output of garuda-inxi
Kernel: 6.0.12-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=aeb3c7e0-45af-4344-ba3f-05339ad86d76
rw rootflags=subvol=@ rd.udev.log_priority=3 vt.global_cursor_default=0 loglevel=3 ibt=off
Console: tty 2 Distro: Garuda Linux base: Arch Linux
Type: Desktop Mobo: Gigabyte model: B550M DS3H AC v: x.x serial: <superuser required>
UEFI: American Megatrends LLC. v: F15 date: 07/29/2022
Info: model: AMD Ryzen 7 5800X bits: 64 type: MT MCP arch: Zen 3 gen: 4 level: v3 note: check
built: 2021-22 process: TSMC n7 (7nm) family: 0x19 (25) model-id: 0x21 (33) stepping: 0
microcode: 0xA201016
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache: L1: 512 KiB
desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 3924 high: 4834 min/max: 2200/4850 boost: enabled scaling:
driver: acpi-cpufreq governor: performance cores: 1: 3851 2: 3800 3: 3800 4: 3800 5: 3800
6: 4834 7: 3800 8: 3800 9: 3800 10: 3866 11: 3800 12: 3800 13: 3865 14: 4444 15: 3872 16: 3853
bogomips: 121380
Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, IBRS_FW, STIBP: always-on, RSB
filling, PBRSB-eIBRS: Not affected
Device-1: NVIDIA TU116 [GeForce GTX 1650 SUPER] vendor: ASUSTeK driver: N/A alternate: nouveau
non-free: 525.xx+ status: current (as of 2022-12) arch: Turing code: TUxxx process: TSMC 12nm FF
built: 2018-22 pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3 speed: 8 GT/s
bus-ID: 06:00.0 chip-ID: 10de:2187 class-ID: 0300
Display: server: X.org v: 1.21.1.5 with: Xwayland v: 22.1.6 driver: N/A tty: 102x38
API: OpenGL Message: GL data unavailable in console. Try -G --display
Device-1: NVIDIA TU116 High Definition Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3 speed: 8 GT/s bus-ID: 06:00.1
chip-ID: 10de:1aeb class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: Gigabyte driver: snd_hda_intel v: kernel pcie:
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 08:00.4 chip-ID: 1022:1487 class-ID: 0403
Sound API: ALSA v: k6.0.12-zen1-1-zen running: yes
Sound Server-2: PipeWire v: 0.3.61 running: no
Device-1: Intel Dual Band Wireless-AC 3168NGW [Stone Peak] driver: iwlwifi v: kernel pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 04:00.0 chip-ID: 8086:24fb class-ID: 0280
Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Gigabyte
driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 05:00.0
Device-1: Intel Wireless-AC 3168 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-9:4
chip-ID: 8087:0aa7 class-ID: e001
Local Storage: total: 476.94 GiB used: 395.58 GiB (82.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: SSDPEKNW512G8 size: 476.94 GiB
rev: 002C temp: 42.9 C scheme: GPT
ID-1: / raw-size: 476.64 GiB size: 476.64 GiB (100.00%) used: 395.58 GiB (83.0%) fs: btrfs
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 608 KiB (0.2%) fs: vfat
ID-3: /home raw-size: 476.64 GiB size: 476.64 GiB (100.00%) used: 395.58 GiB (83.0%) fs: btrfs
ID-4: /var/log raw-size: 476.64 GiB size: 476.64 GiB (100.00%) used: 395.58 GiB (83.0%)
ID-5: /var/tmp raw-size: 476.64 GiB size: 476.64 GiB (100.00%) used: 395.58 GiB (83.0%)
ID-1: swap-1 type: zram size: 15.52 GiB used: 256 KiB (0.0%) priority: 100 dev: /dev/zram0
System Temperatures: cpu: 51.0 C mobo: N/A
Processes: 334 Uptime: 1m wakeups: 0 Memory: 15.52 GiB used: 1.53 GiB (9.9%) Init: systemd
v: 252 default: graphical tool: systemctl Compilers: gcc: 12.2.0 alt: 11 clang: 14.0.6
Packages: 2178 pm: nix-default pkgs: 0 pm: nix-sys pkgs: 0 pm: nix-usr pkgs: 0 pm: pacman
pkgs: 2177 libs: 457 tools: gnome-software,octopi,pamac,paru,yay pm: flatpak pkgs: 1 Shell: Zsh
v: 5.9 running-in: tty 2 inxi: 3.3.24
e[1;34mGaruda (2.6.10-1):e[0m
e[1;34m System install date:e[0m 2022-01-29
e[1;34m Last full system update:e[0m 2022-12-14
e[1;34m Is partially upgraded: e[0m No
e[1;34m Relevant software: e[0m NetworkManager
e[1;34m Windows dual boot: e[0m No/Undetected
e[1;34m Snapshots: e[0m Snapper
e[1;34m Failed units: e[0m xbindkeys-startup.service
output of startx
X.Org X Server 1.21.1.5
X Protocol Version 11, Revision 0
Current Operating System: Linux jbh5 6.0.12-zen1-1-zen #1 ZEN SMP PREEMPT_DYNAMIC Thu, 08 Dec 2022 11:03:40 +0000 x86_64
Kernel command line: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=aeb3c7e0-45af-4344-ba3f-05339ad86d76 rw rootflags=subvol=@ rd.udev.log_priority=3 vt.global_cursor_default=0 loglevel=3 ibt=off
Current version of pixman: 0.42.2
Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
(==) Log file: "/var/log/Xorg.0.log", Time: Wed Dec 14 23:11:54 2022
(==) Using config file: "/etc/X11/xorg.conf"
(==) Using config directory: "/etc/X11/xorg.conf.d"
(==) Using system config directory "/usr/share/X11/xorg.conf.d"
(EE)
Fatal server error:
(EE) no screens found(EE)
(EE)
Please consult the The X.Org Foundation support
at http://wiki.x.org
for help.
(EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
(EE)
(EE) Server terminated with error (1). Closing log file.
xinit: giving up
xinit: unable to connect to X server: Connection refused
xinit: server error
output of mhwd -l
e[1me[31m> e[m0000:06:00.0 (0300:10de:2187) Display controller nVidia Corporation:
NAME VERSION FREEDRIVER TYPE
video-nvidia-dkms 2022.11.30 false PCI
video-nvidia-470xx-dkms 2022.11.30 false PCI
video-linux 2021.08.29 true PCI
video-modesetting 2020.07.13 true PCI
video-vesa 2017.03.12 true PCI
e[1me[31m> e[m0000:05:00.0 (0200:10ec:8168) Network controller Realtek Semiconductor Co., Ltd.:
network-r8168 2020.05.22 true PCI
output of sudo pacman -Qs nvidia
local/egl-wayland 2:1.1.11-2
EGLStream-based Wayland external platform
local/garuda-nvidia-config 1:r63.2f652e8-2
Meta configuration package for nvidia systems on Garuda Linux
local/gwe 0.15.5-3.1
A system utility for controlling NVIDIA GPUs
local/lib32-libvdpau 1.5-1
Nvidia VDPAU library
local/lib32-nvidia-utils 525.60.11-1
NVIDIA drivers utilities (32-bit)
local/lib32-opencl-nvidia 525.60.11-1
OpenCL implemention for NVIDIA (32-bit)
local/libvdpau 1.5-1
local/libxnvctrl 525.60.11-2
NVIDIA NV-CONTROL X extension
local/mhwd-nvidia 525.60.11-1
mhwd-nvidia pci id
local/mhwd-nvidia-390xx 390.143-1
mhwd-nvidia-390xx PCI ID database
local/mhwd-nvidia-470xx 470.94-1
mhwd-nvidia-470xx PCI ID database
local/nvidia-dkms 525.60.11-1
NVIDIA drivers - module sources
local/nvidia-settings 525.60.11-2
Tool for configuring the NVIDIA graphics driver
local/nvidia-utils 525.60.11-1
local/opencl-nvidia 525.60.11-1
local/xf86-video-nouveau 1.0.17-2 (xorg-drivers)
Open Source 3D acceleration driver for nVidia cards
output of sudo dkms autoinstall
Error! Could not locate dkms.conf file.
File: /var/lib/dkms/nvidia/495.46/source/dkms.conf does not exist.
Seeing this post should I boot the plain linux kernel?
TNE
14 December 2022 17:55
2
sudo pacman -S nvidia-dkms && sudo modprobe nvidia && garuda-inxi
Nuh-uh.
resolving dependencies...
Packages (1) nvidia-dkms-525.60.11-1
Total Installed Size: 68.44 MiB
Net Upgrade Size: 0.00 MiB
checking keyring...
checking package integrity...
loading package files...
checking for file conflicts...
checking available disk space...
(1/2) Performing snapper pre snapshots for the following configurations...
IO Error (.snapshots is not a btrfs subvolume).
==> root:
(2/2) Remove upgraded DKMS modules
==> dkms remove nvidia/525.60.11
reinstalling nvidia-dkms...
(1/9) Arming ConditionNeedsUpdate...
