Hello Garuda users.
I have installed Blackarch on Garuda with the setup assistant and can't find any of them
jim
Hi, welcome to the forum!
Do you have the repository active? Can you post the content of /etc/pacman.conf
to confirm?
Per the template it would be great if you could also post the contents of your garuda-inxi
, even when it doesn't seem entirely relevant.
# /etc/pacman.conf
# See the pacman.conf(5) manpage for option and repository directives
# GENERAL OPTIONS
[options]
# The following paths are commented out with their default values listed.
# If you wish to use different paths, uncomment and update the paths.
#RootDir = /
#DBPath = /var/lib/pacman/
CacheDir = /var/cache/pacman/pkg/
#LogFile = /var/log/pacman.log
#GPGDir = /etc/pacman.d/gnupg/
#HookDir = /etc/pacman.d/hooks/
HoldPkg = pacman glibc
#XferCommand = /usr/bin/curl -L -C - -f -o %o %u
#XferCommand = /usr/bin/wget --passive-ftp -c -O %o %u
[ Read 93 lines ]
used: 39.84 GiB (8.6%) fs: btrfs block-size: 4096 B dev: /dev/sdd2
maj-min: 8:50
maj-min: 8:50
System Temperatures: cpu: 46.2 C mobo: N/A gpu: nouveau temp: 43.0 C
Fan Speeds (RPM): N/A gpu: nouveau fan: 1140
Processes: 300 Uptime: 1h 3m wakeups: 0 Memory: 15.53 GiB
used: 1.96 GiB (12.6%) Init: systemd v: 253 default: graphical
pkgs: 1471 libs: 390 tools: octopi,paru Shell: Bash v: 5.1.16
running-in: xfce4-terminal inxi: 3.3.25
Garuda (2.6.15-1):
System install date: 2023-02-27
Last full system update: 2023-02-28 ↻
I've edited your post to include blocks of text with a triple accent/tilde ~~~
Seems you've gotten only a partial copy of both. You can show the entirety of a file with cat:
cat /etc/pacman.conf
Do you mean you can’t find them in the menu?
If so, you might need blackarch-menus
and this hint:
Sorry for all this. Here is the code you wanted
[core]
Include = /etc/pacman.d/mirrorlist
[extra]
[community]
[multilib]
[chaotic-aur]
Include = /etc/pacman.d/chaotic-mirrorlist
# An example of a custom package repository. See the pacman manpage for
# tips on creating your own repositories.
#[custom]
#SigLevel = Optional TrustAll
#Server = file:///home/custompkgs
[blackarch]
Include = /etc/pacman.d/blackarch-mirrorlist
[root@garuda jim]#
I am not using garuda dragonized gaming edition
It doesn't matter.
The link I posted was from a Dr460nized user, but the tool creates menu entries with a pacman hook when you install new packages, independently from the DE.
Anyway, as said, your garuda-inxi is cut, and does not provide much information.
Me too!
Again
Please, post terminal input and output as text formatted between three ~ in first and last line.
my terminal text
my terminal text
Is root your user name?
Please, post full garuda-inxi.
I have installed the new version of Garuda that does not come with blackarch and had to be installed with the setup assistant.
No root is not my user name. If you look above it you will see my user name.
Technetium. I can't find any accent/tilde~~~/' ' ' any where in my edited code.
