Kernel: 6.0.12-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=abd777b9-4019-424d-b40b-01cd38fb38db rw rootflags=subvol=@
splash rd.udev.log_priority=3 vt.global_cursor_default=0 loglevel=3
Desktop: i3 v: 4.21.1 info: i3bar vt: 7 dm: LightDM v: 1.32.0
Type: Laptop System: LENOVO product: 20AMS1FW00 v: ThinkPad X240
Mobo: LENOVO model: 20AMS1FW00 serial: <superuser required>
UEFI-[Legacy]: LENOVO v: GIET76WW (2.26 ) date: 08/27/2014
ID-1: BAT0 charge: 17.8 Wh (99.4%) condition: 17.9/23.2 Wh (77.2%)
volts: 12.2 min: 11.1 model: SANYO 45N1773 type: Li-ion serial: <filter>
status: not charging
ID-2: BAT1 charge: 25.2 Wh (67.9%) condition: 37.1/47.5 Wh (78.1%)
volts: 10.2 min: 10.8 model: LGC 45N1735 type: Li-ion serial: <filter>
Info: model: Intel Core i5-4300U bits: 64 type: MT MCP arch: Haswell
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 849 high: 1003 min/max: 800/2900 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 800 2: 798 3: 1003
4: 798 bogomips: 19955
Device-1: Intel Haswell-ULT Integrated Graphics vendor: Lenovo ThinkPad X240
driver: i915 v: kernel arch: Gen-7.5 process: Intel 22nm built: 2013 ports:
active: eDP-1 empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2 bus-ID: 00:02.0
chip-ID: 8086:0a16 class-ID: 0300
Device-2: Lite-On Integrated Camera type: USB driver: uvcvideo
bus-ID: 2-8:3 chip-ID: 04ca:7035 class-ID: 0e02
Display: x11 server: X.Org v: 21.1.6 compositor: Picom v: git-b700a
driver: X: loaded: modesetting alternate: fbdev,intel,vesa dri: crocus
s-diag: 414mm (16.31")
Monitor-1: eDP-1 model: AU Optronics 0x106c built: 2012 res: 1366x768
hz: 60 dpi: 126 gamma: 1.2 size: 276x155mm (10.87x6.1") diag: 317mm (12.5")
ratio: 16:9 modes: 1366x768
missing.
Device-1: Intel Haswell-ULT HD Audio vendor: Lenovo ThinkPad X240
driver: snd_hda_intel v: kernel bus-ID: 00:03.0 chip-ID: 8086:0a0c
Device-2: Intel 8 Series HD Audio vendor: Lenovo ThinkPad X240
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:9c20
Sound API: ALSA v: k6.0.12-zen1-1-zen running: yes
Device-1: Intel Ethernet I218-LM vendor: Lenovo ThinkPad X240 driver: e1000e
v: kernel port: 3080 bus-ID: 00:19.0 chip-ID: 8086:155a class-ID: 0200
Device-2: Intel Wireless 7260 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 8086:08b2 class-ID: 0280
bus-ID: 2-7:2 chip-ID: 8087:07dc class-ID: e001
Local Storage: total: 119.24 GiB used: 10.5 GiB (8.8%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: MZ7TD128HAFV-000L1
type: SSD serial: <filter> rev: 4L0Q scheme: MBR
ID-1: / raw-size: 119.24 GiB size: 119.24 GiB (100.00%)
used: 10.5 GiB (8.8%) fs: btrfs dev: /dev/sda1 maj-min: 8:1
ID-2: /home raw-size: 119.24 GiB size: 119.24 GiB (100.00%)
ID-3: /var/log raw-size: 119.24 GiB size: 119.24 GiB (100.00%)
ID-4: /var/tmp raw-size: 119.24 GiB size: 119.24 GiB (100.00%)
ID-1: swap-1 type: zram size: 7.46 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 48.0 C mobo: N/A
Fan Speeds (RPM): fan-1: 2590
Processes: 217 Uptime: 52m wakeups: 1 Memory: 7.46 GiB
used: 2.49 GiB (33.4%) Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.0 Packages: pm: pacman pkgs: 1173
libs: 316 tools: pamac,paru Shell: Bash v: 5.1.16 running-in: xfce4-terminal
inxi: 3.3.24
Garuda (2.6.12-1):
System install date: 2022-12-21
Last full system update: 2022-12-21 ↻
I'm trying to setup a battery element on garuda i3wm, but nothing seems to work? any ideas? I looked over the i3 user guide and the i3status user guide, nothing...
Bonus question: how do I access trackpoint settings on garuda i3wm? I want to set a deadzone and a flat sensativity, no accel. any ideas?
I'm on a thinkpad x240 btw
SGS
21 December 2022 21:15
2
I am on Lenovo
Works.
One problem, per thread, please.
And
reboot.
BTW, no screenshots from terminal, paste as text between three ~ in first and last line.
SGS
21 December 2022 21:23
3
Seems you must check and edit the path.
It looks like <span is missing from the beginning of the format line. Also there is no value for a color declared. Maybe the beginning of the line was deleted by mistake?