(2/9) Install DKMS modules
==> dkms install --no-depmod nvidia/525.60.11 -k 6.0.12-zen1-1-zen
Error! Bad return status for module build on kernel: 6.0.12-zen1-1-zen (x86_64)
Consult /var/lib/dkms/nvidia/525.60.11/build/make.log for more information.
==> WARNING: `dkms install --no-depmod nvidia/525.60.11 -k 6.0.12-zen1-1-zen' exited 10
==> dkms install --no-depmod nvidia/525.60.11 -k 5.15.82-1-lts
Error! Bad return status for module build on kernel: 5.15.82-1-lts (x86_64)
==> WARNING: `dkms install --no-depmod nvidia/525.60.11 -k 5.15.82-1-lts' exited 10
(3/9) Updating linux initcpios...
==> Building image from preset: /etc/mkinitcpio.d/linux-lts.preset: 'default'
-> -k /boot/vmlinuz-linux-lts -c /etc/mkinitcpio.conf -g /boot/initramfs-linux-lts.img
==> Starting build: 5.15.82-1-lts
-> Running build hook: [base]
-> Running build hook: [udev]
-> Running build hook: [autodetect]
-> Running build hook: [modconf]
-> Running build hook: [block]
==> WARNING: Possibly missing firmware for module: xhci_pci
-> Running build hook: [keyboard]
-> Running build hook: [keymap]
-> Running build hook: [consolefont]
-> Running build hook: [plymouth]
-> Running build hook: [filesystems]
-> Running build hook: [grub-btrfs-overlayfs]
==> Generating module dependencies
==> Creating zstd-compressed initcpio image: /boot/initramfs-linux-lts.img
==> Image generation successful
==> Building image from preset: /etc/mkinitcpio.d/linux-lts.preset: 'fallback'
-> -k /boot/vmlinuz-linux-lts -c /etc/mkinitcpio.conf -g /boot/initramfs-linux-lts-fallback.img -S autodetect
==> WARNING: Possibly missing firmware for module: aic94xx
==> WARNING: Possibly missing firmware for module: bfa
==> WARNING: Possibly missing firmware for module: qed
==> WARNING: Possibly missing firmware for module: qla1280
==> WARNING: Possibly missing firmware for module: qla2xxx
==> WARNING: Possibly missing firmware for module: wd719x
==> Creating zstd-compressed initcpio image: /boot/initramfs-linux-lts-fallback.img
==> Building image from preset: /etc/mkinitcpio.d/linux.preset: 'default'
-> -k /boot/vmlinuz-linux -c /etc/mkinitcpio.conf -g /boot/initramfs-linux.img
==> Starting build: 6.0.12-arch1-1
==> Creating zstd-compressed initcpio image: /boot/initramfs-linux.img
==> Building image from preset: /etc/mkinitcpio.d/linux.preset: 'fallback'
-> -k /boot/vmlinuz-linux -c /etc/mkinitcpio.conf -g /boot/initramfs-linux-fallback.img -S autodetect
==> Creating zstd-compressed initcpio image: /boot/initramfs-linux-fallback.img
==> Building image from preset: /etc/mkinitcpio.d/linux-zen.preset: 'default'
-> -k /boot/vmlinuz-linux-zen -c /etc/mkinitcpio.conf -g /boot/initramfs-linux-zen.img
==> Starting build: 6.0.12-zen1-1-zen
==> Creating zstd-compressed initcpio image: /boot/initramfs-linux-zen.img
==> Building image from preset: /etc/mkinitcpio.d/linux-zen.preset: 'fallback'
-> -k /boot/vmlinuz-linux-zen -c /etc/mkinitcpio.conf -g /boot/initramfs-linux-zen-fallback.img -S autodetect
==> Creating zstd-compressed initcpio image: /boot/initramfs-linux-zen-fallback.img
(4/9) Refreshing PackageKit...
(5/9) Foreign/AUR package notification
auto-complete-clang-async 0.5-1
bloaty 1.1-1
bluewho 0.5.2-1
ceph-libs 15.2.17-1
cling 0.9-3
electron13 13.6.9-3
electron14 14.2.9-2
electron16 16.2.8-2
emacs-auto-complete 1.5.1-2
emacs-fuzzy 0.1-2
emacs-popup-el 0.5.3-3
findent 3.1.7-1
fortran-language-server 1.12.0-1
freefilesync-bin 11.23-1
ictree 1.0.1-1
jellyfin-bin 10.8.6-1
jellyfin-server-bin 10.8.6-1
jellyfin-web-bin 10.8.6-1
libguess 1.2-4
libkipi 22.04.0-1
libquicktime 1.2.4-27
metis 5.1.0.p10-2
pi-hole-ftl 5.16.2-1
pi-hole-server 5.11.4-3
python-bluezero 0.7.1-0
python-pylspci 0.4.2-1
rbenv 1.2.0-1
rootactions-servicemenu 2.7.3-1
samba-mounter-git 186.29ebad4-1
seer-gdb 1.11-1
tabby-terminal 1.0.179-1
windscribe-bin 2.4.11-1
(6/9) Orphaned package notification...
