I will first start with this…
╭─fenris@fenris in ~ took 12ms
╰─λ sudo garuda-inxi
[sudo] password for fenris:
Kernel: 6.8.6-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=cd6e149b-2970-476f-b742-e3dc1120bedc rw rootflags=subvol=@
quiet rd.luks.uuid=264cadad-c8c3-46fe-b132-32f30ff8b69c
rd.luks.uuid=0dd705d1-74f7-4ae7-8f55-96ae57f524b8
resume=/dev/mapper/luks-0dd705d1-74f7-4ae7-8f55-96ae57f524b8 loglevel=3
Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.36 wm: xfwm4 v: 4.18.0
Type: Desktop Mobo: AZW model: MINI S v: 10 serial: N/A part-nu: 01
uuid: 03000200-0400-0500-0006-000700080009 UEFI: American Megatrends LLC.
v: ADLNV104 date: 02/06/2023
Info: model: Intel N100 socket: U3E1 bits: 64 type: MCP arch: Alder Lake
level: v3 note: check built: 2021+ process: Intel 7 (10nm ESF) family: 6
model-id: 0xBE (190) stepping: 0 microcode: 0x15
Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 384 KiB
desc: d-4x32 KiB; i-4x64 KiB L2: 2 MiB desc: 1x2 MiB L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 957 high: 1000 min/max: 700/3400 base/boost: 2871/3400
scaling: driver: intel_pstate governor: powersave volts: 1.0 V
ext-clock: 100 MHz cores: 1: 908 2: 996 3: 925 4: 1000 bogomips: 6451
Device-1: Intel Alder Lake-N [UHD Graphics] driver: i915 v: kernel
alternate: xe arch: Gen-12.2 process: Intel 10nm built: 2021-22+ ports:
active: HDMI-A-1,HDMI-A-2 empty: none bus-ID: 00:02.0 chip-ID: 8086:46d1
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-4.3:8
chip-ID: 041e:40a0 class-ID: 0102 serial: <filter>
Display: x11 server: X.Org v: 21.1.13 compositor: xfwm4 v: 4.18.0 driver:
X: loaded: modesetting alternate: fbdev,intel,vesa dri: iris gpu: i915
display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 3280x1080 s-dpi: 96 s-size: 868x286mm (34.17x11.26")
s-diag: 914mm (35.98")
Monitor-1: HDMI-A-1 mapped: HDMI-1 pos: left model: HKC TV
serial: <filter> built: 2015 res: 1360x768 hz: 60 dpi: 45 gamma: 1.2
size: 760x450mm (29.92x17.72") diag: 806mm (31.7") ratio: 16:9, 15:9
modes: max: 1360x768 min: 720x400
Monitor-2: HDMI-A-2 mapped: HDMI-2 pos: primary,right model: HP LA2206
serial: <filter> built: 2011 res: 1920x1080 hz: 60 dpi: 102 gamma: 1.2
API: Vulkan v: 1.3.279 layers: 5 device: 0 type: integrated-gpu
name: Intel Graphics (ADL-N) driver: mesa intel v: 24.0.5-arch1.1
device-ID: 8086:46d1 surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
(LLVM 17.0.6 256 bits) driver: mesa llvmpipe v: 24.0.5-arch1.1 (LLVM
Device-1: Intel Alder Lake-N PCH High Definition Audio driver: snd_hda_intel
chip-ID: 8086:54c8 class-ID: 0403
Device-2: C-Media CM106 Like Sound Device
lanes: 1 mode: 1.1 bus-ID: 1-4.2:6 chip-ID: 0d8c:0102 class-ID: 0300
Device-3: Creative Live! Cam Sync 1080p V2 driver: snd-usb-audio,uvcvideo
Device-4: JMTek LLC. LCS USB Audio
lanes: 1 mode: 1.1 bus-ID: 1-4.4:9 chip-ID: 0c76:2018 class-ID: 0300
API: ALSA v: k6.8.6-zen1-1-zen status: kernel-api tools: N/A
Server-1: PipeWire v: 1.0.5 status: n/a (root, process) with:
Device-1: Intel CNVi: Wi-Fi driver: iwlwifi v: kernel bus-ID: 00:14.3
chip-ID: 8086:54f0 class-ID: 0280
bus-ID: 01:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp1s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-3: ASIX AX88179 Gigabit Ethernet driver: ax88179_178a type: USB
rev: 3.0 speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 2-4.1:4
chip-ID: 0b95:1790 class-ID: ff00 serial: <filter>
IF: enp0s20f0u4u1 state: down mac: <filter>
IF-ID-1: tun0 state: unknown speed: 10000 Mbps duplex: full mac: N/A
IF-ID-3: vmnet8 state: unknown speed: N/A duplex: N/A mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-10:5 chip-ID: 8087:0026
