Looks like the Beautyline weather icon is stuck. It’s stuck on ‘cloudy with rain’ even when it’s bright sunshine with no clouds. You might want to fix this next time there is a Beautyline update. There is no inxi because there are no problems.
thx
thx
If I recall correctly, it has been this way for years now.
I’m not sure if new icons need to be contributed to BeautyLine, or if the existing icons are not named in a way that the weather app can use but my guess would be one of those two things is the cause of the issue.
Thanks for the detailed explanation, which helps clarify a few things. I was starting to think it was just something on my end, but seeing that it behaves differently on other distros makes me think it’s likely a packaging or theme compatibility issue specific to Garuda. Hopefully, someone from the team can take a look or confirm if it’s related to the icon naming.It wouldd be great to see it working properly again in a future update.
I think its how the widgets call for it. at least in plasma 6. I don’t have the chaotic Beautyline installed just the one from pling and its still weird depending on the weather widget used. They all show something different. The one it picks for clear day might be confusing as it seems to pick a cloud with a rainbow an it kinda looks like rain. But then there is a real rain icon an one with lighting it picks on rainy days.
So if anything maybe that is where its not set right or miss labeled on the devs side. Since it’s like that even on nix.
