Hi There,
I’m relatively new to Garuda Linux and Arch but not Linux in general.
I’m looking for some insight from those experienced with the Distro around what seems to be a snapper corruption that is impacting all snapshots (past present and future).
I’ve provided some screenshots for examples and I do think I could manually restore them if I had to but I really liked this feature of being able to boot from snapshots on the fly.
Is there any way to rebuild snapper or even core garuda packages, maybe someone could point me in the right direction around dependencies for root cause analysis?
Closest topic I could reference was this and it was sort of inconclusive (seems most were concerned around some sort of file system corruption) - Booting Into Snapshot: Read-Only File System - #8 by BluishHumility
Kernel: 6.5.7-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=56d1f10b-cb16-46c0-9169-6bc3151b9b5d rw rootflags=subvol=@
intel_iommu=on iommu=pt isolcpus rcu_nocbs transparent_hugepage=never
quiet nvidia-drm.modeset=1 quiet rd.udev.log_priority=3
vt.global_cursor_default=0
resume=UUID=45d3cd5d-df18-46f9-8497-133a5a31ae08 loglevel=3 ibt=off
Desktop: KDE Plasma v: 5.27.8 tk: Qt v: 5.15.11 wm: kwin_x11 vt: 2
Type: Desktop Mobo: ASUSTeK model: MAXIMUS IX HERO v: Rev 1.xx
serial: <superuser required> UEFI: American Megatrends v: 1301
date: 03/14/2018
Info: model: Intel Core i7-7700K bits: 64 type: MT MCP arch: Kaby Lake
model-id: 0x9E (158) stepping: 9 microcode: 0xF4
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 1200 high: 1201 min/max: 800/4800 scaling:
driver: intel_pstate governor: powersave cores: 1: 1200 2: 1200 3: 1200
4: 1200 5: 1200 6: 1200 7: 1201 8: 1200 bogomips: 67200
Device-1: NVIDIA GA102 [GeForce RTX 3080 Lite Hash Rate] vendor: Gigabyte
driver: nvidia v: 535.113.01 alternate: nouveau,nvidia_drm non-free: 535.xx+
status: current (as of 2023-09) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-23 pcie: gen: 2 speed: 5 GT/s lanes: 16
link-max: gen: 4 speed: 16 GT/s ports: active: none off: DP-1,DP-2
empty: DP-3, HDMI-A-1, HDMI-A-2, HDMI-A-3 bus-ID: 01:00.0
chip-ID: 10de:2216 class-ID: 0300
Device-2: Lite-On HP Full-HD Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6:3 chip-ID: 04ca:7078
Device-3: Oculus VR Rift CV1 Sensor driver: uvcvideo type: USB rev: 3.0
speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 2-5:3 chip-ID: 2833:0211
class-ID: ef00 serial: <filter>
alternate: fbdev,nv,vesa gpu: nvidia,nvidia-nvswitch display-ID: :0
Screen-1: 0 s-res: 7040x1440 s-dpi: 91 s-size: 1962x401mm (77.24x15.79")
s-diag: 2003mm (78.84")
Monitor-1: DP-1 mapped: DP-0 note: disabled pos: primary,right
model: Samsung LS49AG95 serial: <filter> built: 2021 res: 5120x1440 hz: 240
dpi: 130048 gamma: 1.2 size: 1x1mm (0.04x0.04") diag: 1239mm (48.8")
modes: max: 3840x1080 min: 640x480
Monitor-2: DP-2 note: disabled pos: left model: Dell P2419H
serial: <filter> built: 2019 res: 1920x1080 hz: 60 dpi: 93 gamma: 1.2
max: 1920x1080 min: 640x480
API: EGL v: 1.5 hw: drv: nvidia platforms: gbm: drv: nvidia
API: OpenGL v: 4.6.0 vendor: nvidia v: 535.113.01 glx-v: 1.4
direct-render: yes renderer: NVIDIA GeForce RTX 3080/PCIe/SSE2
memory: 9.77 GiB
API: Vulkan v: 1.3.264 layers: 14 device: 0 type: discrete-gpu
name: NVIDIA GeForce RTX 3080 driver: nvidia v: 535.113.01
device-ID: 10de:2216 surfaces: xcb,xlib device: 1 type: discrete-gpu
device-ID: 10de:2216 surfaces: xcb,xlib device: 2 type: cpu name: llvmpipe
Device-2: NVIDIA GA102 High Definition Audio vendor: Gigabyte
link-max: gen: 4 speed: 16 GT/s bus-ID: 01:00.1 chip-ID: 10de:1aef
Device-3: JMTek LLC. LCS USB Audio
lanes: 1 mode: 1.1 bus-ID: 1-7:5 chip-ID: 0c76:2018 class-ID: 0300
API: ALSA v: k6.5.7-zen1-1-zen status: kernel-api
Server-2: PipeWire v: 0.3.82 status: active with: 1: pipewire-pulse
IF-ID-1: br0 state: up speed: 10000 Mbps duplex: unknown mac: <filter>
IF-ID-2: vnet0 state: unknown speed: 10000 Mbps duplex: full mac: <filter>
Local Storage: total: 16.84 TiB used: 10.1 TiB (60.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 950 PRO 512GB
lanes: 4 tech: SSD serial: <filter> fw-rev: 2B0QBXX7 temp: 27.9 C
ID-2: /dev/nvme1n1 maj-min: 259:2 vendor: Samsung model: SSD 980 PRO 2TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 5B2QGXA7 temp: 28.9 C
ID-3: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000DX002-2DV164
tech: HDD rpm: 7200 serial: <filter> fw-rev: CC41 scheme: GPT
ID-4: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST4000DX001-1CE168
tech: HDD rpm: 5980 serial: <filter> fw-rev: DA11 scheme: GPT
ID-5: /dev/sdc maj-min: 8:32 vendor: Seagate model: ST10000VN0004-1ZD101
size: 9.1 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: HDD rpm: 7200 serial: <filter> fw-rev: SC60 scheme: GPT
ID-1: / raw-size: 1.75 TiB size: 1.75 TiB (100.00%) used: 893.82 GiB (49.8%)
fs: btrfs dev: /dev/nvme1n1p2 maj-min: 259:4
used: 576 KiB (0.2%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:3
ID-3: /home raw-size: 1.75 TiB size: 1.75 TiB (100.00%)
used: 893.82 GiB (49.8%) fs: btrfs dev: /dev/nvme1n1p2 maj-min: 259:4
ID-4: /var/log raw-size: 1.75 TiB size: 1.75 TiB (100.00%)
ID-5: /var/tmp raw-size: 1.75 TiB size: 1.75 TiB (100.00%)
ID-1: swap-1 type: zram size: 62.73 GiB used: 15.2 MiB (0.0%)
ID-2: swap-2 type: partition size: 69.01 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme1n1p3 maj-min: 259:5
System Temperatures: cpu: 34.0 C mobo: N/A gpu: nvidia temp: 23 C
Processes: 332 Uptime: 12h 52m wakeups: 1 Memory: total: 64 GiB note: est.
available: 62.73 GiB used: 52.95 GiB (84.4%) Init: systemd v: 254
pm: pacman pkgs: 1633 libs: 483 tools: octopi,paru Shell: fish v: 3.6.1
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.30
Garuda (2.6.17-1):
System install date: 2023-10-06
Last full system update: 2023-10-15
