Audio crackling issue on pipewire
so i am using my lenovo laptop with garuda linux and i am facing this werid issue where my audio just starts crackling after some sound and sometimes it fixes automatically sometime i need to restart pipewire services please help me fix this problem
  Kernel: 6.4.7-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
    root=UUID=722c5358-2390-4040-bd30-796be0b675ef rw rootflags=subvol=@
  Desktop: KDE Plasma v: 5.27.6 tk: Qt v: 5.15.10 wm: kwin_wayland vt: 1
  Type: Laptop System: LENOVO product: 82K1 v: IdeaPad Gaming 3 15IHU6
    serial: <superuser required> Chassis: type: 10 v: IdeaPad Gaming 3 15IHU6
  Mobo: LENOVO model: LNVNB161216 v: SDK0T76465 WIN
    serial: <superuser required> UEFI: LENOVO v: H4CN22WW(V1.07)
    date: 11/18/2021
  ID-1: BAT1 charge: 24.5 Wh (55.8%) condition: 43.9/45.0 Wh (97.6%)
    volts: 11.8 min: 11.5 model: Sunwoda L20D3PC2 type: Li-ion serial: <filter>
    status: not charging
  Info: model: 11th Gen Intel Core i5-11300H bits: 64 type: MT MCP
    microcode: 0xAA
    L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 5 MiB desc: 4x1.2 MiB L3: 8 MiB
    desc: 1x8 MiB
  Speed (MHz): avg: 2155 high: 4000 min/max: 400/4400 scaling:
    driver: intel_pstate governor: powersave cores: 1: 4000 2: 732 3: 2942
    4: 1300 5: 4000 6: 1038 7: 1242 8: 1989 bogomips: 49766
  Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: Lenovo
    driver: i915 v: kernel arch: Gen-12.1 process: Intel 10nm built: 2020-21
    ports: active: eDP-1 empty: DP-1, DP-2, DP-3, HDMI-A-1 bus-ID: 00:02.0
    chip-ID: 8086:9a49 class-ID: 0300
  Device-2: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q] vendor: Lenovo
    driver: nvidia v: 535.86.05 alternate: nouveau,nvidia_drm non-free: 535.xx+
    status: current (as of 2023-07) arch: Turing code: TUxxx
    process: TSMC 12nm FF built: 2018-22 pcie: gen: 1 speed: 2.5 GT/s lanes: 4
    link-max: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 02:00.0
    chip-ID: 10de:1f9d class-ID: 0302
  Device-3: Bison Integrated Camera driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6:3 chip-ID: 5986:212b
    class-ID: 0e02
  Display: wayland server: X.org v: 1.21.1.8 with: Xwayland v: 23.1.2
  API: OpenGL v: 4.6 Mesa 23.1.4 renderer: Mesa Intel Xe Graphics (TGL GT2)
    direct-render: Yes
  Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: Lenovo
    chip-ID: 8086:a0c8 class-ID: 0401
  API: ALSA v: k6.4.7-zen1-1-zen status: kernel-api with: aoss
  Server-1: PipeWire v: 0.3.76 status: active with: 1: pipewire-pulse
    status: active 2: pipewire-media-session status: active 3: pipewire-alsa
    type: plugin 4: pw-jack type: plugin tools: pactl,pw-cat,pw-cli
  Device-1: Intel Wi-Fi 6 AX201 driver: iwlwifi v: kernel bus-ID: 00:14.3
    port: 3000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-10:5 chip-ID: 8087:0026
    address: <filter>
  Local Storage: total: 476.94 GiB used: 232.39 GiB (48.7%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Toshiba
    model: KBG40ZNT512G MEMORY size: 476.94 GiB block-size: physical: 512 B
    fw-rev: 0109AELA temp: 61.9 C scheme: GPT
  ID-1: / raw-size: 38.97 GiB size: 38.97 GiB (100.00%)
    used: 23.93 GiB (61.4%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:5
  ID-2: /boot/efi raw-size: 667 MiB size: 665.7 MiB (99.80%)
    used: 580 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p4 maj-min: 259:4
  ID-3: /home raw-size: 58.59 GiB size: 58.59 GiB (100.00%)
    used: 51.76 GiB (88.3%) fs: btrfs dev: /dev/nvme0n1p10 maj-min: 259:10
  ID-4: /var/log raw-size: 38.97 GiB size: 38.97 GiB (100.00%)
  ID-5: /var/tmp raw-size: 38.97 GiB size: 38.97 GiB (100.00%)
  ID-1: swap-1 type: zram size: 7.55 GiB used: 2.58 GiB (34.2%)
  System Temperatures: cpu: 53.0 C mobo: N/A
  Processes: 321 Uptime: 2h 48m wakeups: 1 Memory: total: 8 GiB note: est.
  available: 7.55 GiB used: 5.31 GiB (70.4%) Init: systemd v: 253
  default: graphical tool: systemctl Compilers: gcc: 13.1.1 Packages: 1441
  pm: pacman pkgs: 1427 libs: 413 tools: octopi,paru,yay pm: flatpak pkgs: 14
  Shell: Bash v: 5.1.16 running-in: konsole inxi: 3.3.28
  System install date:     2023-06-29
  Last full system update: 2023-07-29
It seems you are using deprecated session manager for pipewire. Please follow along the below post to reinstall pipewire with the latest session manager wireplumber. Please note following the below steps would ask you to remove pipewire-media-session confirm it’s removal since we will be using wireplumber in it’s place following this reinstall.
not fixed still happening
Do you have audio processor like jamesdsp or easyeffects installed? Also can you provide the output of
systemctl status --user wireplumber
systemctl status --user pipewire
systemctl status --user pipewire-pulse
cat /etc/security/limits.d/99-realtime-privileges.conf
groups $USER
If you get "stuck" after running these commands as in you can't type any more commands just press q and you will have your prompt to type commands back.
