Hi all,
I need some help please because a pacman -Syu upgrade failed while the kernel was being installed (machine froze), and now cannot find the kernel when booting.
Ok, no problem, I will just boot from a BTRFS snapshot. But what I find is that the snapshot does boot, sort of, but only to a TTY. The problem is that the root partition is mounted read-only from the snapshot.
I searched the forum but no clues in there. I checked the grub entry for the snapshot but it doesn't seem to be instructing it to mount read-only. However every snapshot I've tried does only mount r/o.
Is there a way of changing the settings from live usb or something and telling it to mount as read-write when booting from a snapshot?
I managed to boot into it using a live-usb and chrooted into the install. I finished the pacman -Syu but on rebooting it still says the kernel cannot be found.
Thanks for any help.
sh-5.1# garuda-inxi
12System:
12Kernel 5.14.8-zen1-1-zen 12arch x86_64 12bits 64 12compiler gcc 12v 11.1.0
12parameters BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC misobasedir=garuda
misolabel=GARUDA_DR460NIZED_HARPYEAGLE quiet systemd.show_status=1 driver=free
nouveau.modeset=1 i915.modeset=1 radeon.modeset=1
12Console N/A 12wm kwin_x11 12Distro Garuda Linux 12base Arch Linux
12Machine:
12Type Laptop 12System LENOVO 12product 20AMS5AN10 12v ThinkPad X240 12serial <filter> 12Chassis 12type 10
12serial <filter>
12Mobo LENOVO 12model 20AMS5AN10 12serial <filter> 12UEFI-[Legacy] LENOVO 12v GIET98WW (2.48 )
12date 08/08/2019
12Battery:
12ID-1 BAT1 12charge 28.2 Wh (100.0%) 12condition 28.2/47.5 Wh (59.4%) 12volts 12.3 12min 10.8
12model SMP 45N1736 12type Li-ion 12serial <filter> 12status full
12CPU:
12Info 12model Intel Core i5-4300U 12socket rPGA988B (U3E1) 12note check 12bits 64 12type MT MCP
12arch Haswell 12gen core 4 12built 2013-15 12process Intel 22nm 12family 6 12model-id 0x45 (69) 12stepping 1
12microcode 0x26
12Topology 12cpus 1x 12cores 2 12tpc 2 12threads 4 12smt enabled 12cache 12L1 128 KiB
12desc d-2x32 KiB; i-2x32 KiB 12L2 512 KiB 12desc 2x256 KiB 12L3 3 MiB 12desc 1x3 MiB
12Speed (MHz) 12avg 1980 12high 2236 12min/max 800/2900 12base/boost 1900/1900 12scaling
12driver intel_cpufreq 12governor performance 12volts 0.7 V 12ext-clock 100 MHz 12cores 121 1896 122 2236
123 1896 124 1895 12bogomips 19953
12Flags avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
12Vulnerabilities
12Type itlb_multihit 12status KVM: VMX disabled
12Type l1tf 12mitigation PTE Inversion; VMX: conditional cache flushes, SMT vulnerable
12Type mds 12mitigation Clear CPU buffers; SMT vulnerable
12Type meltdown 12mitigation PTI
12Type spec_store_bypass 12mitigation Speculative Store Bypass disabled via prctl and seccomp
12Type spectre_v1 12mitigation usercopy/swapgs barriers and __user pointer sanitization
12Type spectre_v2
12mitigation Full generic retpoline, IBPB: conditional, IBRS_FW, STIBP: conditional, RSB filling
12Type srbds 12mitigation Microcode
12Type tsx_async_abort 12status Not affected
12Graphics:
12Device-1 Intel Haswell-ULT Integrated Graphics 12vendor Lenovo ThinkPad X240 12driver i915 12v kernel
12arch Gen7.5 12process Intel 22nm 12built 2013 12ports 12active DP-4,eDP-1
12empty DP-1, DP-2, DP-3, DP-5, HDMI-A-1, HDMI-A-2 12bus-ID 00:02.0 12chip-ID 8086:0a16
12class-ID 0300
12Device-2 Chicony Integrated Camera 12type USB 12driver uvcvideo 12bus-ID 2-8:6 12chip-ID 04f2:b39a
12class-ID 0e02
12Display 12server X.org 12v 1.21.1.3 12with Xwayland 12v 22.1.2 12compositor kwin_x11 12driver 12X 12loadedN/A
12unloaded modesetting 12failed intel 12alternate fbdev,vesa 12gpu i915 12note X driver n/a 12display-ID :0
12Monitor-1 DP-4 12model Samsung S23B300 12serial <filter> 12built 2012 12res 1920x1080 12dpi 96 12gamma 1.2
12size 510x287mm (20.08x11.3") 12diag 585mm (23") 12ratio 16:9 12modes 12max 1920x1080 12min 720x400
12Monitor-2 eDP-1 12model AU Optronics 0x106c 12built 2012 12res 1366x768 12dpi 126 12gamma 1.2
12size 276x155mm (10.87x6.1") 12diag 317mm (12.5") 12ratio 16:9 12modes 1366x768
12Message Unable to show GL data. Required tool glxinfo missing.