ant 1.10.12-2
bluetooth-autoconnect 1.3-1.2
ceph-libs 15.2.17-1
coffeescript 2.7.0-1
cronie 1.6.1-1
crypto++ 8.7.0-1
cunit 2.1.3-3
debugedit 5.0-4
doxygen 1.9.5-1
electron 20.3.8-1
electron13 13.6.9-3
electron14 14.2.9-2
electron16 16.2.8-2
electron17 17.4.11-4
ethtool 1:6.0-1
extra-cmake-modules 5.101.0-1
fcgi 2.4.2-2
gcc11 11.3.0-5
gendesk 1.0.9-3
geocode-glib 3.26.4-2
go 2:1.19.4-1
gperf 3.1-3
gtest 1.12.1-1
img2pdf 0.4.4-1
java11-openjfx 11.0.17.u1-1
js78 78.15.0-4
kfiredragonhelper 5.0.6-1.1
leveldb 1.23-3
lib32-at-spi2-core 2.46.0-2
lib32-gdk-pixbuf2 2.42.10-1
lib32-libpng12 1.2.59-2
lib32-pango 1:1.50.12-1
lib32-pcre 8.45-3
lib32-readline 8.2.001-2
libcmis 0.5.2-12
libcroco 0.6.13-2
libgee 0.20.6-1
libguess 1.2-4
libkipi 22.04.0-1
libofa 0.9.3-9
librabbitmq-c 0.11.0-2
librdkafka 1.9.2-2
libxml++2.6 2.42.1-1
memavaild 0.6-2.1
metis 5.1.0.p10-2
neard 0.18-1.1
nm-connection-editor 1.30.0-1
nohang 0.2.0-1.1
ntp 4.2.8.p15-2
pngquant 2.17.0-2
prelockd 0.9-2.1
python-bcrypt 4.0.1-1
python-beaker 1.11.0-8
python-blessings 1.7-9
python-build 0.9.0-1
python-cachecontrol 1:0.12.11-1
python-cherrypy 18.8.0-2
python-coloredlogs 15.0.1-3.1
python-contextlib2 21.6.0-1
python-defusedxml 0.7.1-4
python-elasticsearch 7.9.0-1
python-flask-restful 0.3.9-4
python-google-api-python-client 2.66.0-1
python-importlib_resources 5.10.1-1
python-installer 0.6.0-1
python-isodate 0.6.1-2
python-mock 3.0.5-9
python-nose 1.3.7-14
python-nspektr 0.4.0-2
python-pdfminer 20220524-1
python-pecan 1.4.2-2
python-pkgconfig 1.5.5-3
python-prettytable 3.5.0-1
python-progress 1.6-5
python-prometheus_client 0.15.0-2
python-py 1.11.0-1
python-pybluez 0.23-4
python-pycodestyle 2.10.0-1
python-pyjwt 2.6.0-1
python-pylint 2.15.8-1
python-pytest-cov 4.0.0-1
python-resolvelib 0.9.0-1
python-retrying 1.3.3-14
python-rich 12.6.0-2
python-scikit-learn 1.2.0-1
python-setuptools-scm-git-archive 1.4-1
python-sphinx 5.3.0-1
python-tenacity 8.1.0-1
python-tqdm 4.64.1-1
python-xmlsec 1.3.13-1
rabbitmq 3.10.7-1
rest 0.8.1+r4+ge5ee6ef-1
unicode-cldr-annotations 41.0-1
unpaper 7.0.0-1
uresourced 0.5.3-1.1
xapp 2.4.2-1
xf86-video-intel 1:2.99.917+916+g31486f40-2
xmlstarlet 1.6.1-3
yarn 1.22.19-1
zita-alsa-pcmi 0.5.1-1
(7/9) Checking for .pacnew and .pacsave files...
e[1m.pac* files found:e[0m
/etc/locale.gen.pacnew
/etc/default/grub.pacnew
/etc/pamac.conf.pacnew
/etc/libvirt/libvirtd.conf.pacnew
/etc/libvirt/qemu.conf.pacnew
/etc/mkinitcpio.conf.pacnew
/etc/ssh/sshd_config.pacnew
/etc/paru.conf.pacnew
e[1mPlease check and mergee[0m
Invalid snapshot '--type'.