● wireplumber.service - Multimedia Service Session Manager
     Loaded: loaded (/usr/lib/systemd/user/wireplumber.service; enabled; preset: enabled)
     Active: active (running) since Mon 2023-07-31 08:39:00 IST; 8min ago
   Main PID: 10100 (wireplumber)
      Tasks: 6 (limit: 9195)
     Memory: 10.0M
        CPU: 251ms
     CGroup: /user.slice/user-1000.slice/user@1000.service/session.slice/wireplumber.service
             └─10100 /usr/bin/wireplumber
Jul 31 08:39:00 devilmaycryy-82k1 systemd[10088]: Started Multimedia Service Session Manager.
Jul 31 08:39:00 devilmaycryy-82k1 wireplumber[10100]: [0:02:01.692743307] [10100] ERROR IPAModule ipa_module.cpp:172 Symbol ipaModuleInfo not found
Jul 31 08:39:00 devilmaycryy-82k1 wireplumber[10100]: [0:02:01.692756737] [10100] ERROR IPAModule ipa_module.cpp:292 v4l2-compat.so: IPA module has no valid info
Jul 31 08:39:00 devilmaycryy-82k1 wireplumber[10100]: [0:02:01.692776184] [10100]  INFO Camera camera_manager.cpp:284 libcamera v0.1.0
Jul 31 08:39:01 devilmaycryy-82k1 wireplumber[10100]: <WpPortalPermissionStorePlugin:0x559e0386b180> Failed to call Lookup: GDBus.Error:org.freedesktop.portal.Error.NotFound: No entry for camera
Jul 31 08:39:02 devilmaycryy-82k1 wireplumber[10100]: Failed to get percentage from UPower: org.freedesktop.DBus.Error.NameHasNoOwner
● pipewire.service - PipeWire Multimedia Service
     Loaded: loaded (/usr/lib/systemd/user/pipewire.service; enabled; preset: enabled)
     Active: active (running) since Mon 2023-07-31 08:39:00 IST; 11min ago
TriggeredBy: ● pipewire.socket
   Main PID: 10098 (pipewire)
      Tasks: 3 (limit: 9195)
     Memory: 17.6M
        CPU: 1.944s
     CGroup: /user.slice/user-1000.slice/user@1000.service/session.slice/pipewire.service
             └─10098 /usr/bin/pipewire
Jul 31 08:39:00 devilmaycryy-82k1 systemd[10088]: Started PipeWire Multimedia Service.
Jul 31 08:39:01 devilmaycryy-82k1 pipewire[10098]: [0:02:01.828193929] [10098] ERROR IPAModule ipa_module.cpp:172 Symbol ipaModuleInfo not found
Jul 31 08:39:01 devilmaycryy-82k1 pipewire[10098]: [0:02:01.828206360] [10098] ERROR IPAModule ipa_module.cpp:292 v4l2-compat.so: IPA module has no valid info
Jul 31 08:39:01 devilmaycryy-82k1 pipewire[10098]: [0:02:01.828222964] [10098]  INFO Camera camera_manager.cpp:284 libcamera v0.1.0
● pipewire-pulse.service - PipeWire PulseAudio
     Loaded: loaded (/usr/lib/systemd/user/pipewire-pulse.service; disabled; preset: enabled)
     Active: active (running) since Mon 2023-07-31 08:39:07 IST; 9min ago
TriggeredBy: ● pipewire-pulse.socket
   Main PID: 12629 (pipewire-pulse)
      Tasks: 2 (limit: 9195)
     Memory: 3.9M
        CPU: 82ms
     CGroup: /user.slice/user-1000.slice/user@1000.service/session.slice/pipewire-pulse.service
             └─12629 /usr/bin/pipewire-pulse
Jul 31 08:39:07 devilmaycryy-82k1 systemd[10088]: Started PipeWire PulseAudio.
@realtime - rtprio 98
@realtime - memlock unlimited
@realtime - nice -11
wheel input lp video realtime devilmaycryy
Hmm, the above info looks fine…
What about this? @Piyushraj
i have easy effects but its happening before installing it
Still. Try disabling it. We have just changed your pipewire session manager so maybe things have changed this time around. We should make sure of it.
kill -SIGKILL $(pgrep easyeffects)
systemctl restart --user pipewire-pulse.socket pipewire.socket wireplumber.service
Perhaps this is the work of a faulty configuration in easyeffects + the deprecated session manager. With the above commands it should be easy to figure this out.
okk i will do this and then see whats happening
i reckon, this happends on my machine too.. but only on bluetooth headset (airpods pro).. the audio is fine until i play a game.. it happens randomly like 10mins later or few secods later after alt-tabbing between apps.. the audio cracking.. i can quickly fix it by switching to hsp/hfp then back to a2dp again.
In my case crackling sound was caused by audio-card goes to sleep for power save reason at startup and so it crack when return active so probably most crackling issue will be solved with this comand on terminal:
echo options snd-hda-intel power_save=0 power_save_controller=N | sudo tee /etc/modprobe.d/hda.conf
terminal will respond : options snd-hda-intel power_save=0 power_save_controller=N
now restart your system and see if issue is solved
yess u are right i happens mostly when i play games in bottles and alt tabbing fixes this problem