Local Storage: total: 2.73 TiB used: 1.05 TiB (38.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 990 PRO 1TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 4B2QJXD7 temp: 53.9 C
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000LM015-2E8174
tech: HDD rpm: 5400 serial: <filter> fw-rev: 0001 scheme: GPT
ID-1: / raw-size: 914.27 GiB size: 914.27 GiB (100.00%)
used: 31.45 GiB (3.4%) fs: btrfs block-size: 4096 B dev: /dev/dm-0
maj-min: 254:0 mapped: luks-264cadad-c8c3-46fe-b132-32f30ff8b69c
used: 728 KiB (0.2%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1
ID-3: /home raw-size: 914.27 GiB size: 914.27 GiB (100.00%)
ID-4: /var/log raw-size: 914.27 GiB size: 914.27 GiB (100.00%)
ID-5: /var/tmp raw-size: 914.27 GiB size: 914.27 GiB (100.00%)
ID-1: swap-1 type: partition size: 16.94 GiB used: 0 KiB (0.0%)
mapped: luks-0dd705d1-74f7-4ae7-8f55-96ae57f524b8
ID-2: swap-2 type: zram size: 15.4 GiB used: 5.88 GiB (38.2%)
System Temperatures: cpu: 59.0 C mobo: N/A
Memory: total: 16 GiB available: 15.4 GiB used: 12.58 GiB (81.7%)
igpu: 60 MiB
Processes: 369 Power: uptime: 10h 26m states: freeze,mem,disk
reboot, suspend, test_resume image: 6.14 GiB
services: upowerd,xfce4-power-manager Init: systemd v: 255
Packages: pm: pacman pkgs: 1726 libs: 465 tools: pamac,paru Compilers:
clang: 17.0.6 gcc: 13.2.1 Shell: garuda-inxi (sudo) default: Bash v: 5.2.26
running-in: xfce4-terminal inxi: 3.3.34
System install date: 2024-04-11
Last full system update: 2024-04-18 ↻
Failed units: vmware-workstation-server.service vmware.service
╭─fenris@fenris in ~ as 🧙 took 6s
╰─λ
So my issue is, my updates keep failing cause Blackarch for some whatever reason can’t connect to the server properly. I get this…
╭─fenris@fenris in /mnt/veracrypt1/Videos as 🧙 took 1m12s
[🔴] × garuda-update -a
garuda is up to date
core is up to date
extra is up to date
multilib is up to date
chaotic-aur is up to date
blackarch.db failed to download
error: failed retrieving file 'blackarch.db' from ftp.halifax.rwth-aachen.de : SSL connection timeout
error: failed to synchronize all databases (download library error)
chaotic-aur.db failed to download
error: failed retrieving file 'chaotic-aur.db' from garudalinux.org : Resolving timed out after 10002 milliseconds
garuda downloading...
core downloading...
extra downloading...
multilib downloading...
chaotic-aur downloading...
blackarch downloading...
spawn pacman -Su -yy
garuda 72.4 KiB 13.2 KiB/s 00:05 [----------------------] 100%
core 127.5 KiB 16.1 KiB/s 00:08 [----------------------] 100%
extra 8.1 MiB 777 KiB/s 00:11 [----------------------] 100%
multilib 139.1 KiB 20.5 KiB/s 00:07 [----------------------] 100%
chaotic-aur 2.0 MiB 155 KiB/s 00:13 [----------------------] 100%
╭─fenris@fenris in /mnt/veracrypt1/Videos as 🧙 took 2m46s
I then tried to do a garuda-update -a --skip-mirrorlist and I still get this…
╭─fenris@fenris in /mnt/veracrypt1/Videos took 5s
[🔴] × garuda-update -a --skip-mirrorlist
core 127.5 KiB 29.1 KiB/s 00:04 [----------------------] 100%
extra 8.1 MiB 868 KiB/s 00:10 [----------------------] 100%
multilib 139.1 KiB 40.4 KiB/s 00:03 [----------------------] 100%
chaotic-aur 2.0 MiB 94.4 KiB/s 00:22 [----------------------] 100%
error: failed to synchronize all databases (unexpected error)
chaotic-aur 2.0 MiB 226 KiB/s 00:09 [######################] 100%
core downloading...
spawn pacman -Su -y
core is up to date
extra is up to date
chaotic-aur 2.0 MiB 212 KiB/s 00:10 [----------------------] 100%
Any ideas how to fix this?
