since a few Updates my Astro Headset is showing Both Audio Channels before i only had 1 Channel In and 1 Out and it worked, a poor Quality but it Worked... now i got Both Channel In Game and Voice also Surround Sound is Working nice but my Microphone i don´t know its Messed up a bit.
Discord is Streaming all Incoming Sound to the Audience but not the Incoming Voices from Discord (only other Application Sounds) and i dont Know were to start digging if 1 of u had the same Headset and knows the glue plx give me a hint. Thanks a Lot
I Only found a PulseAudio Fix at Github and a Forum from EndeavorOS pointing to that Gist but... only 10 Star and i use pipewire and dunno if that impacts something ...
╰─λ pactl info
Server String: /run/user/1000/pulse/native
Library Protocol Version: 35
Server Protocol Version: 35
Is Local: yes
Client Index: 137
Tile Size: 65472
User Name: nudel
Host Name: Gott
Server Name: PulseAudio (on PipeWire 0.3.42)
Server Version: 15.0.0
Default Sample Specification: float32le 2ch 48000Hz
Default Channel Map: front-left,front-right
Default Sink: alsa_output.usb-Astro_Gaming_Astro_A50-00.pro-output-0
Default Source: alsa_input.usb-Astro_Gaming_Astro_A50-00.pro-input-1
Cookie: cd8b:c50c
[ 3.017758] usb 3-2.4: New USB device found, idVendor=9886, idProduct=0015, bcdDevice= 0.00
[ 3.017761] usb 3-2.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 3.017762] usb 3-2.4: Product: Astro A50
[ 3.017763] usb 3-2.4: Manufacturer: Astro Gaming
[ 3.113279] hid-generic 0003:9886:0015.000A: hiddev103,hidraw9: USB HID v1.00 Device [Astro Gaming Astro A50] on usb-0000:07:00.3-2.4/input6
[ 3.116694] systemd[1]: Finished Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling.
╰─λ lsusb
Bus 006 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 005 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 004 Device 004: ID 2537:1081 Norelsys NS1081
Bus 004 Device 003: ID 05e3:0620 Genesys Logic, Inc. USB3.0 Hub
Bus 004 Device 002: ID 174c:3074 ASMedia Technology Inc. ASM1074 SuperSpeed hub
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 003: ID 0b05:1824 ASUSTek Computer, Inc. ROG SPATHA Receiver
Bus 003 Device 006: ID 9886:0015 Astro Gaming A50
Bus 003 Device 005: ID 05e3:0610 Genesys Logic, Inc. Hub
Bus 003 Device 004: ID 0b05:181c ASUSTek Computer, Inc. ROG SPATHA
Bus 003 Device 002: ID 174c:2074 ASMedia Technology Inc. ASM1074 High-Speed hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 007: ID 0b05:18f3 ASUSTek Computer, Inc. AURA LED Controller
Bus 001 Device 005: ID 1b1c:0c10 Corsair Commander PRO
Bus 001 Device 006: ID 1b1c:0c21 Corsair H115iRGBPROXT
Bus 001 Device 004: ID 05e3:0610 Genesys Logic, Inc. Hub
Bus 001 Device 003: ID 05e3:0610 Genesys Logic, Inc. Hub
Bus 001 Device 002: ID 05ac:0256 Apple, Inc. AZIO Retro Classic USB
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
I’d have a look at inxi -Aaz to find out the audio chipset, then look for any other threads/issues on this, the EnOS, and the Arch fora, as well as for any similar models on the Arch wiki.
OK, so there’s an old (and resolved) bug report here:
This indicates support was added in alsa-card-profiles=14.1-2 which has since been replaced by a PipeWire version, currently 1:0.3.42-1 .
Do you have this installed?
I can see there’s an entry for the Astro A50 Gen4 in /usr/lib/udev/rules.d/90-pipewire-alsa.rules :
# Lucidsound LS31
ATTRS{idVendor}=="2f12", ATTRS{idProduct}=="0109", ENV{ACP_PROFILE_SET}="usb-gaming-headset.conf"
# ID 9886:002c is for the Astro A50 Gen4
ATTRS{idVendor}=="9886", ATTRS{idProduct}=="002c", ENV{ACP_PROFILE_SET}="usb-gaming-headset.conf"
# ID 1532:0520 is for the Razer Kraken Tournament Edition
ATTRS{idVendor}=="1532", ATTRS{idProduct}=="0520", ENV{ACP_PROFILE_SET}="usb-gaming-headset.conf"
but this doesn’t match your headset:
So - adapting the existing line, let’s create a new rule to match your headset:
/etc/udev/rules.d/90-astro-50.rules
# ID 9886:0015 is for the Astro A50
ATTRS{idVendor}=="9886", ATTRS{idProduct}=="0015", ENV{ACP_PROFILE_SET}="usb-gaming-headset.conf"
If that works then you can figure out why there’s a different USB ID.
Chat Out like the Old Stereo out
2 Chat Out and Chat In Crashes Audio Config at Testing the Output after switching to any Other Option and then Back the Output Works but Mic nope i see the Amp. going up with my Voice but Discord dont Rekognize me...
3 Pro Audio (best Audio Quality and Both Channel but Mic is Streaming)
4 Chat In only Mic and Works ....
its so weird and every turn from Pro Audio to any other i need to restart for Action...
or just restart the alsa and pipewire ctl's ?
I don't know - it looks like "something else" needs to be done to get this one working. I assume this is a Gen3... there's some mention on the gist about someone doing some more editing but it isn't clear what they actually did.
