After running garuda-update today, on boot, the system was hanging indefinitely (I believe on "Accessing RAM", second line in the boot screen). After several restarts, I managed to get to the login screen. My keyboard did not work at all, including when trying to access terminal. The mouse did, however. On restart, I received:
Device descriptor read/64, error -110
Device descriptor read/8, error -110
I restored snapshot from before update, and I am able to login and my keyboard works. The problem was replicated when I ran the update again. So far, the solution is to not update, but finding the source of the bug might allow me to update somehow. Please let me know if I should post any outputs, and I'll add it to this message.
Apologies if this is a bit incoherent; Am very ill and on some hefty medications.
Please, post your garuda-inxi.
Post also as text, the log when you do garuda-update, just copy and paste here, but do not update, you know .
Sorry, I was absolutely zonked and forgot to add those. Feel better today, so hopefully I can follow basic instructions lol.
garuda-update
:: Synchronizing package databases…
garuda 96.6 KiB 63.1 KiB/s 00:02 [-------------------------------------------] 100%
core 131.9 KiB 819 KiB/s 00:00 [-------------------------------------------] 100%
extra 8.3 MiB 7.01 MiB/s 00:01 [-------------------------------------------] 100%
multilib 140.7 KiB 890 KiB/s 00:00 [-------------------------------------------] 100%
chaotic-aur 2.8 MiB 1598 KiB/s 00:02 [-------------------------------------------] 100%
→ Refreshing mirrorlists using rate-mirrors, please be patient…
Error: error decoding response body: invalid value: integer -8, expected u64 at line 1 column 146607
Failed to update mirrorlist
:: Starting full system upgrade…
warning: reflector-simple: local (2.0-1.1) is newer than garuda (2.0-1)
resolving dependencies…
looking for conflicting packages…
Packages (38) amd-ucode-20230625.ee91452d-1 autorandr-1.14-1 freetype2-2.13.1-1 garuda-wallpapers-r86.e1486a1-1
imagemagick-7.1.1.12-1 iproute2-6.4.0-1 lib32-brotli-1.0.9-12 lib32-freetype2-2.13.1-1
lib32-libpng-1.6.40-1 lib32-libssh2-1.11.0-1 lib32-mesa-23.1.3-1 lib32-util-linux-2.39.1-1
lib32-vulkan-icd-loader-1.3.255-1 libopenmpt-0.7.2-1 libpng-1.6.40-1 libssh2-1.11.0-1
linux-firmware-20230625.ee91452d-1 linux-firmware-whence-20230625.ee91452d-1 mercurial-6.4.5-1 mesa-23.1.3-1
openexr-3.1.9-1 openfortivpn-1.20.5-1 pamac-aur-11.0.1-1 pcsclite-2.0.0-1 procps-ng-4.0.3-1
python-cairocffi-1.5.0-1 python-cryptography-41.0.1-2 python-setuptools-1:68.0.0-1 rate-mirrors-0.15.2-1
reflector-2023-1 sddm-0.20.0-1 util-linux-2.39.1-1 util-linux-libs-2.39.1-1 vulkan-headers-1:1.3.255-1
vulkan-icd-loader-1.3.255-1 vulkan-tools-1.3.255-1 wine-8.11-1 xterm-383-1
Total Download Size: 216.46 MiB
Total Installed Size: 1071.15 MiB
Net Upgrade Size: 2.30 MiB
Kernel: 6.3.9-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
root=UUID=07673fcd-7381-4a95-904f-ae4a01aa632b rw rootflags=subvol=@
loglevel=3 ibt=off
Desktop: Qtile v: 0.22.1 wm: LG3D vt: 1 dm: SDDM Distro: Garuda Linux
Type: Desktop Mobo: Micro-Star model: B450 TOMAHAWK MAX (MS-7C02) v: 1.0
serial: UEFI: American Megatrends LLC. v: 3.F1
date: 07/05/2022
Info: model: AMD Ryzen 9 5900X bits: 64 type: MT MCP arch: Zen 3+ gen: 4
L3: 64 MiB desc: 2x32 MiB
Speed (MHz): avg: 2472 high: 3700 min/max: 2200/4950 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 3700 2: 2200
3: 2883 4: 2200 5: 2200 6: 2200 7: 2200 8: 2200 9: 2200 10: 2200 11: 2200
12: 2200 13: 2200 14: 3700 15: 2880 16: 2880 17: 2200 18: 2200 19: 3700
20: 2200 21: 2200 22: 2200 23: 2200 24: 2200 bogomips: 177605
Device-1: NVIDIA TU104 [GeForce RTX 2060] vendor: Micro-Star MSI
driver: nvidia v: 535.54.03 alternate: nouveau,nvidia_drm non-free: 530.xx+