I checked the path and it's correct, it brings me to a folder with all the battery info, could it be that tlp or powertop
it's a refubished thinkpad x240 if that helps
edit:
seems like a problem with how pango and i3 read the battery status?
the %status command manifests in a "<span col" element in the bar.
I checked this by commenting out markup=pango, oddly enough it finds the %percentage fine.
any ideas?
I added it, same results.
You added what?
Paste the line into the thread as text so people can see what you are trying to do.
SGS
22 December 2022 03:38
11
battery 0 {
format = "<span color='#008bef'> %status %percentage %remaining %emptytime</span>"
path = "/sys/class/power_supply/BAT0/uevent"
format_down = "No battery"
low_threshold = 10
status_chr = " 🠩"
status_bat = " 🠫"
#status_unk = "[? ukwn ] "
status_full = " "
last_full_capacity = true
hide_seconds = true
integer_battery_capacity = true
SGS
22 December 2022 03:40
12
aswe323:
edit:
the %status command manifests in a “<span col” element in the bar.
"markup"="pango"
works.
Before you start editing files make a backup.
Or restore by /etc/skel/.config/
format = "<span color='#fa4c7e'> %status %percentage // %remaining %emptytime </span>"
thank you for your patience, I was a bit of a dummy trying to copy paste from vim with ctrl shift c.
I just cp the etc/skel/.config/i3status/config into the ~/.config/i3status/ dir. same results.
SGS
22 December 2022 03:54
15
reboot or Super + Shift + r
and
Super + Shift + c
Past the whole config into the thread so we can take a look--it sounds like there must be a typo somewhere.
You have reloaded i3 after making each change? (Meta+Shift+R, or Meta+Shift+C)
Yup, every time.
# i3status configuration file.
# see "man i3status" for documentation.
# color_good = "#00e6ac"
# color_bad = "#ff0000"
# color_degraded = "#ffff66"
# It is important that this file is edited as UTF-8.
# The following line should contain a sharp s:
# ß
# If the above line is not correctly displayed, fix your editor first!
general {
output_format = "i3bar"
colors = true
#color_good = "#2E588E"
#color_degraded = "#FFFF00"
#color_bad = "#FF0000"
interval = 1
"markup"="pango"
order += "disk /"
#order += "wireless _first_"
#order += "ethernet _first_"
order += "battery all"
#order += "load"
order += "cpu_temperature 0"
order += "cpu_temperature 1"
#order += "cpu_temperature 2"
#order += "cpu_temperature 3"
#order += "cpu_temperature 4"
order += "volume master"
order += "tztime local"
ipv6 {
format_up = "%ip"
format_down = ""
wireless _first_ {
# format_up = "W: (%quality at %essid) %ip"
# format_down = "W: down"
format_up = "<span color='#FFFFFF'>[ ]: On: %essid (%quality) %ip</span>"
format_down = "" #"[ ] Wifi: down"
ethernet _first_ {
# if you use %speed, i3status requires root privileges
format_up = "<span color='#FFFFFF'>%ip | %speed </span>"
format_down = " no lan "
battery all {
format = "<span color='#FEFF72'> %status: %percentage %remaining %emptytime </span>"
#'#fa4c7e'
status_chr = "<span color='#00e64d'>[ ] </span> "
status_bat = "<span color='#8080ff' >[ ] </span>"
status_full = "<span color='#66FF99'> [ ] </span>"
path = "/sys/class/power_supply/BAT%d/uevent"
low_threshold = 10
# last_full_capacity = true
hide_seconds = true
tztime local {
format = "◔ %H:%M:%S | %a. %d.%m.%Y "
locale = "de_DE.UTF-8"
load {
format = "%1min"
cpu_temperature 0 {
format = "T: %degrees °C"
path = "/sys/devices/platform/coretemp.0/hwmon/hwmon*/temp1_input"
cpu_temperature 1 {
path = "/sys/devices/platform/coretemp.0/hwmon/hwmon*/temp2_input"
cpu_temperature 2 {
path = "/sys/devices/platform/coretemp.0/hwmon/hwmon*/temp3_input"
cpu_temperature 3 {
path = "/sys/devices/platform/coretemp.0/hwmon/hwmon*/temp4_input"
cpu_temperature 4 {
path = "/sys/devices/platform/coretemp.0/hwmon/hwmon*/temp5_input"
disk "/" {
# format = " hdd %avail "
format = " ⛁ %avail "
volume master {
format = "<span color='#FFFFFF'>[VOL]: %volume </span>"
format_muted = "<span color='#cfafc8'>[ ]: muted (%volume) </span>"
