Broke up timeshift somehow and now `garuda-chroot -a` does not detect nvme drives also
Hello,
i broked restore snapshots i think and then grub puff too and now I'm trying to run the garuda-chroot and it is not detecting my nvme0 drive.
Advice wellcome thx
mount /dev/nvmeXYZ /mnt
garuda-chroot /mnt
Read
I have no idea if it will help, but I'd try resetting your bios to the factory default.
You will need to change some settings afterwards, such as:
Disable secure boot and fastboot.
Enable SATA AHCI mode.
Then you may want to reinstall grub and update-grub.
