Hi, I decided to install Garuda KDE Dr46onized because I really liked what I saw while testing the live media. My WiFi adapter was recognised during testing and I was able to join my home network no problem, but since installing I have to 'modprobe brcmfmac' after every reboot. What's the best way to automate this command on each startup?
I've seen this asked in a few similar threads, so here's the output of inxi -Fxxxza :
Kernel: 5.10.2-104-tkg-bmq x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: intel_pstate=passive
BOOT_IMAGE=/@/boot/vmlinuz-linux-tkg-bmq
root=UUID=e0fa4565-685f-4ef3-8124-181edfbca9b8 rw rootflags=subvol=@
Desktop: KDE Plasma 5.20.4 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11
dm: SDDM Distro: Garuda Linux
Type: Laptop System: Dell product: XPS 15 9550 v: N/A serial: <filter>
Chassis: type: 9 serial: <filter>
Mobo: Dell model: 0N7TVV v: A00 serial: <filter> UEFI: Dell v: 1.13.1
date: 12/12/2019
Info: Quad Core model: Intel Core i7-6700HQ bits: 64 type: MT MCP
arch: Skylake-S family: 6 model-id: 5E (94) stepping: 3 microcode: E2
L2 cache: 6 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
bogomips: 41646
Speed: 3461 MHz min/max: 800/3500 MHz Core speeds (MHz): 1: 3461 2: 3117
3: 3235 4: 3134 5: 3113 6: 3102 7: 3143 8: 3102
Type: l1tf
Type: tsx_async_abort mitigation: Clear CPU buffers; SMT vulnerable
Device-1: Intel HD Graphics 530 vendor: Dell XPS 15 9550 driver: i915
v: kernel bus ID: 00:02.0 chip ID: 8086:191b
Device-2: NVIDIA GM107M [GeForce GTX 960M] vendor: Dell XPS 15 9550
driver: nvidia v: 455.45.01 alternate: nouveau,nvidia_drm
bus ID: 01:00.0 chip ID: 10de:139b
Device-3: Sunplus Innovation Integrated_Webcam_HD type: USB
driver: uvcvideo bus ID: 1-12:4 chip ID: 1bcf:2b95
Display: x11 server: X.org 1.20.10 compositor: kwin_x11
driver: modesetting,nvidia alternate: fbdev,intel,nouveau,nv,vesa
resolution: <missing: xdpyinfo>
OpenGL: renderer: Mesa Intel HD Graphics 530 (SKL GT2)
v: 4.6 Mesa 20.3.1 direct render: Yes
vendor: Dell XPS 15 9550 driver: snd_hda_intel v: kernel bus ID: 00:1f.3
chip ID: 8086:a170
Sound Server: ALSA v: k5.10.2-104-tkg-bmq
Device-1: Broadcom BCM43602 802.11ac Wireless LAN SoC vendor: Dell
driver: brcmfmac v: kernel port: e000 bus ID: 02:00.0 chip ID: 14e4:43ba
Local Storage: total: 476.94 GiB used: 11.13 GiB (2.3%)
model: PM951 NVMe 512GB size: 476.94 GiB block size: physical: 512 B
logical: 512 B speed: 31.6 Gb/s lanes: 4 serial: <filter> rev: BXV77D0Q
temp: 38.9 C
ID-1: / raw size: 476.64 GiB size: 476.64 GiB (100.00%)
used: 11.13 GiB (2.3%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-2: /boot/efi raw size: 300 MiB size: 299.4 MiB (99.80%)
used: 560 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw size: 476.64 GiB size: 476.64 GiB (100.00%)
ID-4: /var/log raw size: 476.64 GiB size: 476.64 GiB (100.00%)
ID-5: /var/tmp raw size: 476.64 GiB size: 476.64 GiB (100.00%)
ID-1: swap-1 type: zram size: 1.94 GiB used: 0 KiB (0.0%)
priority: 32767 dev: /dev/zram0
ID-2: swap-2 type: zram size: 1.94 GiB used: 0 KiB (0.0%)
priority: 32767 dev: /dev/zram1
ID-3: swap-3 type: zram size: 1.94 GiB used: 0 KiB (0.0%)
priority: 32767 dev: /dev/zram2
ID-4: swap-4 type: zram size: 1.94 GiB used: 0 KiB (0.0%)
priority: 32767 dev: /dev/zram3
ID-5: swap-5 type: zram size: 1.94 GiB used: 0 KiB (0.0%)
priority: 32767 dev: /dev/zram4
ID-6: swap-6 type: zram size: 1.94 GiB used: 0 KiB (0.0%)
priority: 32767 dev: /dev/zram5
ID-7: swap-7 type: zram size: 1.94 GiB used: 0 KiB (0.0%)
priority: 32767 dev: /dev/zram6
ID-8: swap-8 type: zram size: 1.94 GiB used: 0 KiB (0.0%)
priority: 32767 dev: /dev/zram7
System Temperatures: cpu: 65.0 C mobo: N/A
Fan Speeds (RPM): cpu: 2514 fan-2: 2466
Processes: 240 Uptime: 32m wakeups: 1 Memory: 15.48 GiB
used: 3.21 GiB (20.7%) Init: systemd v: 247 Compilers: gcc: 10.2.0
clang: 11.0.0 Packages: pacman: 1093 lib: 271 Shell: fish v: 3.1.2
running in: konsole inxi: 3.2.01
Thanks for any help
