Yeah yeah great and all but can I have the outputs of those commands now
/usr/bin/cc is owned by gcc 12.2.0-1
No version, just the same error
Running plain /usr/bin/gcc
works though.
gcc (GCC) 12.2.0
Copyright (C) 2022 Free Software Foundation, Inc.
This is free software; see the source for copying conditions. There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
Ok i think I got it.
As I suspected, ccache
uses redis
and the ccache
symlinks are in $PATH
If I run /usr/bin/cc
it works.
See the manual ccache(1) for symlinks and
ccache(1) for hiredis
Alright, I figured it was ccache, I have a suspicion as to what the root cause is at this point.
pacman -Q ccache
4.7.4-2
I realise I also had ccache 4.7.4 manually installed (not through pacman)
But the same version is also in /usr/bin/
Oh my god... Just.. Why..
Anyway, let's get rid of that garbage.
echo $PATH
/home/jb/.rbenv/shims
/home/jb/vulkan/1.3.204.1/x86_64/bin
/home/jb/.nix-profile/bin
/nix/var/nix/profiles/default/bin
/usr/lib/emscripten
/home/jb/jetbrains/clion-2022.3/bin
/home/jb/cpp/ccache/4.7.4
/home/jb/bin
/home/jb/cpp/cmake_nightly/cmake-3.25.20221117-g140369d-linux-x86_64/bin
/home/jb/llvm/15.06/bin
/home/jb/cpp/gcc-modules/install/bin
/usr/lib/jellyfin/bin
/home/jb/.cargo/bin
/usr/local/sbin
/usr/local/bin
/usr/bin
/home/jb/.dotnet/tools
/usr/lib/jvm/default/bin
/usr/bin/site_perl
/usr/bin/vendor_perl
/usr/bin/core_perl
/home/jb/.local/share/gem/ruby/3.0.0/bin
I piped it into a python one-liner to put it on newlines
Oh my god, that's horrible. You have /home things in your system PATH? Get rid of anything /home in your system PATH, no wonder you ended up in this situation, it was inevitable.
ccache I don't remeber actually
clang, gcc I installed locally because I needed their latest versions.
I put these $PATH
changes in my ~/.zshenv
I didn't realise it would be used by literally everything
Should I put in my ~/.zshrc
instead
I forgot how $PATH
works, I though it would only be for commands I type for some reason.
Excuse my brain damage
That's fine for your user path, but oh god don't do that for your system PATH.
This should be your system PATH: /usr/local/sbin:/usr/local/bin:/usr/bin:/usr/lib/jvm/default/bin:/usr/bin/site_perl:/usr/bin/vendor_perl:/usr/bin/core_perl
Nothing more, nothing less.
After you did that, run sudo pacman -S linux-zen linux-zen-headers
(to rebuild all DKMS modules) and then reboot. You should have your precious GUI back.
Once you are there, verify snapper-support
is installed and then run garuda-update remote reset-snapper
and then share the output of sudo btrfs subvolume list /
Ok I'll be honest, there's stuff in my $PATH
I don't even remeber where I added.
They're not in .zshenv
or .zshrc
Do you know any other places?
Also would you please enlighten me the difference between system and user $PATH
Where should I add it for the user?
It's the year of the linux desktop, the least I can ask is a GUI
\s
Damn! Still gets stuck at target graphical interface
I manualy ran startx
/var/log/Xorg.0.log
[ 31.278]
X.Org X Server 1.21.1.5
X Protocol Version 11, Revision 0
[ 31.279] Current Operating System: Linux jbh5 6.0.12-zen1-1-zen #1 ZEN SMP PREEMPT_DYNAMIC Thu, 08 Dec 2022 11:03:40 +0000 x86_64
[ 31.279] Kernel command line: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=aeb3c7e0-45af-4344-ba3f-05339ad86d76 rw [email protected] rd.udev.log_priority=3 vt.global_cursor_default=0 loglevel=3 ibt=off
[ 31.279]
[ 31.279] Current version of pixman: 0.42.2
[ 31.279] Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
[ 31.279] Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 31.279] (==) Log file: "/var/log/Xorg.0.log", Time: Thu Dec 15 00:49:20 2022
[ 31.280] (==) Using config file: "/etc/X11/xorg.conf"
[ 31.280] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 31.280] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 31.281] (==) ServerLayout "Layout0"
[ 31.281] (**) |-->Screen "Screen0" (0)
[ 31.281] (**) | |-->Monitor "Monitor0"
[ 31.281] (**) | |-->Device "Device0"
[ 31.281] (**) |-->Input Device "Keyboard0"
[ 31.281] (**) |-->Input Device "Mouse0"
[ 31.281] (==) Automatically adding devices
[ 31.281] (==) Automatically enabling devices
[ 31.281] (==) Automatically adding GPU devices
[ 31.281] (==) Automatically binding GPU devices
[ 31.281] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 31.281] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[ 31.281] Entry deleted from font path.
