that got an error, but it did something and finished
╭─user@garudabox in ~ took 12s
[🔴] × sudo -E pacman -Sy chaotic-keyring
core is up to date
extra is up to date
community 5.6 MiB 2.12 MiB/s 00:03 [------------------------------------] 100%
multilib is up to date
chaotic-aur 1144.9 KiB 301 KiB/s 00:04 [------------------------------------] 100%
blackarch is up to date
resolving dependencies...
Packages (1) chaotic-keyring-20210617-1
Total Installed Size: 0.02 MiB
Net Upgrade Size: 0.01 MiB
(1/1) checking keys in keyring [------------------------------------] 100%
(1/1) checking package integrity [------------------------------------] 100%
(1/1) loading package files [------------------------------------] 100%
(1/1) checking for file conflicts [------------------------------------] 100%
(1/1) checking available disk space [------------------------------------] 100%
(1/1) Creating Timeshift snapshot before upgrade...
Using system disk as snapshot device for creating snapshots in BTRFS mode
/dev/sda5 is mounted at: /run/timeshift/backup, options: rw,relatime,compress=zstd:3,space_cache,autodefrag,subvolid=5,subvol=/
Creating new backup...(BTRFS)
Saving to device: /dev/sda5, mounted at path: /run/timeshift/backup
Created directory: /run/timeshift/backup/timeshift-btrfs/snapshots/2021-06-22_09-43-20
Created subvolume snapshot: /run/timeshift/backup/timeshift-btrfs/snapshots/2021-06-22_09-43-20/@
Created control file: /run/timeshift/backup/timeshift-btrfs/snapshots/2021-06-22_09-43-20/info.json
BTRFS Snapshot saved successfully (0s)
Tagged snapshot '2021-06-22_09-43-20': ondemand
Found theme: /usr/share/grub/themes/garuda-dr460nized/theme.txt
Found initrd image: /boot/intel-ucode.img /boot/initramfs-linux-zen.img
Found fallback initrd image(s) in /boot: initramfs-linux-zen-fallback.img
Found Manjaro Linux (21.0.6) on /dev/sda2
Detecting snapshots ...
Info: Separate boot partition not detected
Found snapshot: 2021-06-22 09:43:20 | timeshift-btrfs/snapshots/2021-06-22_09-43-20/@
Found snapshot: 2021-06-22 08:20:39 | timeshift-btrfs/snapshots/2021-06-22_08-20-39/@
Found snapshot: 2021-06-22 08:02:54 | timeshift-btrfs/snapshots/2021-06-22_08-02-54/@
Found snapshot: 2021-06-16 20:53:23 | timeshift-btrfs/snapshots/2021-06-16_20-53-23/@
Found 4 snapshot(s)
done
(1/1) upgrading chaotic-keyring [------------------------------------] 100%
==> Appending keys from chaotic.gpg...
==> Locally signing trusted keys in keyring...
gpg: checking the trustdb
gpg: key 1EB2638FF56C0C53: no user ID for key signature packet of class 10
gpg: key 786C63F330D7CB92: no user ID for key signature packet of class 10
gpg: marginals needed: 3 completes needed: 1 trust model: pgp
gpg: depth: 0 valid: 1 signed: 13 trust: 0-, 0q, 0n, 0m, 0f, 1u
gpg: depth: 1 valid: 13 signed: 86 trust: 1-, 0q, 0n, 12m, 0f, 0u
gpg: depth: 2 valid: 80 signed: 24 trust: 80-, 0q, 0n, 0m, 0f, 0u
gpg: next trustdb check due at 2021-08-02
-> Locally signed 1 keys.
==> Importing owner trust values...
gpg: setting ownertrust to 4
==> Updating trust database...
gpg: depth: 1 valid: 13 signed: 86 trust: 0-, 0q, 0n, 13m, 0f, 0u
(1/8) Syncing all file systems...
(2/8) Arming ConditionNeedsUpdate...
(3/8) Foreign/AUR package notification
libappletdecoration 0.8.1-3
libcanberra-pulse 0.30+2+gc0620e4-3
qca 2.3.2-2
(4/8) Orphaned package notification...
=> No orphans found.
(5/8) Checking for .pacnew and .pacsave files...
(6/8) Updating pkgfile database...
(7/8) Checking which packages need to be rebuilt
pactree: error while loading shared libraries: libalpm.so.12: cannot open shared object file: No such file or directory
pacconf: error while loading shared libraries: libalpm.so.12: cannot open shared object file: No such file or directory
(8/8) Syncing all file systems...
I’ll try to upgrade again
Ran the pacman-key stuff again and same thing…
Total Installed Size: 10863.16 MiB
Net Upgrade Size: 165.79 MiB
(597/597) checking keys in keyring [------------------------------------] 100%
downloading required keys...
:: Import PGP key E0959FEA8B550539, "George Rawlinson <grawlinson@archlinux.org>"? [Y/n] y
error: key "E0959FEA8B550539" could not be looked up remotely
error: required key missing from keyring
error: failed to commit transaction (unexpected error)
╭─user@garudabox in ~ took 18s
I get the feeling I should have read the FAQ before my first upgrade instead of after. LOL
Maybe it’s a bad habit ti prioritize my 1st upgrade.
