Hello
Garuda Community
i have been trying to get my brightness to work on the laptop with no sucess.. i have spent the last few days from searching the web (Google and Arch Wiki) to asking for help in various discord communities (even installing arch linux and other various flavours) the only distro it seems to work on is ubuntu (its odd)
i have tried adding myself to the video group and adding the nvidia backlight to the 20-nvidia.conf file with no success
i have added keyboard.conf and optimus-manager.conf files incase there is somthing there that needs to be chaged that i am unaware of
my garuda-inxi file below
Kernel: 5.16.16-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=408275d2-8375-4ce7-ab5f-171c60a110f6 rw rootflags=subvol=@
resume=UUID=1e2fa55d-f2a7-4370-83dc-8fdf1cc6f4d2 loglevel=3
Type: Laptop System: Dell product: Dell G15 5515 v: 1.5.0
serial: <superuser required> Chassis: type: 10 v: 1.5.0
Mobo: Dell model: 0TGD6F v: A04 serial: <superuser required> UEFI: Dell
v: 1.5.0 date: 12/21/2021
ID-1: BAT1 charge: 53.2 Wh (100.0%) condition: 53.2/56.0 Wh (94.9%)
volts: 13.1 min: 11.4 model: Simplo 0x50,0x39,0x35,0x41,0x0B,0x0A,0x0004
type: Li-ion serial: <filter> status: full
Info: model: AMD Ryzen 5 5600H with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 3 family: 0x19 (25) model-id: 0x50 (80) stepping: 0
microcode: 0xA50000C
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 1881 high: 2400 min/max: 1200/3300 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 1915 2: 1909
3: 2400 4: 2055 5: 1488 6: 1915 7: 1915 8: 1912 9: 1742 10: 1913 11: 1658
12: 1757 bogomips: 79050
STIBP: always-on, RSB filling
Device-1: NVIDIA GA107M [GeForce RTX 3050 Mobile] vendor: Dell
driver: nvidia v: 510.54 alternate: nouveau,nvidia_drm pcie: gen: 3
speed: 8 GT/s lanes: 8 link-max: gen: 4 speed: 16 GT/s lanes: 16 ports:
active: none empty: HDMI-A-1 bus-ID: 01:00.0 chip-ID: 10de:25a2
Device-2: AMD Cezanne vendor: Dell driver: amdgpu v: kernel pcie: gen: 3
active: eDP-1 empty: DP-1 bus-ID: 06:00.0 chip-ID: 1002:1638
Device-3: Microdia Integrated_Webcam_HD type: USB driver: uvcvideo
bus-ID: 1-4:3 chip-ID: 0c45:6720 class-ID: 0e02
loaded: modesetting,nvidia gpu: amdgpu display-ID: :0 screens: 1
Monitor-1: eDP-1 model: ChiMei InnoLux 0x1522 built: 2020 res: 1920x1080
hz: 120 dpi: 142 gamma: 1.2 size: 344x193mm (13.54x7.6")
diag: 394mm (15.5") ratio: 16:9 modes: max: 1920x1080 min: 640x480
OpenGL: renderer: AMD RENOIR (LLVM 13.0.1 DRM 3.44 5.16.16-zen1-1-zen)
v: 4.6 Mesa 22.0.0 direct render: Yes
Device-1: NVIDIA driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s
lanes: 8 link-max: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 01:00.1
chip-ID: 10de:2291 class-ID: 0403
Device-2: AMD Renoir Radeon High Definition Audio vendor: Dell
link-max: gen: 4 speed: 16 GT/s bus-ID: 06:00.1 chip-ID: 1002:1637
Device-3: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Dell
alternate: snd_pci_acp3x,snd_pci_acp5x,snd_pci_acp6x pcie: gen: 3
speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 06:00.5
Device-4: AMD Family 17h/19h HD Audio vendor: Dell driver: snd_hda_intel
speed: 16 GT/s bus-ID: 06:00.6 chip-ID: 1022:15e3 class-ID: 0403
Device-1: Realtek RTL8125 2.5GbE vendor: Dell driver: r8169 v: kernel pcie:
gen: 2 speed: 5 GT/s lanes: 1 port: 2000 bus-ID: 03:00.0 chip-ID: 10ec:8125
Device-2: Intel Wi-Fi 6 AX200 vendor: Rivet Networks Killer™
driver: iwlwifi v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1
bus-ID: 04:00.0 chip-ID: 8086:2723 class-ID: 0280
bus-ID: 1-3:2 chip-ID: 8087:0029 class-ID: e001
Local Storage: total: 1.4 TiB used: 16.62 GiB (1.2%)
ID-1: /dev/nvme0n1 maj-min: 259:1 model: AITC FZKM SSD 512GB
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: U0914A0L
temp: 46.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 model: AITC FZKM SSD 1TB
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: 2107XKR
temp: 39.9 C scheme: GPT
ID-1: / raw-size: 460.09 GiB size: 460.09 GiB (100.00%)
used: 16.62 GiB (3.6%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:3
used: 588 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:2
ID-3: /home raw-size: 460.09 GiB size: 460.09 GiB (100.00%)
ID-4: /var/log raw-size: 460.09 GiB size: 460.09 GiB (100.00%)
ID-5: /var/tmp raw-size: 460.09 GiB size: 460.09 GiB (100.00%)
ID-1: swap-1 type: partition size: 16.55 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:4
ID-2: swap-2 type: zram size: 15.04 GiB used: 4.8 MiB (0.0%)
System Temperatures: cpu: N/A mobo: N/A gpu: amdgpu temp: 49.0 C
Processes: 377 Uptime: 12m wakeups: 372 Memory: 15.05 GiB
used: 2.6 GiB (17.3%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 Packages: pacman: 1712 lib: 514 Shell: fish v: 3.4.1
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.14
Garuda (2.5.6-2):
System install date: 2022-04-04
Last full system update: 2022-04-04 ↻
10-optimus-manager.conf
Section "Files"
ModulePath "/usr/lib/nvidia"
ModulePath "/usr/lib32/nvidia"
ModulePath "/usr/lib32/nvidia/xorg/modules"
ModulePath "/usr/lib32/xorg/modules"
ModulePath "/usr/lib64/nvidia/xorg/modules"
ModulePath "/usr/lib64/nvidia/xorg"
ModulePath "/usr/lib64/xorg/modules"
EndSection
Section "ServerLayout"
Identifier "layout"
Screen 0 "integrated"
Inactive "nvidia"
Option "AllowNVIDIAGPUScreens"
EndSection
Section "Device"
Identifier "integrated"
Driver "modesetting"
BusID "PCI:6:0:0"
Option "DRI" "3"
EndSection
Section "Screen"
Device "integrated"
EndSection
Section "Device"
Identifier "nvidia"
Driver "nvidia"
BusID "PCI:1:0:0"
Option "Coolbits" "28"
EndSection
Section "Screen"
Identifier "nvidia"
Device "nvidia"
EndSection
00-keyboard.conf
Section "InputClass"
Identifier "system-keyboard"
MatchIsKeyboard "on"
Option "XkbLayout" "au"
EndSection