[ 31.281] (==) FontPath set to:
/usr/share/fonts/misc,
/usr/share/fonts/TTF,
/usr/share/fonts/OTF,
/usr/share/fonts/100dpi,
/usr/share/fonts/75dpi
[ 31.281] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 31.281] (WW) Hotplugging is on, devices using drivers 'kbd', 'mouse' or 'vmmouse' will be disabled.
[ 31.281] (WW) Disabling Keyboard0
[ 31.281] (WW) Disabling Mouse0
[ 31.281] (II) Module ABI versions:
[ 31.281] X.Org ANSI C Emulation: 0.4
[ 31.281] X.Org Video Driver: 25.2
[ 31.281] X.Org XInput driver : 24.4
[ 31.281] X.Org Server Extension : 10.0
[ 31.282] (++) using VT number 2
[ 31.282] (II) systemd-logind: took control of session /org/freedesktop/login1/session/_31
[ 31.284] (--) PCI:*([email protected]:0:0) 10de:2187:1043:8769 rev 161, Mem @ 0xfb000000/16777216, 0xd0000000/268435456, 0xe0000000/33554432, I/O @ 0x0000e000/128, BIOS @ 0x????????/131072
[ 31.284] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[ 31.284] (II) LoadModule: "glx"
[ 31.284] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 31.285] (II) Module glx: vendor="X.Org Foundation"
[ 31.285] compiled for 1.21.1.5, module version = 1.0.0
[ 31.285] ABI class: X.Org Server Extension, version 10.0
[ 31.285] (II) LoadModule: "nvidia"
[ 31.285] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[ 31.288] (II) Module nvidia: vendor="NVIDIA Corporation"
[ 31.288] compiled for 1.6.99.901, module version = 1.0.0
[ 31.288] Module class: X.Org Video Driver
[ 31.288] (II) NVIDIA dlloader X Driver 525.60.11 Wed Nov 23 22:56:57 UTC 2022
[ 31.288] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 31.288] (II) Loading sub module "fb"
[ 31.288] (II) LoadModule: "fb"
[ 31.288] (II) Module "fb" already built-in
[ 31.288] (II) Loading sub module "wfb"
[ 31.288] (II) LoadModule: "wfb"
[ 31.288] (II) Loading /usr/lib/xorg/modules/libwfb.so
[ 31.288] (II) Module wfb: vendor="X.Org Foundation"
[ 31.288] compiled for 1.21.1.5, module version = 1.0.0
[ 31.288] ABI class: X.Org ANSI C Emulation, version 0.4
[ 31.288] (II) Loading sub module "ramdac"
[ 31.288] (II) LoadModule: "ramdac"
[ 31.288] (II) Module "ramdac" already built-in
[ 31.290] (EE) NVIDIA: Failed to initialize the NVIDIA kernel module. Please see the
[ 31.290] (EE) NVIDIA: system's kernel log for additional error messages and
[ 31.290] (EE) NVIDIA: consult the NVIDIA README for details.
[ 31.290] (EE) No devices detected.
[ 31.290] (EE)
Fatal server error:
[ 31.290] (EE) no screens found(EE)
[ 31.290] (EE)
Please consult the The X.Org Foundation support
at http://wiki.x.org
for help.
[ 31.290] (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
[ 31.290] (EE)
[ 31.291] (EE) Server terminated with error (1). Closing log file.
Oh god why didn't I choose an AMD graphics card. Also I recently switched from and intel 9400 which had integrated drivers
You probably didn't reboot after changing your system wide path properly before running the command to trigger DKMS.
echo $PATH; pacman -S nvidia-dkms
and then upload /var/lib/dkms/nvidia/525.60.11/build/make.log
Share all logs.
Hmm I thought I did?
Does running sudo reboot
suffice or do I have to do a full powerdown?
