (Windows) explorer
#launcher:
# program: xdg-open
# args: []
# URL modifiers
# These are the modifiers that need to be held down for opening URLs when clicking
# on them. The available modifiers are documented in the key binding section.
#modifiers: None
# Mouse bindings
# Mouse bindings are specified as a list of objects, much like the key
# bindings further below.
# To trigger mouse bindings when an application running within Alacritty captures the mouse, the
# `Shift` modifier is automatically added as a requirement.
# Each mouse binding will specify a:
# - `mouse`:
# - Middle
# - Left
# - Right
# - Numeric identifier such as `5`
# - `action` (see key bindings)
# And optionally:
# - `mods` (see key bindings)
#mouse_bindings:
# - { mouse: Middle, action: PasteSelection }
# Key bindings
# Key bindings are specified as a list of objects. For example, this is the
# default paste binding:
# `- { key: V, mods: Control|Shift, action: Paste }`
# Each key binding will specify a:
# - `key`: Identifier of the key pressed
# - A-Z
# - F1-F24
# - Key0-Key9
# A full list with available key codes can be found here:
# https://docs.rs/glutin/*/glutin/event/enum.VirtualKeyCode.html#variants
# Instead of using the name of the keys, the `key` field also supports using
# the scancode of the desired key. Scancodes have to be specified as a
# decimal number. This command will allow you to display the hex scancodes
# for certain keys:
# `showkey --scancodes`.
# Then exactly one of:
# - `chars`: Send a byte sequence to the running application
# The `chars` field writes the specified string to the terminal. This makes
# it possible to pass escape sequences. To find escape codes for bindings
# like `PageUp` (`"\x1b[5~"`), you can run the command `showkey -a` outside
# of tmux. Note that applications use terminfo to map escape sequences back
# to keys. It is therefore required to update the terminfo when changing an
# escape sequence.
# - `action`: Execute a predefined action
# - ToggleViMode
# - Copy
# - Paste
# - PasteSelection
# - IncreaseFontSize
# - DecreaseFontSize
# - ResetFontSize
# - ScrollPageUp
# - ScrollPageDown
# - ScrollLineUp
# - ScrollLineDown
# - ScrollToTop
# - ScrollToBottom
# - ClearHistory
# - Hide
# - Minimize
# - Quit
# - ToggleFullscreen
# - SpawnNewInstance
# - ClearLogNotice
# - ClearSelection
# - ReceiveChar
# - None
# (`mode: Vi` only):
# - Open
# - Up
# - Down
# - Left
# - Right
# - First
# - Last
# - FirstOccupied
# - High
# - Middle
# - Low
# - SemanticLeft
# - SemanticRight
# - SemanticLeftEnd
# - SemanticRightEnd
# - WordRight
# - WordLeft
# - WordRightEnd
# - WordLeftEnd
# - Bracket
# - ToggleNormalSelection
# - ToggleLineSelection
# - ToggleBlockSelection
# - ToggleSemanticSelection
# (macOS only):
# - ToggleSimpleFullscreen: Enters fullscreen without occupying another space
# (Linux/BSD only):
# - CopySelection: Copies into selection buffer
# - `command`: Fork and execute a specified command plus arguments
# The `command` field must be a map containing a `program` string and an
# `args` array of command line parameter strings. For example:
# `{ program: "alacritty", args: ["-e", "vttest"] }`
# And optionally:
# - `mods`: Key modifiers to filter binding actions
# - Command
# - Control
# - Option
# - Super
# - Shift
# - Alt
# Multiple `mods` can be combined using `|` like this:
# `mods: Control|Shift`.
# Whitespace and capitalization are relevant and must match the example.
# - `mode`: Indicate a binding for only specific terminal reported modes
# This is mainly used to send applications the correct escape sequences
# when in different modes.
# - AppCursor
# - AppKeypad
# - Alt
# A `~` operator can be used before a mode to apply the binding whenever
# the mode is *not* active, e.g. `~Alt`.
# Bindings are always filled by default, but will be replaced when a new
# binding with the same triggers is defined. To unset a default binding, it can
# be mapped to the `ReceiveChar` action. Alternatively, you can use `None` for
# a no-op if you do not wish to receive input characters for that binding.
# If the same trigger is assigned to multiple actions, all of them are executed
# at once.
key_bindings:
# (Windows, Linux, and BSD only)
- { key: C, mods: Control|Shift, action: Copy }
- { key: Insert, mods: Shift, action: PasteSelection }
- { key: Key0, mods: Control, action: ResetFontSize }
- { key: Equals, mods: Control, action: IncreaseFontSize }
- { key: Plus, mods: Control, action: IncreaseFontSize }
- { key: Minus, mods: Control, action: DecreaseFontSize }
#debug:
# Display the time it takes to redraw each frame.
#render_timer: false
# Keep the log file after quitting Alacritty.
#persistent_logging: false
# Log level
# Values for `log_level`:
# - None
# - Error
# - Warn
# - Info
# - Debug
# - Trace
#log_level: Warn
# Print all received window events.
#print_events: false
# Custom colorscheme fitting Sweetified theme
colors:
primary:
background: '0x0a1124'
foreground: '0xeec49a'
cursor:
text: '0x0a1124'
cursor: '0xeec49a'
normal:
black: '0x0a1124'
red: '0x5F4149'
green: '0xEB3247'
yellow: '0xBC4349'
blue: '0xF35645'
magenta: '0xF6A73B'
cyan: '0xFAD32F'
white: '0xeec49a'
bright:
black: '0xa6896b'
red: '0x5F4149'
green: '0xEB3247'
yellow: '0xBC4349'
blue: '0xF35645'
magenta: '0xF6A73B'
cyan: '0xFAD32F'
white: '0xeec49a'```
Kernel: 6.2.12-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=4350e34a-a170-4085-ab6b-dea58f40d93e rw rootflags=subvol=@
cryptdevice=UUID=0bfab363-815b-4b0d-90ba-bbed136e65a9:luks-0bfab363-815b-4b0d-90ba-bbed136e65a9
root=/dev/mapper/luks-0bfab363-815b-4b0d-90ba-bbed136e65a9 splash
systemd.unified_cgroup_hierarchy=1 loglevel=3 sysrq_always_enabled=1
nvidia-drm.modeset=1 nosgx ibt=off
Type: Desktop Mobo: ASUSTeK model: MAXIMUS IX HERO v: Rev 1.xx
serial: <superuser required> UEFI: American Megatrends v: 1301
date: 03/14/2018
Info: model: Intel Core i7-7700K bits: 64 type: MT MCP arch: Kaby Lake
model-id: 0x9E (158) stepping: 9 microcode: 0xF0
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 3841 high: 4805 min/max: 800/4500:5000 scaling:
driver: intel_pstate governor: performance cores: 1: 4801 2: 4802 3: 1027
4: 4200 5: 4200 6: 4805 7: 2093 8: 4800 bogomips: 67200
Device-1: NVIDIA GA102 [GeForce RTX 3080 Lite Hash Rate] vendor: eVga.com.
status: current (as of 2023-03) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 2 speed: 5 GT/s lanes: 16
link-max: gen: 4 speed: 16 GT/s ports: active: none off: DP-1,HDMI-A-1
empty: DP-2,DP-3 bus-ID: 01:00.0 chip-ID: 10de:2216 class-ID: 0300
compositor: kwin_x11 driver: X: loaded: nvidia gpu: nvidia,nvidia-nvswitch
Screen-1: 0 s-res: 4480x1440 s-dpi: 93 s-size: 1224x389mm (48.19x15.31")
s-diag: 1284mm (50.56")
Monitor-1: DP-1 mapped: DP-0 note: disabled pos: primary,top-left
model: Asus ROG PG279Q serial: <filter> built: 2017 res: 2560x1440 dpi: 109
gamma: 1.2 size: 598x336mm (23.54x13.23") diag: 686mm (27") ratio: 16:9
modes: max: 2560x1440 min: 640x480
Monitor-2: HDMI-A-1 mapped: HDMI-0 note: disabled pos: bottom-r
model: Asus VH242H serial: <filter> built: 2011 res: 1920x1080 hz: 60
dpi: 94 gamma: 1.2 size: 521x293mm (20.51x11.54") diag: 598mm (23.5")
API: OpenGL v: 4.6.0 NVIDIA 530.41.03 renderer: NVIDIA GeForce RTX
3080/PCIe/SSE2 direct-render: Yes
driver: snd_hda_intel bus-ID: 1-6:4 v: kernel alternate: snd_soc_avs
chip-ID: 1395:005e class-ID: 0300 bus-ID: 00:1f.3 serial: <filter>
Device-2: NVIDIA GA102 High Definition Audio vendor: eVga.com.
