╭─[email protected] in ~
╰─λ inxi -Fxaz
Kernel: 5.15.7-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=56bb78b7-6a47-43f7-80ec-23c4a93622ff rw [email protected]
Mobo: ASUSTeK model: ROG CROSSHAIR VIII HERO v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 3402
date: 03/22/2021
Device-1: apple_mfi_fastcharge model: N/A serial: N/A charge: N/A
status: N/A
Info: model: AMD Ryzen 9 3900X bits: 64 type: MT MCP arch: Zen 2
L3: 64 MiB desc: 4x16 MiB
Speed (MHz): avg: 3557 high: 4365 min/max: 2200/4672 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3607 2: 3592
3: 3122 4: 3472 5: 3480 6: 3613 7: 3546 8: 3525 9: 3707 10: 3594 11: 3594
12: 3599 13: 3636 14: 3039 15: 3512 16: 3433 17: 3422 18: 4365 19: 3592
20: 3232 21: 3923 22: 3594 23: 3595 24: 3595 bogomips: 182078
Device-1: NVIDIA GA102 [GeForce RTX 3080] driver: nvidia v: 495.46
alternate: nouveau,nvidia_drm bus-ID: 0a:00.0 chip-ID: 10de:2206
Display: x11 server: X.Org 1.21.1.1 compositor: kwin_x11 driver:
loaded: nvidia note: n/a (using device driver) unloaded: nvidia
Screen-1: 0 s-res: 7680x2160 s-dpi: 144 s-size: 1355x381mm (53.3x15.0")
s-diag: 1408mm (55.4")
Monitor-1: DP-0 res: 3840x2160 hz: 60
Monitor-2: DP-2 res: 3840x2160 hz: 60 dpi: 161
size: 607x345mm (23.9x13.6") diag: 698mm (27.5")
OpenGL: renderer: NVIDIA GeForce RTX 3080/PCIe/SSE2
v: 4.6.0 NVIDIA 495.46 direct render: Yes
Device-1: NVIDIA GA102 High Definition Audio driver: snd_hda_intel
v: kernel bus-ID: 0a:00.1 chip-ID: 10de:1aef class-ID: 0403
Device-2: Astro Gaming A50 type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 3-2.4:7 chip-ID: 9886:0015
Sound Server-1: ALSA v: k5.15.7-zen1-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.41 running: yes
port: e000 bus-ID: 05:00.0 chip-ID: 10ec:8125 class-ID: 0200
Device-2: Intel I211 Gigabit Network vendor: ASUSTeK driver: igb
v: kernel port: d000 bus-ID: 06:00.0 chip-ID: 8086:1539 class-ID: 0200
IF-ID-1: enp7s0f3u1c4i2 state: down mac: <filter>
Local Storage: total: 5.46 TiB used: 417.19 GiB (7.5%)
ID-1: /dev/nvme0n1 maj-min: 259:5 vendor: Samsung model: SSD 960 EVO 1TB
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: 3B7QCXE7
temp: 42.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Samsung
rev: 2B2QEXM7 temp: 43.9 C scheme: MBR
ID-3: /dev/sda maj-min: 8:0 vendor: Seagate model: ST4000LM024-2AN17V
type: HDD rpm: 5526 serial: <filter> rev: 0001 scheme: MBR
used: 417.19 GiB (44.8%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:7
used: 576 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:6
ID-1: swap-1 type: zram size: 15.59 GiB used: 2.5 MiB (0.0%)
System Temperatures: cpu: N/A mobo: N/A gpu: nvidia temp: 49 C
Fan Speeds (RPM): fan-2: 1485 fan-3: 1516 fan-4: 956 fan-5: 1496
fan-6: 1197 gpu: nvidia fan: 30%
Processes: 432 Uptime: 41m wakeups: 1 Memory: 15.59 GiB
used: 3.73 GiB (23.9%) Init: systemd v: 249 tool: systemctl Compilers:
gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1929 lib: 515 Shell: fish
v: 3.3.1 default: Bash v: 5.1.12 running-in: konsole inxi: 3.3.10
╭─[email protected] in ~ took 1s
╰─λ
