Kernel: 6.4.11-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=e980f10a-9cc2-49eb-afc0-0f08d79aef1e rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.27.7 tk: Qt v: 5.15.10 wm: kwin_x11 dm: SDDM
Type: Laptop System: ASUSTeK product: ASUS EXPERTBOOK B1400CEAEY_B1400CEAE
v: 1.0 serial: <filter>
Mobo: ASUSTeK model: B1400CEAEY v: 1.0 serial: <filter> UEFI: ASUSTeK
v: B1400CEAEY.320 date: 11/04/2022
ID-1: BAT0 charge: 35.4 Wh (100.0%) condition: 35.4/42.1 Wh (84.1%)
volts: 11.8 min: 11.8 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
status: not charging cycles: 226
Info: model: 11th Gen Intel Core i5-1135G7 socket: U3E1 bits: 64
type: MT MCP arch: Tiger Lake gen: core 11 level: v4 note: check built: 2020
microcode: 0xAC
L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 5 MiB desc: 4x1.2 MiB L3: 8 MiB
desc: 1x8 MiB
Speed (MHz): avg: 849 high: 1200 min/max: 400/4200 base/boost: 3800/4200
scaling: driver: intel_pstate governor: powersave volts: 1.0 V
ext-clock: 100 MHz cores: 1: 650 2: 601 3: 1100 4: 596 5: 396 6: 1200
7: 1094 8: 1162 bogomips: 38707
Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: ASUSTeK
driver: i915 v: kernel arch: Gen-12.1 process: Intel 10nm built: 2020-21
ports: active: eDP-1 empty: DP-1, DP-2, DP-3, HDMI-A-1 bus-ID: 00:02.0
chip-ID: 8086:9a49 class-ID: 0300
Device-2: IMC Networks USB2.0 HD UVC WebCam driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-5:2 chip-ID: 13d3:56a2
Display: server: X.Org v: 21.1.8 with: Xwayland v: 23.2.0
Monitor-1: eDP-1 model: ChiMei InnoLux 0x14d4 built: 2020 res: 1920x1080
hz: 60 dpi: 158 gamma: 1.2 size: 309x173mm (12.17x6.81") diag: 354mm (13.9")
ratio: 16:9 modes: 1920x1080
API: OpenGL v: 4.6 Mesa 23.1.6 renderer: Mesa Intel Xe Graphics (TGL GT2)
direct-render: Yes
Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: ASUSTeK
chip-ID: 8086:a0c8 class-ID: 0401
API: ALSA v: k6.4.11-zen2-1-zen status: kernel-api tools: N/A
Server-1: PipeWire v: 0.3.77 status: n/a (root, process) with:
Device-1: Intel Wi-Fi 6 AX201 driver: iwlwifi v: kernel bus-ID: 00:14.3
Device-2: Intel Ethernet I219-V driver: e1000e v: kernel port: N/A
bus-ID: 00:1f.6 chip-ID: 8086:15fc class-ID: 0200
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:3 chip-ID: 8087:0026
lmp-v: 11 status: discoverable: no pairing: no class-ID: 7c010c
Local Storage: total: 476.94 GiB used: 123.95 GiB (26.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: PC SN530
SDBPNPZ-512G-1002 size: 476.94 GiB block-size: physical: 512 B
fw-rev: 21106000 temp: 44.9 C scheme: GPT
SMART: yes health: PASSED on: 37d 22h cycles: 599
read-units: 69,092,782 [35.3 TB] written-units: 29,261,239 [14.9 TB]
ID-1: / raw-size: 200.24 GiB size: 200.24 GiB (100.00%)
used: 123.9 GiB (61.9%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p5
maj-min: 259:5
used: 52.9 MiB (55.1%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1
ID-3: /home raw-size: 200.24 GiB size: 200.24 GiB (100.00%)
maj-min: 259:5
ID-4: /var/log raw-size: 200.24 GiB size: 200.24 GiB (100.00%)
maj-min: 259:5
ID-5: /var/tmp raw-size: 200.24 GiB size: 200.24 GiB (100.00%)
maj-min: 259:5
ID-1: swap-1 type: zram size: 15.32 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 57.0 C mobo: N/A
Fan Speeds (rpm): cpu: 3500
Processes: 322 Uptime: 3m wakeups: 1 Memory: total: 16 GiB
available: 15.32 GiB used: 7.05 GiB (46.0%) igpu: 64 MiB Init: systemd
v: 254 default: graphical tool: systemctl Compilers: gcc: 13.2.1 Packages:
pm: pacman pkgs: 1383 libs: 432 tools: octopi,paru,yay
inxi: 3.3.29
System install date: 2023-04-28
Last full system update: 2023-08-22
Windows dual boot: Yes
My audio got absolute crazy. Volume doesn't increase/decrease on shortcut buttons if they are pressed too rapidly or held, only if I press them once in somewhat 1.5-2 seconds. When I do it through slider in the system tray tool, it seems to adjust the sound, but the slider then goes either back, or in just random direction. Though it doesn't bug when I use separate sliders for right and left (weird). And one time the volume got absolute crazy and started jumping on its own across three different levels several times a second without any of my input at all.
And in addition to that, sometimes, rarely, the sound starts to sound like some robotic effects. It seem to heal after some time or several times of unplugging/plugging the earphones, I dunno
And btw all that problems apply to both speakers and earphones, so I doubt it's a earphones issue
And none of those problems appear on my dualbooted Windows
Please help, what demon has possessed my laptop