12Audio:
12Device-1 Intel Haswell-ULT HD Audio 12vendor Lenovo ThinkPad X240 12driver snd_hda_intel
12bus-ID 2-2:2 12v kernel 12bus-ID 00:03.0 12chip-ID 20b1:3008 12class-ID fe01 12chip-ID 8086:0a0c
12serial <filter> 12class-ID 0403
12Device-2 Intel 8 Series HD Audio 12vendor Lenovo ThinkPad X240 12driver snd_hda_intel 12v kernel
12bus-ID 00:1b.0 12chip-ID 8086:9c20 12class-ID 0403
12Device-3 XMOS iFi (by AMR) HD USB Audio 12type USB 12driver snd-usb-audio
12Sound Server-1 ALSA 12v k5.14.8-zen1-1-zen 12running yes
12Sound Server-2 PulseAudio 12v 16.0 12running no
12Sound Server-3 PipeWire 12v 0.3.52 12running yes
12Network:
12Device-1 Intel Ethernet I218-LM 12vendor Lenovo ThinkPad X240 12driver e1000e 12v kernel 12port 3080
12bus-ID 00:19.0 12chip-ID 8086:155a 12class-ID 0200
12IF enp0s25 12state down 12mac <filter>
12Device-2 Intel Wireless 7260 12driver iwlwifi 12v kernel 12pcie 12gen 1 12speed 2.5 GT/s 12lanes 1
12bus-ID 03:00.0 12chip-ID 8086:08b2 12class-ID 0280
12IF wlp3s0 12state up 12mac <filter>
12Bluetooth:
12Device-1 Intel Bluetooth wireless interface 12type USB 12driver btusb 12v 0.8 12bus-ID 2-7:4
12chip-ID 8087:07dc 12class-ID e001
12Report bt-adapter 12ID hci0 12rfk-id 1 12state up 12address N/A
12Drives:
12Local Storage 12total 4.16 TiB 12used 69.77 GiB (1.6%)
12SMART Message Required tool smartctl not installed. Check --recommends
12ID-1 /dev/sda 12maj-min 8:0 12vendor Netac 12model SSD 512GB 12size 476.94 GiB 12block-size
12physical 512 B 12logical 512 B 12speed 6.0 Gb/s 12type SSD 12serial <filter> 12rev 0326
12ID-2 /dev/sdb 12maj-min 8:16 12type USB 12model USB DISK 3.0 12size 57.7 GiB 12block-size 12physical 512 B
12logical 512 B 12type N/A 12serial <filter> 12rev PMAP
12ID-3 /dev/sdc 12maj-min 8:32 12type USB 12vendor Western Digital 12model WD My Passport 25E2
12size 3.64 TiB 12block-size 12physical 4096 B 12logical 512 B 12type N/A 12serial <filter> 12rev 4005
12Partition:
12ID-1 / 12raw-size 87.89 GiB 12size 87.89 GiB (100.00%) 12used 69.77 GiB (79.4%) 12fs btrfs
12block-size 4096 B 12dev /dev/sda7 12maj-min 8:7
12Swap:
12Kernel 12swappiness 133 (default 60) 12cache-pressure 100 (default)
12ID-1 swap-1 12type zram 12size 7.44 GiB 12used 174.2 MiB (2.3%) 12priority 100 12dev /dev/zram0
12Sensors:
12System Temperatures 12cpu 80.0 C 12mobo N/A
12Fan Speeds (RPM) 12fan-1 4934
12Info:
12Processes 229 12Uptime 11m 12wakeups 1 12Memory 7.44 GiB 12used 3.86 GiB (51.9%) 12Init systemd 12v 251
12default graphical 12tool systemctl 12Compilers 12gcc 12.1.0 12clang 13.0.1 12Packages 12pacman 1981 12lib 437
12flatpak 0 12Client 12inxi 3.3.18
Garuda (2.6.3-2):
System install date: 2022-06-16
Last full system update: 2022-06-16 ↻
Relevant software: NetworkManager connman
Running in chroot, ignoring command 'list-units'