status: current (as of 2023-05) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-22 pcie: gen: 2 speed: 5 GT/s lanes: 4
link-max: lanes: 16 bus-ID: 25:00.0 chip-ID: 10de:1e89 class-ID: 0300
Display: x11 server: X.Org v: 21.1.8 compositor: Picom v: git-c4107
driver: X: loaded: nvidia gpu: nvidia display-ID: :0 screens: 1
Screen-1: 0 s-res: 4480x1440 s-dpi: 95 s-size: 1198x389mm (47.17x15.31")
s-diag: 1260mm (49.59")
Monitor-1: DP-0 pos: bottom-l res: 1920x1080 hz: 60 dpi: 96
size: 510x287mm (20.08x11.3") diag: 585mm (23.04") modes: N/A
Monitor-2: DP-4 pos: primary,top-right res: 2560x1440 hz: 60 dpi: 109
size: 597x336mm (23.5x13.23") diag: 685mm (26.97") modes: N/A
API: OpenGL v: 4.6.0 NVIDIA 535.54.03 renderer: NVIDIA GeForce RTX
2060/PCIe/SSE2 direct-render: Yes
Device-1: NVIDIA TU104 HD Audio vendor: Micro-Star MSI driver: snd_hda_intel
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 4 link-max: lanes: 16
bus-ID: 25:00.1 chip-ID: 10de:10f8 class-ID: 0403
bus-ID: 27:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Logitech G733 Gaming Headset
lanes: 1 mode: 1.1 bus-ID: 1-9:3 chip-ID: 046d:0ab5 class-ID: 0300
API: ALSA v: k6.3.9-zen1-1-zen status: kernel-api
Server-2: PipeWire v: 0.3.71 status: active with: 1: pipewire-pulse
IF: enp34s0 state: up speed: 1000 Mbps duplex: full mac:
Local Storage: total: 2.73 TiB used: 758.65 GiB (27.1%)
model: WDS100T3X0C-00SJG0 size: 931.51 GiB block-size: physical: 512 B
logical: 512 B speed: 31.6 Gb/s lanes: 4 tech: SSD serial:
fw-rev: 111110WD temp: 36.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000DM008-2FR102
tech: HDD rpm: 7200 serial: fw-rev: 0001 scheme: GPT
used: 27.8 GiB (3.0%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
System Temperatures: cpu: 42.4 C mobo: N/A gpu: nvidia temp: 35 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 30%
Processes: 423 Uptime: 4m wakeups: 0 Memory: available: 31.27 GiB
used: 2.96 GiB (9.5%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 13.1.1 Packages: pm: pacman pkgs: 1288
libs: 416 tools: pamac,paru Shell: fish v: 3.6.1 default: Bash v: 5.1.16
running-in: alacritty inxi: 3.3.27
System install date: 2023-05-24
Last full system update: 2023-06-26
filo
28 June 2023 14:46
4
Try removing splash from the kernel boot parameters.
There are several recent topics about it.
It's not necessarily your same issue. You managed to log-in and experienced a different problem. But you never can say...
If it works and you want the plymouth splash screen back now (before the issue is fixed upstream), you'll have to install plymouth which will replace plymouth-git, which seems to be the culprit.
If I just uninstall plymouth-git and install plymouth, will it stay that way on updates? Do I add the following line to /etc/default/grub?
GRUB_CMDLINE_LINUX_DEFAULT=“quiet splash rd.udev.log_priority=3 vt.global_cursor_default=0 systemd.unified_cgroup_hierarchy=1 loglevel=3”
filo
28 June 2023 14:54
6
We still don't know if that's your problem, so I suggest that you first test the removed splash on a single boot (not permanent).
This should be done when your system is updated, so unbootable, of course.
When you are in the grub line that you want to use, press button E, go to the line starting with linux and remove splash, then CTRL+x
If it works (you can boot), you can easily set this as permanent with the Garuda Boot Options tool in the Kernel parameters field. Or, at that point, you can replace plymouth-git with plymouth and not remove splash, since we have a confirmation that you have the same issue, so the same solution(s) work.
Fixed on the single boot, went into boot options and made permanent. Restarted to double check, still works. I have two garuda boot options in the grub menu now, but it's not a big deal. Thanks so much!
Thanks, everyone's been awesome!
system
Closed
30 June 2023 16:59
10
