Hello!
I have issues where when I open certain apps, (like libvirt, or Signal) and no audio is playing, then, there's no more audio (YouTube videos won't even play), and I need to restart my system.
And when I switch to PipeWire (then restart the system), I have no audio, except on the HDMI.
inxi -Faz
╰─λ inxi -Faz
Kernel: 5.15.13-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=73e38ebc-30d4-4dbe-84d1-abca424384be rw [email protected]
quiet
cryptdevice=UUID=62b5a290-0501-458b-ba20-c7ae892b3399:luks-62b5a290-0501-458b-ba20-c7ae892b3399
root=/dev/mapper/luks-62b5a290-0501-458b-ba20-c7ae892b3399 splash
Type: Laptop System: LENOVO product: 82B5 v: Lenovo Legion 5 15ARH05
serial: <superuser required> Chassis: type: 10 v: Lenovo Legion 5 15ARH05
Mobo: LENOVO model: LNVNB161216 v: SDK0J40709 WIN
serial: <superuser required> UEFI: LENOVO v: EUCN33WW date: 09/23/2021
ID-1: BAT0 charge: 35.1 Wh (59.0%) condition: 59.5/60.0 Wh (99.2%)
volts: 15.5 min: 15.4 model: SMP L19M4PC0 type: Li-poly serial: <filter>
status: N/A cycles: 46
Info: model: AMD Ryzen 7 4800H with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 2 family: 0x17 (23) model-id: 0x60 (96) stepping: 1
microcode: 0x8600106
L3: 8 MiB desc: 2x4 MiB
Speed (MHz): avg: 2428 high: 4055 min/max: 1400/2900 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 2527 2: 3652
3: 1616 4: 1823 5: 2817 6: 2941 7: 1763 8: 1637 9: 2630 10: 2139 11: 2062
12: 1951 13: 2845 14: 4055 15: 2015 16: 2383 bogomips: 92626
Device-1: NVIDIA TU117M [GeForce GTX 1650 Ti Mobile] vendor: Lenovo
driver: nvidia v: 495.46 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
chip-ID: 10de:1f95 class-ID: 0300
Device-2: AMD Renoir vendor: Lenovo driver: amdgpu v: kernel
bus-ID: 05:00.0 chip-ID: 1002:1636 class-ID: 0300
Device-3: Syntek Integrated Camera type: USB driver: uvcvideo
bus-ID: 1-3:3 chip-ID: 174f:244c class-ID: 0e02 serial: <filter>
loaded: modesetting,nvidia display-ID: :0 screens: 1
Screen-1: 0 s-res: 4890x1680 s-dpi: 96 s-size: 1290x443mm (50.8x17.4")
s-diag: 1364mm (53.7")
Monitor-1: eDP-1 res: 1920x1080 hz: 120 dpi: 142
size: 344x193mm (13.5x7.6") diag: 394mm (15.5")
Monitor-2: DP-1-0 res: 1050x1680 hz: 60
Monitor-3: HDMI-1-0 res: 1920x1080 hz: 60 dpi: 82
size: 598x336mm (23.5x13.2") diag: 686mm (27")
Device-1: NVIDIA vendor: Lenovo driver: snd_hda_intel v: kernel
Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor
vendor: Lenovo driver: N/A
alternate: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x bus-ID: 05:00.5
Device-3: AMD Family 17h HD Audio vendor: Lenovo driver: snd_hda_intel
v: kernel bus-ID: 05:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound Server-1: ALSA v: k5.15.13-zen1-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.43 running: no
vendor: Lenovo driver: r8169 v: kernel port: 2000 bus-ID: 03:00.0
Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel bus-ID: 04:00.0
chip-ID: 8086:2723 class-ID: 0280
Device-3: ASIX AX88179 Gigabit Ethernet type: USB driver: ax88179_178a
bus-ID: 2-1.2.1:5 chip-ID: 0b95:1790 class-ID: ff00 serial: <filter>
IF: enp5s0f3u1u2u1 state: up speed: 1000 Mbps duplex: full mac: <filter>
bus-ID: 3-3:4 chip-ID: 8087:0029 class-ID: e001
Local Storage: total: 1.38 TiB used: 95.28 GiB (6.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix
model: HFM512GDHTNI-87A0B size: 476.94 GiB block-size: physical: 512 B
rev: 11010C00 temp: 35.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 850 EVO 500GB
type: SSD serial: <filter> rev: 2B6Q scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 type: USB vendor: Samsung model: PSSD T7
size: 465.76 GiB block-size: physical: 512 B logical: 512 B type: SSD
serial: <filter> scheme: MBR
ID-1: / raw-size: 346.52 GiB size: 346.52 GiB (100.00%)
used: 95.28 GiB (27.5%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
mapped: luks-62b5a290-0501-458b-ba20-c7ae892b3399
ID-2: /boot/efi raw-size: 33 MiB size: 32.5 MiB (98.34%)
used: 1.4 MiB (4.2%) fs: vfat dev: /dev/sdb1 maj-min: 8:17
ID-3: /home raw-size: 346.52 GiB size: 346.52 GiB (100.00%)
ID-4: /var/log raw-size: 346.52 GiB size: 346.52 GiB (100.00%)
ID-5: /var/tmp raw-size: 346.52 GiB size: 346.52 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.07 GiB used: 1.8 MiB (0.0%)
System Temperatures: cpu: N/A mobo: N/A gpu: amdgpu temp: 43.0 C
Processes: 401 Uptime: 22m wakeups: 1 Memory: 15.07 GiB
used: 5.14 GiB (34.1%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1697 lib: 478 Shell: fish
v: 3.3.1 running-in: alacritty inxi: 3.3.11
Switching back and forward, wait a few kernel updates that will potentially fix the issue.