link-max: gen: 4 speed: 16 GT/s bus-ID: 01:00.1 chip-ID: 10de:1aef
Device-3: DSEA A/S GSX 1000 Main Audio type: USB
API: ALSA v: k6.2.12-zen1-1-zen status: kernel-api with: aoss
Device-2: Intel Wireless 8260 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 8086:24f3 class-ID: 0280
bus-ID: 1-14.1:8 chip-ID: 8087:0a2b class-ID: e001
address: <filter>
Local Storage: total: 13.42 TiB used: 474.28 GiB (3.5%)
ID-1: /dev/nvme0n1 maj-min: 259:6 vendor: Samsung model: SSD 960 EVO 1TB
lanes: 4 type: SSD serial: <filter> rev: 3B7QCXE7 temp: 33.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Samsung model: SSD 960 EVO 250GB
size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 type: SSD serial: <filter> rev: 3B7QCXE7 temp: 35.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 850 EVO 1TB
type: SSD serial: <filter> rev: 3B6Q scheme: GPT
ID-4: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 870 EVO 2TB
type: SSD serial: <filter> rev: 2B6Q scheme: GPT
ID-5: /dev/sdc maj-min: 8:32 vendor: Samsung model: SSD 850 EVO 500GB
ID-6: /dev/sdd maj-min: 8:48 vendor: Toshiba model: HDWE160 size: 5.46 TiB
block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s type: HDD
rpm: 7200 serial: <filter> rev: FS2A scheme: GPT
ID-7: /dev/sde maj-min: 8:64 type: USB vendor: Western Digital
model: WD40NDZW-11A8JS0 size: 3.64 TiB block-size: physical: 4096 B
logical: 512 B type: HDD rpm: 5400 serial: <filter> rev: 1034 scheme: GPT
ID-1: / raw-size: 300 GiB size: 300 GiB (100.00%) used: 48.8 GiB (16.3%)
mapped: luks-0bfab363-815b-4b0d-90ba-bbed136e65a9
ID-2: /boot/efi raw-size: 501 MiB size: 500 MiB (99.80%)
used: 724 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p2 maj-min: 259:8
ID-3: /home raw-size: 631.02 GiB size: 631.02 GiB (100.00%)
used: 425.48 GiB (67.4%) fs: btrfs dev: /dev/dm-1 maj-min: 254:1
mapped: luks-23daf038-216d-4bc5-bf5b-9ab9682afb7f
ID-4: /var/log raw-size: 300 GiB size: 300 GiB (100.00%)
used: 48.8 GiB (16.3%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
ID-5: /var/tmp raw-size: 300 GiB size: 300 GiB (100.00%)
ID-1: swap-1 type: zram size: 31.28 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 35.0 C mobo: N/A gpu: nvidia temp: 36 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 39%
Processes: 357 Uptime: 45m wakeups: 0 Memory: 31.28 GiB
used: 6.1 GiB (19.5%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7 Packages: 1867
pm: pacman pkgs: 1861 libs: 515 tools: pamac,paru pm: appimage pkgs: 0
pm: flatpak pkgs: 6 Shell: fish v: 3.6.1 default: Zsh v: 5.9
running-in: alacritty inxi: 3.3.26
System install date: 2021-11-26
Last full system update: 2023-05-02 ↻
Failed units: shadow.service```
