Guys, I really hope you’d be so kind as to help me. I’m a noob, and I’m struggling to resolve the issue. I have tried a meaningful number of solutions from the forum, and at some point I realized that I am risking messing something up severely.
The crux of the problem is that several months ago my system stopped loading, freezing at "loading initial ramdisk". Thinking that it may be some temporary package problem I reverted back to a snapshot that worked and stayed on it since. But the problem isn't resolving.
I am dual-booting with Windows (I know Garuda isn't supposed to be, but it had been working fine).
root=UUID=51f78b03-ce2c-4d81-8364-4f8c1b537f00 rw rootflags=subvol=@
Type: Desktop Mobo: ASUSTeK model: ROG STRIX X570-E GAMING v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 3604
date: 04/14/2021
Info: model: AMD Ryzen 9 5900X bits: 64 type: MT MCP arch: Zen 3
family: 0x19 (25) model-id: 0x21 (33) stepping: 0 microcode: 0xA201009
L3: 64 MiB desc: 2x32 MiB
Speed (MHz): avg: 3214 high: 4581 min/max: 2200/4950 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 3603 2: 3511
3: 3141 4: 3048 5: 2573 6: 3021 7: 2873 8: 3711 9: 4581 10: 3524 11: 2887
12: 3590 13: 3966 14: 2885 15: 2312 16: 2870 17: 3271 18: 2871 19: 3488
20: 2875 21: 3213 22: 2870 23: 2873 24: 3592 bogomips: 177261
STIBP: always-on, RSB filling
Device-1: AMD Navi 21 [Radeon RX 6800/6800 XT / 6900 XT] vendor: ASRock
driver: amdgpu v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 ports:
active: DP-2 empty: DP-1,DP-3,HDMI-A-1 bus-ID: 0d:00.0 chip-ID: 1002:73bf
loaded: amdgpu unloaded: modesetting,radeon alternate: fbdev,vesa
s-diag: 1165mm (45.88")
Monitor-1: DP-2 mapped: DisplayPort-1 model: ROG XG27UQ serial: <filter>
built: 2020 res: 3840x2160 dpi: 164 gamma: 1.2
size: 596x335mm (23.46x13.19") diag: 684mm (26.9") ratio: 16:9 modes:
max: 3840x2160 min: 720x400
OpenGL: renderer: AMD Radeon RX 6800 XT (sienna_cichlid LLVM 13.0.1 DRM
3.44 5.17.1-zen1-1-zen)
v: 4.6 Mesa 22.0.0 direct render: Yes
Device-1: AMD Navi 21 HDMI Audio [Radeon RX 6800/6800 XT / 6900 XT]
bus-ID: 0d:00.1 chip-ID: 1002:ab28 class-ID: 0403
bus-ID: 0f:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-1: Intel Wi-Fi 6 AX200 driver: N/A modules: iwlwifi pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 05:00.0 chip-ID: 8086:2723 class-ID: 0280
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: e000 bus-ID: 06:00.0
Device-3: Intel I211 Gigabit Network vendor: ASUSTeK driver: igb
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 07:00.0
bus-ID: 1-6:4 chip-ID: 8087:0029 class-ID: e001
Local Storage: total: 1.93 TiB used: 323.58 GiB (16.4%)
speed: 63.2 Gb/s lanes: 4 type: SSD serial: <filter> rev: 2B2QGXA7
temp: 51.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:5 vendor: Samsung model: SSD 980 PRO 1TB
temp: 56.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 type: USB vendor: Kingston
model: DataTraveler 3.0 size: 115.33 GiB block-size: physical: 512 B
logical: 512 B type: N/A serial: <filter> rev: 1100 scheme: MBR
used: 323.58 GiB (34.7%) fs: btrfs dev: /dev/nvme1n1p2 maj-min: 259:7
used: 576 KiB (0.2%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:6
ID-1: swap-1 type: zram size: 31.31 GiB used: 883 MiB (2.8%)
System Temperatures: cpu: 43.0 C mobo: 48.0 C gpu: amdgpu temp: 57.0 C
mem: 58.0 C
Processes: 494 Uptime: 3d 8h 4m wakeups: 1 Memory: 31.31 GiB
used: 13.37 GiB (42.7%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 1847 lib: 478 Shell: Zsh
v: 5.8.1 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.14
Garuda (2.5.6-2):
System install date: 2021-12-05
Last full system update: 2022-03-29
Is partially upgraded: Yes
What didn't work for me:
- Computer doesn’t boot, boots to a black screen, or stops at a message
- Stuck at 'Loading initial ramdisk' while booting
- Boot stuck on linux-zen
- A number of times a similar problem was caused by Nvidia, but my GPU is AMD.
When I was messing with the solutions offered in the last post I acquired a duplicated entry in grub and then some time later my Windows entry disappeared from there. I've been able to restore it in grub through some advice on this forum, but I am now afraid to mess around unsupervised.