==> root:
sudo modprobe nvidia:
modprobe: FATAL: Module nvidia not found in directory /lib/modules/6.0.12-zen1-1-zen
Speed (MHz): avg: 3800 min/max: 2200/4850 boost: enabled scaling: driver: acpi-cpufreq
governor: performance cores: 1: 3800 2: 3800 3: 3800 4: 3800 5: 3800 6: 3800 7: 3800 8: 3800
9: 3800 10: 3800 11: 3800 12: 3800 13: 3800 14: 3800 15: 3800 16: 3800 bogomips: 121375
Local Storage: total: 476.94 GiB used: 395.98 GiB (83.0%)
rev: 002C temp: 37.9 C scheme: GPT
ID-1: / raw-size: 476.64 GiB size: 476.64 GiB (100.00%) used: 395.98 GiB (83.1%) fs: btrfs
ID-3: /home raw-size: 476.64 GiB size: 476.64 GiB (100.00%) used: 395.98 GiB (83.1%) fs: btrfs
ID-4: /var/log raw-size: 476.64 GiB size: 476.64 GiB (100.00%) used: 395.98 GiB (83.1%)
ID-5: /var/tmp raw-size: 476.64 GiB size: 476.64 GiB (100.00%) used: 395.98 GiB (83.1%)
ID-1: swap-1 type: zram size: 15.52 GiB used: 512 KiB (0.0%) priority: 100 dev: /dev/zram0
System Temperatures: cpu: 41.6 C mobo: N/A
Processes: 325 Uptime: 5m wakeups: 0 Memory: 15.52 GiB used: 2.47 GiB (15.9%) Init: systemd
TNE
14 December 2022 18:10
4
Upload /var/lib/dkms/nvidia/525.60.11/build/make.log please.
DKMS make.log for nvidia-525.60.11 for kernel 5.15.82-1-lts (x86_64)
Wed Dec 14 11:31:35 PM IST 2022
make[1]: Entering directory '/usr/lib/modules/5.15.82-1-lts/build'
cc: error while loading shared libraries: libhiredis.so.1.0.0: cannot open shared object file: No such file or directory
warning: the compiler differs from the one used to build the kernel
The kernel was built by: gcc (GCC) 12.2.0
You are using:
The C compiler 'cc' does not appear to be able to
create executables. Please make sure you have
your Linux distribution's gcc and libc development
packages installed.
*** Failed CC sanity check. Bailing out! ***
Warning: Compiler version check failed:
The major and minor number of the compiler used to
compile the kernel:
gcc (GCC) 12.2.0, GNU ld (GNU Binutils) 2.39.0
does not match the compiler used here:
It is recommended to set the CC environment variable
to the compiler that was used to compile the kernel.
To skip the test and silence this warning message, set
the IGNORE_CC_MISMATCH environment variable to "1".
However, mixing compiler versions between the kernel
and kernel modules can result in subtle bugs that are
difficult to diagnose.
*** Failed CC version check. ***
make[2]: *** [/var/lib/dkms/nvidia/525.60.11/build/Kbuild:335: cc_sanity_check] Error 1
make[2]: *** Waiting for unfinished jobs....
make[1]: *** [Makefile:1900: /var/lib/dkms/nvidia/525.60.11/build] Error 2
make[1]: Leaving directory '/usr/lib/modules/5.15.82-1-lts/build'
make: *** [Makefile:82: modules] Error 2
I remember now. A few days back clang, ccache, a few others gave the same error. I just locally installed the latest clang from their website and didn't give it a second thought.
I have the 1.1.0-1 version of hiredis installed.
TNE
14 December 2022 18:18
6
Partial upgrade? Do you ignore any packages?
garuda-update output?
I have been running garuda-update for a while now.
However I used to use pamac. Did that screw something up?
How do I check for ignored packages?
