Hello,
Loving the OS, with one big hitch so far that I can't seem to fix. My audio for some reason, seems to split the balance between left and right channels all by itself when I adjust the volume up or down. There doesn't seem to be a 'lock' function so that they don't unbalance. Anyone else ever run into this issue with KDE, or know how to fix it? Thank you.
root=UUID=23fd0220-af2d-4416-beb7-d72c3240b4d7 rw rootflags=subvol=@
Type: Desktop System: ASUS product: N/A v: N/A serial:
Mobo: ASUSTeK model: TUF GAMING Z590-PLUS v: Rev 1.xx
serial: UEFI: American Megatrends v: 1203
date: 10/28/2021
ID-1: hidpp_battery_0 charge: 91% condition: N/A volts: 4.1 min: N/A
model: Logitech G903 Wired/Wireless Gaming Mouse type: N/A serial:
Device-1: ps-controller-battery-7c:66:ef:24:47:6d model: N/A serial: N/A
charge: N/A status: discharging
Info: model: Intel Core i9-10900K bits: 64 type: MT MCP arch: Comet Lake
family: 6 model-id: 0xA5 (165) stepping: 5 microcode: 0xEE
Topology: cpus: 1x cores: 10 tpc: 2 threads: 20 smt: enabled cache:
L1: 640 KiB desc: d-10x32 KiB; i-10x32 KiB L2: 2.5 MiB desc: 10x256 KiB
L3: 20 MiB desc: 1x20 MiB
Speed (MHz): avg: 4900 high: 4901 min/max: 800/5300 scaling:
driver: intel_pstate governor: performance cores: 1: 4900 2: 4900 3: 4900
4: 4900 5: 4900 6: 4900 7: 4900 8: 4900 9: 4900 10: 4900 11: 4900
12: 4901 13: 4900 14: 4900 15: 4900 16: 4900 17: 4901 18: 4900 19: 4900
20: 4900 bogomips: 147994
Device-1: AMD Vega 10 XL/XT [Radeon RX 56/64] driver: amdgpu v: kernel
pcie: gen: 3 speed: 8 GT/s lanes: 16 ports: active: DP-3
empty: DP-1,DP-2,HDMI-A-1 bus-ID: 03:00.0 chip-ID: 1002:687f
s-diag: 777mm (30.58")
Monitor-1: DP-3 mapped: DisplayPort-2 model: AOC AG271QG4
serial: built: 2018 res: 2560x1440 dpi: 109 gamma: 1.2
max: 2560x1440 min: 720x400
OpenGL:
renderer: AMD Radeon RX Vega (vega10 LLVM 13.0.1 DRM 3.44 5.17.1-zen1-1-zen)
v: 4.6 Mesa 22.0.1 direct render: Yes
Device-1: Intel vendor: ASUSTeK driver: snd_hda_intel v: kernel
bus-ID: 00:1f.3 chip-ID: 8086:f0c8 class-ID: 0403
Device-2: AMD Vega 10 HDMI Audio [Radeon 56/64] driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 03:00.1
chip-ID: 1002:aaf8 class-ID: 0403
Device-3: Creative Sound Blaster X3 type: USB
driver: cdc_acm,hid-generic,snd-usb-audio,usbhid bus-ID: 1-4:2
chip-ID: 041e:3264 class-ID: 0102 serial:
Sound Server-3: PipeWire v: 0.3.50 running: yes
Device-1: Mellanox MT26448 [ConnectX EN 10GigE PCIe 2.0 5GT/s]
driver: mlx4_core v: 4.0-0 pcie: gen: 2 speed: 5 GT/s lanes: 4 link-max:
lanes: 8 port: N/A bus-ID: 05:00.0 chip-ID: 15b3:6750 class-ID: 0200
IF: enp5s0 state: up speed: 10000 Mbps duplex: full mac:
IF: enp7s0 state: up speed: 1000 Mbps duplex: full mac:
IF-ID-1: anbox0 state: down mac:
Device-1: TP-Link UB500 Adapter type: USB driver: btusb v: 0.8
bus-ID: 1-11:6 chip-ID: 2357:0604 class-ID: e001 serial:
Report: bt-adapter ID: hci0 rfk-id: 0 state: up address:
Local Storage: total: 2.26 TiB used: 992.21 GiB (43.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Corsair model: Force MP510
size: 447.13 GiB block-size: physical: 512 B logical: 512 B
speed: 31.6 Gb/s lanes: 4 type: SSD serial: rev: ECFM22.6
temp: 34.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000DM008-2FR102
type: HDD rpm: 7200 serial: rev: 0001 scheme: GPT
used: 359.69 GiB (80.5%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 31.2 GiB used: 3.07 GiB (9.8%)
System Temperatures: cpu: 51.0 C mobo: N/A gpu: amdgpu temp: 39.0 C
mem: 40.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 775
Processes: 523 Uptime: 2h 18m wakeups: 6 Memory: 31.2 GiB
used: 28.58 GiB (91.6%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 clang: 13.0.1 Packages: 1981 pacman: 1969 lib: 562 flatpak: 12
Shell: fish v: 3.4.1 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.15
Garuda (2.6.1-1):
System install date: 2022-02-15
Last full system update: 2022-04-13 â»
Snapshots: Timeshift (maybe)