device = "default"
mixer = "Master"
mixer_idx = 0
SGS
22 December 2022 04:00
19
# ß
general {
colors = true
interval = 1
"markup"="pango"
order += "disk /"
#order += "load"
order += "battery 0"
ipv6 {
format_up = "%ip"
format_down = ""
wireless _first_ {
# format_up = "W: (%quality at %essid) %ip" On: %essid %ip
format_up = "%quality"
ethernet _first_ {
format_up = "%ip | %speed"
battery 0 {
low_threshold = 10
status_chr = " 🠩"
status_bat = " 🠫"
status_full = " "
hide_seconds = true
tztime local {
# format = "%Y-%m-%d %H:%M:%S %Z "
# format = "<span color='#ffffff'>%time</span>"
format = " ◔ %H:%M:%S | %a. %d.%m.%Y "
load {
format = "load %1min"
cpu_temperature 0 {
format = " %degrees°C"
cpu_temperature 1 {
cpu_temperature 2 {
cpu_temperature 3 {
cpu_temperature 4 {
disk "/" {
format = "⛁ %avail "
volume master {
format = "<span color='#cccb00'>🎝 %volume</span>"
format_muted = "<span color='#ff0000'> muted (%volume)</span>"
device = "default"
mixer = "Master"
mixer_idx = 0
#battery all {
#POWER_SUPPLY_NAME=BAT0
#POWER_SUPPLY_TYPE=Battery
#POWER_SUPPLY_STATUS=Discharging
#POWER_SUPPLY_PRESENT=1
#POWER_SUPPLY_TECHNOLOGY=Li-poly
#POWER_SUPPLY_CYCLE_COUNT=45
#POWER_SUPPLY_VOLTAGE_MIN_DESIGN=7680000
#POWER_SUPPLY_VOLTAGE_NOW=7388000
#POWER_SUPPLY_POWER_NOW=17927000
#POWER_SUPPLY_ENERGY_FULL_DESIGN=60000000
#POWER_SUPPLY_ENERGY_FULL=59630000
#POWER_SUPPLY_ENERGY_NOW=17060000
#POWER_SUPPLY_CAPACITY=28
#format = "<span color='#FEFF72'> %status: %percentage </span>"
#// %remaining %emptytime"
#format_down = "No battery"
#'#fa4c7e'
# status_chr = "<span color='#00e64d'>[ ] </span> "
# status_bat = "<span color='#8080ff' >[ ] </span>"
# status_unk = "[? ukwn ] "
# status_full = "<span color='#66FF99'> [ ] </span>"
# path = "/sys/class/power_supply/BAT%d/uevent"
# low_threshold = 10
# hide_seconds = true
# integer_battery_capacity = true
I am to tired for meld
I tried adding the battery 0 to the order, and adding your battery 0 config block too, same result, just an empty element on the bar.
All I can think of is maybe you are pulling status unknown somehow and it’s throwing a blank icon to the tool.
Can you double-check this? Post to the thread:
cat /sys/class/power_supply/BAT%d/uevent
I obv subsititued the %d with a number
cat /sys/class/power_supply/BAT0/uevent
POWER_SUPPLY_STATUS=Full
POWER_SUPPLY_TECHNOLOGY=Li-ion
POWER_SUPPLY_CYCLE_COUNT=0
POWER_SUPPLY_VOLTAGE_MIN_DESIGN=11100000
POWER_SUPPLY_VOLTAGE_NOW=12326000
POWER_SUPPLY_POWER_NOW=0
POWER_SUPPLY_ENERGY_FULL_DESIGN=23200000
POWER_SUPPLY_ENERGY_FULL=17870000
POWER_SUPPLY_ENERGY_NOW=17870000
POWER_SUPPLY_CAPACITY=100
POWER_SUPPLY_CAPACITY_LEVEL=Full
POWER_SUPPLY_MODEL_NAME=45N1773
POWER_SUPPLY_MANUFACTURER=SANYO
POWER_SUPPLY_SERIAL_NUMBER= 346
I'll reintarate and say that whne I disable pango and remove all the ... elements everything works kinda fine...
# ß
general {
colors = true
interval = 1
#"markup"="pango"
order += "disk /"
#order += "battery 0"
#order += "load"
ipv6 {
format_up = "%ip"
format_down = ""
wireless _first_ {
ethernet _first_ {
battery 0 {
low_threshold = 10
status_chr = " 🠩"
status_bat = " 🠫"
status_full = " "
hide_seconds = true
battery all {
format = "%status %percentage %remaining %emptytime"
#'#fa4c7e'
status_chr = "[ ] "
status_bat = "[ ]"
status_full = "[ ]"
low_threshold = 10
hide_seconds = true
#battery all {
##format = "<span color='#FEFF72'> %status: %percentage %remaining %emptytime </span>"
#format = "<span color='#008bef'> %status %percentage %remaining %emptytime</span>"
##'#fa4c7e'
## last_full_capacity = true
#tztime local {
#format = "◔ %H:%M:%S | %a. %d.%m.%Y "
#locale = "de_DE.UTF-8"
load {
format = "%1min"
cpu_temperature 0 {
cpu_temperature 1 {
cpu_temperature 2 {
cpu_temperature 3 {
cpu_temperature 4 {
disk "/" {
volume master {
#format = "<span color='#FFFFFF'>[VOL]: %volume </span>"
format = "[VOL]: %volume "
#format_muted = "<span color='#cfafc8'>[ ]: muted (%volume) </span>"
format_muted = "[ ]: muted (%volume) "
device = "default"
mixer = "Master"
mixer_idx = 0