/etc/pacman.conf
# /etc/pacman.conf
# See the pacman.conf(5) manpage for option and repository directives
# GENERAL OPTIONS
[options]
# The following paths are commented out with their default values listed.
# If you wish to use different paths, uncomment and update the paths.
#RootDir = /
#DBPath = /var/lib/pacman/
CacheDir = /var/cache/pacman/pkg/
#LogFile = /var/log/pacman.log
#GPGDir = /etc/pacman.d/gnupg/
#HookDir = /etc/pacman.d/hooks/
HoldPkg = pacman glibc garuda-system
#XferCommand = /usr/bin/curl -L -C - -f -o %o %u
#XferCommand = /usr/bin/wget --passive-ftp -c -O %o %u
#CleanMethod = KeepInstalled
Architecture = auto
# Pacman won't upgrade packages listed in IgnorePkg and members of IgnoreGroup
#IgnorePkg =
#IgnoreGroup =
#NoUpgrade =
#NoExtract =
# Misc options
#UseSyslog
Color
#NoProgressBar
CheckSpace
#VerbosePkgLists
ILoveCandy
ParallelDownloads = 5
# By default, pacman accepts packages signed by keys that its local keyring
# trusts (see pacman-key and its man page), as well as unsigned packages.
SigLevel = Required DatabaseOptional
LocalFileSigLevel = Optional
#RemoteFileSigLevel = Required
# NOTE: You must run `pacman-key --init` before first using pacman; the local
# keyring can then be populated with the keys of all official Arch Linux
# packagers with `pacman-key --populate archlinux`.
# REPOSITORIES
# - can be defined here or included from another file
# - pacman will search repositories in the order defined here
# - local/custom mirrors can be added here or in separate files
# - repositories listed first will take precedence when packages
# have identical names, regardless of version number
# - URLs will have $repo replaced by the name of the current repo
# - URLs will have $arch replaced by the name of the architecture
# Repository entries are of the format:
# [repo-name]
# Server = ServerName
# Include = IncludePath
# The header [repo-name] is crucial - it must be present and
# uncommented to enable the repo.
[garuda]
Include = /etc/pacman.d/chaotic-mirrorlist
[core]
Include = /etc/pacman.d/mirrorlist
[extra]
[community]
[multilib]
[chaotic-aur]
# An example of a custom package repository. See the pacman manpage for
# tips on creating your own repositories.
#[custom]
#SigLevel = Optional TrustAll
#Server = file:///home/custompkgs
TNE
14 December 2022 18:21
8
Please do it and share the output.
garuda downloading...
core downloading...
extra downloading...
community downloading...
multilib downloading...
chaotic-aur downloading...
e[1;33m-->e[1;34m Refreshing mirrorlists using rate-mirrors, please be patient..e[0m
core downloading...
spawn pacman -Su
e[?25le[1;34m::e[0;1m Starting full system upgrade...
e[0m there is nothing to do
e[?25h
Checking for plugin updates
Failed to query plugin channel:
Get "https://raw.githubusercontent.com/micro-editor/plugin-channel/master/channel.json": dial tcp [2405:200:1607:2820:41::36]:443: i/o timeout
unable to find a matching version for "aspell"
e[1;32mSystem updated! 🐧
e[0m
TNE
14 December 2022 18:27
10
Since that log file is unfortunately diagnostically useless, I'll need some more info:
sudo pacman -R linux-lts linux-lts-headers && pacman -S nvidia-dkms and then upload /var/lib/dkms/nvidia/525.60.11/build/make.log
Share as many command outputs as you can of course.
checking dependencies...
:: dkms optionally requires linux-lts-headers: build modules against the LTS kernel
Packages (2) linux-lts-5.15.82-1 linux-lts-headers-5.15.82-1
Total Removed Size: 270.69 MiB
(1/3) Performing snapper pre snapshots for the following configurations...
==> root:
(2/3) Removing linux initcpios...
(3/3) Remove DKMS modules
removing linux-lts-headers...
removing linux-lts...
(2/9) Updating module dependencies...
(3/9) Refreshing PackageKit...
(4/9) Foreign/AUR package notification
bloaty 1.1-1
bluewho 0.5.2-1
ceph-libs 15.2.17-1
cling 0.9-3
electron13 13.6.9-3
electron14 14.2.9-2
electron16 16.2.8-2
emacs-fuzzy 0.1-2
findent 3.1.7-1
ictree 1.0.1-1
libguess 1.2-4
libkipi 22.04.0-1
metis 5.1.0.p10-2
rbenv 1.2.0-1
seer-gdb 1.11-1
(5/9) Orphaned package notification...