'my terminal text' what terminal text is that
jim@garuda ~]$ garuda-inxi
Kernel: 6.1.14-1-lts arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=f96c30ff-eb8f-4e96-8cb1-b44078dfd1e4 rw rootflags=subvol=@
loglevel=3 ibt=off
Mobo: ASUSTeK model: TUF GAMING B550-PLUS v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 2806
date: 10/27/2022
Info: model: AMD Ryzen 5 3500X bits: 64 type: MCP arch: Zen 2 gen: 3
desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB L3: 32 MiB
desc: 2x16 MiB
Speed (MHz): avg: 2199 high: 2200 min/max: 2200/4120 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2195 2: 2200
3: 2200 4: 2200 5: 2200 6: 2200 bogomips: 43136
Device-1: NVIDIA GK104 [GeForce GTX 760] vendor: Gigabyte driver: nouveau
v: kernel non-free: series: 470.xx+ status: legacy-active (EOL~2023/24)
arch: Kepler code: GKxxx process: TSMC 28nm built: 2012-18 pcie: gen: 1
speed: 2.5 GT/s lanes: 16 link-max: gen: 3 speed: 8 GT/s ports:
active: DP-1 empty: DVI-D-1,DVI-I-1,HDMI-A-1 bus-ID: 0a:00.0
chip-ID: 10de:1187 class-ID: 0300 temp: 38.0 C
Display: x11 server: X.Org v: 21.1.7 compositor: xfwm v: 4.18.0 driver: X:
loaded: nouveau unloaded: modesetting alternate: fbdev,nv,vesa dri: nouveau
gpu: nouveau display-ID: :0.0 screens: 1
Monitor-1: DP-1 model: Dell P2417H serial: <filter> built: 2016
res: 1920x1080 hz: 60 dpi: 93 gamma: 1.2 size: 527x296mm (20.75x11.65")
diag: 604mm (23.8") ratio: 16:9 modes: max: 1920x1080 min: 720x400
missing.
Device-1: NVIDIA GK104 HDMI Audio vendor: Gigabyte driver: snd_hda_intel
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3
speed: 8 GT/s bus-ID: 0a:00.1 chip-ID: 10de:0e0a class-ID: 0403
Sound API: ALSA v: k6.1.14-1-lts running: yes
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: f000 bus-ID: 09:00.0
IF: enp9s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Local Storage: total: 5.46 TiB used: 39.84 GiB (0.7%)
model: WD Blue SN570 500GB size: 465.76 GiB block-size: physical: 512 B
rev: 234100WD temp: 30.9 C scheme: MBR
ID-2: /dev/nvme1n1 maj-min: 259:2 vendor: Samsung model: SSD 980 500GB
lanes: 4 type: SSD serial: <filter> rev: 2B4QFXO7 temp: 32.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000DX001-SSHD-8GB
type: HDD rpm: 7200 serial: <filter> rev: CC61 scheme: GPT
model: WD10EVDS-63N5B1 size: 931.51 GiB block-size: physical: 512 B
logical: 512 B speed: 3.0 Gb/s type: N/A serial: <filter> rev: 1A01
scheme: MBR
ID-5: /dev/sdc maj-min: 8:32 vendor: Seagate model: ST3500418AS
size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
type: HDD rpm: 7200 serial: <filter> rev: CC46 scheme: MBR
ID-6: /dev/sdd maj-min: 8:48 vendor: Western Digital
model: WD5000AAKX-001CA0 size: 465.76 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s type: N/A serial: <filter> rev: 1H15
ID-7: /dev/sde maj-min: 8:64 vendor: Seagate model: ST1000DX001-1CM162
type: HDD rpm: 7200 serial: <filter> rev: CC43 scheme: GPT
used: 39.84 GiB (8.6%) fs: btrfs dev: /dev/sdd2 maj-min: 8:50
used: 608 KiB (0.2%) fs: vfat dev: /dev/sdd1 maj-min: 8:49
System Temperatures: cpu: 40.2 C mobo: N/A gpu: nouveau temp: 38.0 C
Fan Speeds (RPM): N/A gpu: nouveau fan: 900
Processes: 305 Uptime: 11m wakeups: 0 Memory: 15.53 GiB
used: 1.97 GiB (12.7%) Init: systemd v: 253 default: graphical
Garuda (2.6.15-1):
[jim@garuda ~]$
Formatting edited by @Technetium
Again
my terminal text
my terminal text
We have edited your previous posts, now it’s time for you, at your leisure, to open them and see what we have changed.
Here again the short form, there is also a longer version that goes a different way.
