First of all sorry for disturbance.
But I really want to dual boot my HP laptop ( win 8.1 and Garuda)
I know there is also a same topic, I found but I don't understand well cause I am not from IT field or have any experience in computer
So please tell me in layman langauge
I make a bootable pendrive with Garuda and boot with USB hard disk (UEFI)
and then boot with open driver
select install Garuda linux
After basic information
Select replace a partition
After 7-10 min the following error show
Please check in your BIOS if you are booting in UEFI mode and that secure boot is disabled (if such option is available in your BIOS).
Post also the restults of
sudo fdisk -l
lsblk -f
First of all Thank you very much for reply
in boot option device i select usb (UEFI) to boot and i disable secure boot and fastboot
and below is the output of the both command
Disk /dev/sda: 931.51 GiB, 1000204886016 bytes, 1953525168 sectors
Disk model: WDC WD10JPVX-60J
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disklabel type: dos
Disk identifier: 0xfc515ad7
Device Boot Start End Sectors Size Id Type
/dev/sda1 * 2048 718847 716800 350M 7 HPFS/NTFS/exFAT
/dev/sda2 720896 204804095 204083200 97.3G 7 HPFS/NTFS/exFAT
/dev/sda3 204806142 1867505663 1662699522 792.8G f W95 Ext'd (LBA)
/dev/sda5 204806144 817940479 613134336 292.4G 7 HPFS/NTFS/exFAT
/dev/sda6 817942528 1867502887 1049560360 500.5G 7 HPFS/NTFS/exFAT
Partition 3 does not start on physical sector boundary.
Disk /dev/sdb: 14.45 GiB, 15514730496 bytes, 30302208 sectors
Disk model: Storage Media
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: dos
Disk identifier: 0x00000000
/dev/sdb1 * 64 4796259 4796196 2.3G 0 Empty
/dev/sdb2 4796260 4804451 8192 4M ef EFI (FAT-12/16/32)
Disk /dev/loop0: 17.67 MiB, 18530304 bytes, 36192 sectors
Disk /dev/loop1: 364.28 MiB, 381972480 bytes, 746040 sectors
Disk /dev/loop2: 1.11 GiB, 1193598976 bytes, 2331248 sectors
Disk /dev/loop3: 709.05 MiB, 743497728 bytes, 1452144 sectors
Disk /dev/zram0: 1.92 GiB, 2062544896 bytes, 503551 sectors
Units: sectors of 1 * 4096 = 4096 bytes
Sector size (logical/physical): 4096 bytes / 4096 bytes
Disk /dev/zram1: 1.92 GiB, 2062544896 bytes, 503551 sectors
Disk /dev/zram2: 1.92 GiB, 2062544896 bytes, 503551 sectors
Disk /dev/zram3: 1.92 GiB, 2062544896 bytes, 503551 sectors
NAME FSTYPE FSVER LABEL UUID FSAVAIL FSUSE% MOUNTPOINT
loop0 squash 4.0 0 100% /run/miso/
loop1 squash 4.0 0 100% /run/miso/
loop2 squash 4.0 0 100% /run/miso/
loop3 squash 4.0 0 100% /run/miso/
sda
├─sda1 ntfs System Reserved 01D8118C548FE640
├─sda2 ntfs 01D8118CE06DB750
├─sda3
├─sda5 ntfs Game 01D8118CE69863F0
└─sda6 ntfs Storage 01D8106667B62AD0
sdb iso966 Joliet GARUDA_DR460NIZED_SOARING_ 2021-05-07-11-01-06-00 0 100% /run/miso/
├─sdb1 iso966 Joliet GARUDA_DR460NIZED_SOARING_ 2021-05-07-11-01-06-00
└─sdb2 vfat FAT12 MISO_EFI BF22-740A
sr0
zram0 [SWAP]
zram1 [SWAP]
zram2 [SWAP]
zram3 [SWAP]
Please read
Your disk is MBR based, so you shouldn't boot in UEFI mode. Select something like Legacy mode (depending on the naming)
WOW its Work
Thank you very much
i check both the OS work pretty well
when i boot the windows the damage/corrupt image show i think windows get corrupted but later after a minute it start and work well
before ending the discussion
can i turn on Fastboot ? cause i feel windows take more time to start
I strongly suggest to avoid the use of windows fast boot, because it kind of keeps on-hold some HW resources, like Wifi and blootooth cards, etc, that might then not work in Garuda the next time.
Furthermore, with fastboot on I think you should never change (add, update, delete) from Garuda any file in the Windows partiton, becuase that could get kind of corrupted. At least this might occur from Windows 10, where fast boot is actually an hibernation. I don't remember about win8.1...
You can try if you want, but then just remove it before opening a new topic for relevant problems