ant 1.10.12-2
ceph-libs 15.2.17-1
cronie 1.6.1-1
crypto++ 8.7.0-1
cunit 2.1.3-3
debugedit 5.0-4
doxygen 1.9.5-1
electron 20.3.8-1
electron13 13.6.9-3
electron14 14.2.9-2
electron16 16.2.8-2
ethtool 1:6.0-1
fcgi 2.4.2-2
gcc11 11.3.0-5
gendesk 1.0.9-3
go 2:1.19.4-1
gperf 3.1-3
gtest 1.12.1-1
img2pdf 0.4.4-1
js78 78.15.0-4
leveldb 1.23-3
lib32-pcre 8.45-3
libcmis 0.5.2-12
libcroco 0.6.13-2
libgee 0.20.6-1
libguess 1.2-4
libkipi 22.04.0-1
libofa 0.9.3-9
librdkafka 1.9.2-2
memavaild 0.6-2.1
metis 5.1.0.p10-2
neard 0.18-1.1
nohang 0.2.0-1.1
ntp 4.2.8.p15-2
pngquant 2.17.0-2
prelockd 0.9-2.1
python-mock 3.0.5-9
python-py 1.11.0-1
rabbitmq 3.10.7-1
unpaper 7.0.0-1
xapp 2.4.2-1
xmlstarlet 1.6.1-3
yarn 1.22.19-1
(6/9) Checking for .pacnew and .pacsave files...
(7/9) GRUB update after transactions...
Found theme: /usr/share/grub/themes/garuda-dr460nized/theme.txt
Found initrd image: /boot/intel-ucode.img /boot/initramfs-linux-zen.img
Found fallback initrd image(s) in /boot: intel-ucode.img initramfs-linux-zen-fallback.img
Found initrd image: /boot/intel-ucode.img /boot/initramfs-linux.img
Found fallback initrd image(s) in /boot: intel-ucode.img initramfs-linux-fallback.img
Found Garuda Linux on /dev/nvme0n1p2
Found Debian GNU/Linux 11 (bullseye) on /dev/nvme0n1p2
Detecting snapshots ...
Found snapshot: 2022-12-14 19:39:22 | timeshift-btrfs/snapshots/2022-12-13_20-10-23/@/.snapshots/31/snapshot | post | krita svt-av1 |
Found snapshot: 2022-12-14 19:39:20 | timeshift-btrfs/snapshots/2022-12-13_20-10-23/@/.snapshots/30/snapshot | pre | pacman -Syu |
Found snapshot: 2022-12-14 17:40:03 | timeshift-btrfs/snapshots/2022-12-13_20-10-23/@/.snapshots/29/snapshot | post | xf86-video-fbdev |
Found snapshot: 2022-12-14 17:40:01 | timeshift-btrfs/snapshots/2022-12-13_20-10-23/@/.snapshots/28/snapshot | pre | pacman -Syu xf86-video-fbdev |
Found snapshot: 2022-12-14 17:32:40 | timeshift-btrfs/snapshots/2022-12-13_20-10-23/@/.snapshots/27/snapshot | post | vim vim-runtime xf86-video-vesa xorg-bdftopcf xorg-docs xorg-font-util x |
Found snapshot: 2022-12-14 17:32:35 | timeshift-btrfs/snapshots/2022-12-13_20-10-23/@/.snapshots/26/snapshot | pre | pacman -Syu xorg |
Found snapshot: 2022-12-14 17:13:40 | timeshift-btrfs/snapshots/2022-12-13_20-10-23/@/.snapshots/25/snapshot | post | xf86-video-fbdev |
Found snapshot: 2022-12-14 17:13:38 | timeshift-btrfs/snapshots/2022-12-13_20-10-23/@/.snapshots/24/snapshot | pre | pacman -R xf86-video-fbdev |
Found snapshot: 2022-12-14 16:53:50 | timeshift-btrfs/snapshots/2022-12-13_20-10-23/@/.snapshots/23/snapshot | post | corefreq-client corefreq-dkms corefreq-server |
Found snapshot: 2022-12-14 16:53:18 | timeshift-btrfs/snapshots/2022-12-13_20-10-23/@/.snapshots/22/snapshot | pre | pacman -R --config /etc/pacman.conf -- corefreq-client corefreq-server c |
Found snapshot: 2022-12-14 16:35:51 | timeshift-btrfs/snapshots/2022-12-13_20-10-23/@/.snapshots/15/snapshot | single | Before installing nvidia |
Found snapshot: 2022-12-14 15:00:00 | timeshift-btrfs/snapshots/2022-12-13_20-10-23/@/.snapshots/4/snapshot | single | N/A |
Found snapshot: 2022-12-13 20:10:24 | @_backup_20221412214741565 | N/A | N/A |
Found snapshot: 2022-12-10 00:32:35 | timeshift-btrfs/snapshots/2022-12-10_00-32-35/@ | ondemand | N/A |
Found snapshot: 2022-12-09 23:48:25 | timeshift-btrfs/snapshots/2022-12-09_23-48-25/@ | ondemand | N/A |
Found snapshot: 2022-12-09 23:24:17 | timeshift-btrfs/snapshots/2022-12-09_23-24-17/@ | ondemand | N/A |
Found snapshot: 2022-01-30 23:48:06 | timeshift-btrfs/snapshots/2022-01-30_23-48-06/@ | ondemand | N/A |
Found 17 snapshot(s)
Unmount /tmp/grub-btrfs.34OPbAmjCq .. Success
/usr/bin/grub-probe: warning: unknown device type nvme0n1.
done
==> root:
checking keyring...
