I am running Garuda on a Lenovo Thinkpad X380 Yoga. I am really enjoying learning about Arch (have been on Fedora and Ubuntu for several years).
On another post, I was mentioning battery life and it was suggested that I select "Enable Powersaver Tweaks." When I select that it says there is a conflict with "Enable Performance Tweaks." If I attempt to disable "Enable Performance Tweaks" there seems to be several dependencies that will be removed.
Can I safely disable the performance tweaks without breaking Garuda on my system?
Hi All,
Just to follow up. I did remove the conflicting "Enable Performance Tweaks" and install the "Enable Powersaver Tweaks." I am seeing significant battery improvement without any noticeable performance penalties.
Thanks to the Garuda and Arch teams for an awesome distro!
