Hiya All,
I recently switched and am loving this distro.
I'm running Garuda KDE Dragonized with BlackArch repositories enabled
Mirror Issue
Updating shows an SSL error against the default selected blackarch mirror.
e.g. when running yay -Sy
:: Synchronising package databases...
garuda is up to date
core is up to date
extra is up to date
community is up to date
multilib is up to date
chaotic-aur 2.3 MiB 7.13 MiB/s 00:00 [------------------------------------] 100%
blackarch is up to date
error: failed retrieving file 'blackarch.db' from ftp.halifax.rwth-aachen.de : SSL certificate problem: unableto get local issuer certificate
Notes
- IPv6 is enabled for my setup, however testing with IPv6 disabled still produces the same error
- The mirror worked until a couple of days ago.
- Visiting the mirror in browser shows a valid SSL cert.
- Testing on a fresh install produced the same error when enabling the blckarch mirrors via setup assistant.
- The Refresh mirrors tool in Garuda Assistant doesn't choose a working mirror for BlackArch.
- The issue may be geographically dependent for the choice of fastest mirror
Workaround
I tweaked /etc/pacman.d/blackarch-mirrorlist
to disable the mirror, and it now picks one with a working configuration.
garuda-inxi Output:
Kernel: 5.19.11-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=219e1b8b-78de-4396-b5a3-7f5f6f5b5079 rw rootflags=subvol=@
loglevel=3 nvidia_drm.modeset=1
Type: Desktop Mobo: Micro-Star model: MPG Z390M GAMING EDGE AC (MS-7B50)
v: 1.0 serial: <superuser required> UEFI: American Megatrends v: 1.C1
date: 12/17/2020
Info: model: Intel Core i7-9700K bits: 64 type: MCP arch: Coffee Lake
gen: core 9 level: v3 built: 2018 process: Intel 14nm family: 6
model-id: 0x9E (158) stepping: 0xD (13) microcode: 0xF0
Topology: cpus: 1x cores: 8 smt: <unsupported> cache: L1: 512 KiB
desc: d-8x32 KiB; i-8x32 KiB L2: 2 MiB desc: 8x256 KiB L3: 12 MiB
desc: 1x12 MiB
Speed (MHz): avg: 4787 high: 4799 min/max: 800/4900:5000 scaling:
driver: intel_pstate governor: performance cores: 1: 4753 2: 4797 3: 4791
4: 4799 5: 4799 6: 4791 7: 4781 8: 4790 bogomips: 57600
Type: mmio_stale_data mitigation: Clear CPU buffers; SMT disabled
Device-1: NVIDIA TU104 [GeForce RTX 2080 SUPER] vendor: Micro-Star MSI
driver: nvidia v: 515.76 alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-08) arch: Turing code: TUxxx
process: TSMC 12nm built: 2018-22 pcie: gen: 3 speed: 8 GT/s lanes: 16
ports: active: none off: DP-1,DP-3 empty: DP-2,HDMI-A-1 bus-ID: 01:00.0
chip-ID: 10de:1e81 class-ID: 0300
Device-2: Logitech HD Pro Webcam C920 type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 1-1.3.4:14 chip-ID: 046d:082d
compositor: kwin_x11 driver: X: loaded: nvidia gpu: nvidia,nvidia-nvswitch
Screen-1: 0 s-res: 4480x1440 s-dpi: 81 s-size: 1405x457mm (55.31x17.99")
s-diag: 1477mm (58.17")
Monitor-1: DP-1 note: disabled pos: bottom-r model: Asus VP278
serial: <filter> built: 2018 res: 1920x1080 hz: 60 dpi: 82 gamma: 1.2
max: 1920x1080 min: 640x480
Monitor-2: DP-3 mapped: DP-4 note: disabled pos: primary,top-left
model: MSI MAG321CURV serial: <filter> built: 2019 res: 2560x1440 hz: 60
dpi: 93 gamma: 1.2 size: 700x390mm (27.56x15.35") diag: 801mm (31.5")
ratio: 16:9 modes: max: 3840x2160 min: 640x480
OpenGL: renderer: NVIDIA GeForce RTX 2080 SUPER/PCIe/SSE2 v: 4.6.0 NVIDIA
515.76 direct render: Yes
driver: snd_hda_intel bus-ID: 1-1.3.1.3:15 v: kernel chip-ID: 1038:1297
class-ID: 0300 chip-ID: 8086:a348 class-ID: 0403
Device-2: NVIDIA TU104 HD Audio vendor: Micro-Star MSI
bus-ID: 01:00.1 chip-ID: 10de:10f8 class-ID: 0403
Device-3: SteelSeries ApS Arctis Pro Wireless type: USB
Device-4: Logitech HD Pro Webcam C920 type: USB
Sound Server-1: ALSA v: k5.19.11-zen1-1-zen running: yes
Device-2: Intel Ethernet I219-V vendor: Micro-Star MSI driver: e1000e
v: kernel port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15bc class-ID: 0200
IF: eno2 state: up speed: 1000 Mbps duplex: full mac: <filter>
IF-ID-1: nordlynx state: unknown speed: N/A duplex: N/A mac: N/A
driver: btusb v: 0.8 bus-ID: 1-14:9 chip-ID: 8087:0aaa class-ID: e001
Local Storage: total: 4.99 TiB used: 178.2 GiB (3.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 970 EVO Plus
500GB size: 465.76 GiB block-size: physical: 512 B logical: 512 B
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: 2B2QEXM7
temp: 36.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:1 vendor: Samsung model: SSD 970 EVO Plus
temp: 42.9 C
ID-3: /dev/sda maj-min: 8:0 vendor: OCZ model: TRION100 size: 223.57 GiB
serial: <filter> rev: 11.2 scheme: GPT
ID-4: /dev/sdb maj-min: 8:16 vendor: OCZ model: TRION100 size: 223.57 GiB
ID-5: /dev/sdc maj-min: 8:32 type: USB vendor: Seagate model: Portable
size: 3.64 TiB block-size: physical: 4096 B logical: 512 B type: N/A
serial: <filter> rev: 9300 scheme: GPT
ID-1: / raw-size: 465.46 GiB size: 931.23 GiB (200.06%) used: 178.2 GiB
(19.1%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:3
(0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:2
ID-3: /home raw-size: 465.46 GiB size: 931.23 GiB (200.06%) used: 178.2
GiB (19.1%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:3
ID-4: /var/log raw-size: 465.46 GiB size: 931.23 GiB (200.06%) used: 178.2
ID-5: /var/tmp raw-size: 465.46 GiB size: 931.23 GiB (200.06%) used: 178.2
ID-1: swap-1 type: zram size: 31.29 GiB used: 2 MiB (0.0%) priority: 100
System Temperatures: cpu: 48.0 C pch: 52.0 C mobo: N/A gpu: nvidia
temp: 41 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 26%
Processes: 346 Uptime: 2h 4m wakeups: 0 Memory: 31.29 GiB used: 10.9 GiB
(34.8%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 Packages: pm: pacman pkgs: 1874 libs: 532
tools: octopi,pamac,paru Shell: fish v: 3.5.1 default: Zsh v: 5.9
running-in: konsole inxi: 3.3.21
Garuda (2.6.8-1):
System install date: 2022-09-24
Last full system update: 2022-09-29