==> root:
bloaty 1.1-1
bluewho 0.5.2-1
ceph-libs 15.2.17-1
cling 0.9-3
electron13 13.6.9-3
electron14 14.2.9-2
electron16 16.2.8-2
emacs-fuzzy 0.1-2
findent 3.1.7-1
ictree 1.0.1-1
libguess 1.2-4
libkipi 22.04.0-1
metis 5.1.0.p10-2
rbenv 1.2.0-1
seer-gdb 1.11-1
ant 1.10.12-2
ceph-libs 15.2.17-1
cronie 1.6.1-1
crypto++ 8.7.0-1
cunit 2.1.3-3
debugedit 5.0-4
doxygen 1.9.5-1
electron 20.3.8-1
electron13 13.6.9-3
electron14 14.2.9-2
electron16 16.2.8-2
ethtool 1:6.0-1
fcgi 2.4.2-2
gcc11 11.3.0-5
gendesk 1.0.9-3
go 2:1.19.4-1
gperf 3.1-3
gtest 1.12.1-1
img2pdf 0.4.4-1
js78 78.15.0-4
leveldb 1.23-3
lib32-pcre 8.45-3
libcmis 0.5.2-12
libcroco 0.6.13-2
libgee 0.20.6-1
libguess 1.2-4
libkipi 22.04.0-1
libofa 0.9.3-9
librdkafka 1.9.2-2
memavaild 0.6-2.1
metis 5.1.0.p10-2
neard 0.18-1.1
nohang 0.2.0-1.1
ntp 4.2.8.p15-2
pngquant 2.17.0-2
prelockd 0.9-2.1
python-mock 3.0.5-9
python-py 1.11.0-1
rabbitmq 3.10.7-1
unpaper 7.0.0-1
xapp 2.4.2-1
xmlstarlet 1.6.1-3
yarn 1.22.19-1
==> root:
DKMS make.log for nvidia-525.60.11 for kernel 6.0.12-zen1-1-zen (x86_64)
Thu Dec 15 12:02:47 AM IST 2022
make[1]: Entering directory '/usr/lib/modules/6.0.12-zen1-1-zen/build'
You are using:
packages installed.
compile the kernel:
make[1]: *** [Makefile:1849: /var/lib/dkms/nvidia/525.60.11/build] Error 2
make[1]: Leaving directory '/usr/lib/modules/6.0.12-zen1-1-zen/build'
TNE
14 December 2022 18:40
13
Okay, this is rather special, huh?
ldd /usr/bin/cc; pacman -Qo /usr/bin/cc; cc --version
GCC does not use this library as far as I can tell, so let's figure out what's going on with it.
Is it sensible and/or possible to install that version of hiredis?
TNE
14 December 2022 18:41
15
Uh, I guess, but that's not exactly a solution, now is it? That's not how packages and dependencies work, after all, and I am specifically looking for the root cause of this issue instead of giving you a half-assed solution that will just lead to more breakage later on.
TNE:
ldd /usr/bin/cc
linux-vdso.so.1 (0x00007ffdedbd0000)
libc.so.6 => /usr/lib/libc.so.6 (0x00007f6d2af0d000)
/lib64/ld-linux-x86-64.so.2 => /usr/lib64/ld-linux-x86-64.so.2 (0x00007f6d2b136000)
As an aside, why did this happen?? I’ve ran Garuda since Jan and it flawlessly.
A week back I ran garuda-update and I encountered problem after problem: first it got stuck in boot at loading initial ramdisk, then it gave a separate out of range pointer issue. I used chroot for the first time and updated grub. That fixed the pointer error, but then it didn’t load a gui.
(some of them were my fault of course, I’m a noob in this area of linux. I should have taken snapshots, and should have switched to snapper which takes one before and after updates anyways)
TNE
14 December 2022 18:49
18
I can't say that for sure without first diagnosing the issue you are having, which is very frustrating through forum text because I could rattle down these commands in a terminal in a couple seconds instead of having to wait a couple of minutes between every command
(You are still missing two commands)
Why do both GCC and Clang compilers need a database package for that matter
I'm so so thankful for Garuda's community.
I had never used web forums for tech problems before, unix.stackexchange would suffice.
