I am using Garuda Gnome Edition, I'm facing a crucial problem that my bluetooth headset microphone not work only I can here, other If I use normal wired headset then everything is fine
A forum search reveals…
Many threads on this type pf problem, take a trip through them.
Nice pic...did you read the thread I gave you? Did you attempt what @jonathon suggested, in the thread I linked?
Any results/thoughts?
Just read but did not get any suitable remark out there
Which tells you
This is a current issue with Pipewire’s Bluetooth handling
This is not a suitable remark?
okay fine, have you got your issue fixed?
I don't have an issue. You do. I am trying to help you.
I posted a thread with what appears to be, the same issue you face.
then after running that command in my console,whats next?
If you follow the thread, @jonathon gives the command and an answer, as to what it does.
I would then check my audio, but I would keep in mind bluetooth can be problematic, so would not expect a magic bullet.
The thread(s) show this admirably. (you have searched the forum, as suggested?)
