After my struggles with trying to fix my laptops network dying after sleep (thread here) and eventually somehow hiding garuda from efi, I installed a fresh ISO of the garuda KDE edition on my laptop.
All seems well and similar to my previous installation, except that I cannot use bluetooth anymore at all. When opening the bluetooth panel it just shows "No bluetooth adapters found" (in finnish). If I then try to "add a new device", it just shows the bluetooth connection/discovery dialogue, but doesn't seem to find anything.
rfkill doesn't show it as blocked:
ID TYPE DEVICE SOFT HARD
0 wlan ideapad_wlan unblocked unblocked
1 bluetooth ideapad_bluetooth unblocked unblocked
3 wlan phy0 unblocked unblocked
4 bluetooth hci0 unblocked unblocked
bluetoothctl seems a bit weird though:
>bluetoothctl
Agent registered
[bluetooth]# list
[bluetooth]#
Doesn't seem to work, systemctl status bluetooth reveals something though:
â—Ź bluetooth.service - Bluetooth service
Loaded: loaded (/usr/lib/systemd/system/bluetooth.service; enabled; vendor preset: disabled)
Active: active (running) since Mon 2020-11-02 17:50:06 EET; 8min ago
Docs: man:bluetoothd(8)
Main PID: 403 (bluetoothd)
Status: "Running"
Tasks: 1 (limit: 8729)
Memory: 2.0M
CGroup: /system.slice/bluetooth.service
└─403 /usr/lib/bluetooth/bluetoothd
marras 02 17:50:05 ip-f5 bluetoothd[403]: src/main.c:parse_controller_config() Key file does not have key “LEScanIntervalConnect” in group “Controller”
marras 02 17:50:05 ip-f5 bluetoothd[403]: src/main.c:parse_controller_config() Key file does not have key “LEScanWindowConnect” in group “Controller”
marras 02 17:50:05 ip-f5 bluetoothd[403]: src/main.c:parse_controller_config() Key file does not have key “LEMinConnectionInterval” in group “Controller”
marras 02 17:50:05 ip-f5 bluetoothd[403]: src/main.c:parse_controller_config() Key file does not have key “LEMaxConnectionInterval” in group “Controller”
marras 02 17:50:05 ip-f5 bluetoothd[403]: src/main.c:parse_controller_config() Key file does not have key “LEConnectionLatency” in group “Controller”
marras 02 17:50:05 ip-f5 bluetoothd[403]: src/main.c:parse_controller_config() Key file does not have key “LEConnectionSupervisionTimeout” in group “Controller”
marras 02 17:50:05 ip-f5 bluetoothd[403]: src/main.c:parse_controller_config() Key file does not have key “LEAutoconnecttimeout” in group “Controller”
marras 02 17:50:05 ip-f5 bluetoothd[403]: Starting SDP server
marras 02 17:50:06 ip-f5 bluetoothd[403]: Bluetooth management interface 1.18 initialized
marras 02 17:50:06 ip-f5 systemd[1]: Started Bluetooth service.
