Audio issues with PulseAudio, and no audio with PipeWire
install package plasma-pa
This probably means your devices are configured to use the "Pro Audio" profile rather than e.g. "Analog Output". Check your audio device settings.
(The Pro Audio profile is intended for use with hardware mixers etc.)
This brought be back missing audio category, and control.
Thank you!
I have nothing called "Pro", but I got the audio on my laptop back on the internal speaker, and trough the jack port.
But I still have the issue when I open certain apps, that break the audio, but I'm still using PulseAudio, I'll try PipeWire. (I'll change on PipeWire trough the System configurator, in the Garuda Assistant.)
After installing PipeWire, I do get audio... only trough the HDMI ports.
It showed some with "Pro" in the settings for the Family 17h HD Audio thing, but when I tried to change it, it disapeared, even after a reboot.
Hi guys,
I have a very similar issue, which I described here along with some system info.
Basically no audio, not even playback devices, only mics.
It suddendly happened when I unplugged my USB headset during a google meet meeting.
If I plug it back I get its mic, but no playback sound :smiley:
Also, running inxi -Faz:
Kernel: 5.16.2-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=f4a20d63-c4e3-4b28-b0b0-d2b451d0cb18 rw [email protected]
resume=UUID=44001575-ec3e-40c7-adb0-5fd96fe574f7 loglevel=3
Type: Laptop System: Acer product: Aspire A515-52 v: V1.14
Mobo: WL model: Raticate_WL v: V1.14 serial: <superuser required>
UEFI: Insyde v: 1.14 date: 05/24/2019
ID-1: BAT1 charge: 21.9 Wh (63.1%) condition: 34.7/48.9 Wh (71.0%)
volts: 14.8 min: 15.2 model: LG PABAS0241231 type: Li-ion serial: <filter>
status: Discharging
Device-1: hidpp_battery_1 model: Logitech Craft Advanced Keyboard
status: Discharging
Info: model: Intel Core i7-8565U bits: 64 type: MT MCP arch: Whiskey Lake
family: 6 model-id: 0x8E (142) stepping: 0xB (11) microcode: 0xEA
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 3572 high: 4027 min/max: 400/4600 scaling:
driver: intel_pstate governor: powersave cores: 1: 4027 2: 3882 3: 3466
4: 3297 5: 3503 6: 3402 7: 3502 8: 3500 bogomips: 31999
Device-1: Intel WhiskeyLake-U GT2 [UHD Graphics 620]
vendor: Acer Incorporated ALI driver: i915 v: kernel bus-ID: 00:02.0
chip-ID: 8086:3ea0 class-ID: 0300
Device-2: Chicony HD User Facing type: USB driver: uvcvideo bus-ID: 1-7:3
chip-ID: 04f2:b64f class-ID: 0e02 serial: <filter>
loaded: modesetting display-ID: :0 screens: 1
Screen-1: 0 s-res: 5760x2160 s-dpi: 96 s-size: 1520x570mm (59.8x22.4")
s-diag: 1623mm (63.9")
Monitor-1: eDP-1 res: 1920x1080 hz: 60 dpi: 142
Monitor-2: HDMI-1 res: 3840x2160 hz: 30 dpi: 122
size: 800x335mm (31.5x13.2") diag: 867mm (34.1")
Device-1: Intel Cannon Point-LP High Definition Audio
vendor: Acer Incorporated ALI driver: snd_hda_intel v: kernel
chip-ID: 8086:9dc8 class-ID: 0403
Sound Server-1: ALSA v: k5.16.2-zen1-1-zen running: yes
Sound Server-3: PipeWire v: 0.3.43 running: yes
Device-1: Intel Cannon Point-LP CNVi [Wireless-AC] driver: iwlwifi
v: kernel bus-ID: 00:14.3 chip-ID: 8086:9df0 class-ID: 0280
IF: wlp0s20f3 state: down mac: <filter>
vendor: Acer Incorporated ALI driver: r8169 v: kernel port: 3000
bus-ID: 01:00.1 chip-ID: 10ec:8168 class-ID: 0200
IF: enp1s0f1 state: up speed: 1000 Mbps duplex: full mac: <filter>
IF-ID-1: lxdbrtest0 state: down mac: <filter>
IF-ID-2: minanto state: unknown speed: N/A duplex: N/A mac: N/A
driver: btusb v: 0.8 bus-ID: 1-10:7 chip-ID: 8087:0aaa class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 4 state: up address: <filter>
v: 3.0 port: 4060 bus-ID: 00:17.0 chip-ID: 8086:282a rev: N/A
class-ID: 0104
Local Storage: total: 465.76 GiB used: 80.03 GiB (17.2%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 850 EVO 500GB
type: SSD serial: <filter> rev: 2B6Q scheme: GPT
ID-1: / raw-size: 448.44 GiB size: 448.44 GiB (100.00%)
used: 80.03 GiB (17.8%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-3: /home raw-size: 448.44 GiB size: 448.44 GiB (100.00%)
ID-4: /var/log raw-size: 448.44 GiB size: 448.44 GiB (100.00%)
ID-5: /var/tmp raw-size: 448.44 GiB size: 448.44 GiB (100.00%)
ID-1: swap-1 type: partition size: 17.02 GiB used: 0 KiB (0.0%)
ID-2: swap-2 type: zram size: 15.48 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 56.0 C pch: 56.0 C mobo: N/A
Processes: 324 Uptime: 8m wakeups: 34 Memory: 15.48 GiB
used: 4.87 GiB (31.5%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.1.0 clang: 13.0.0 Packages: 1627 pacman: 1617 lib: 377 flatpak: 10
Shell: fish v: 3.3.1 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.12
I have a red speaker icon with a red minus sign beside It.
I tried the solutions you recommend here but nothing worked, the only thing left to try is switching from pipewire to pulseaudio. Is it worth trying?
