When I try to install Anydesk, which is in Chaotic repo, I get
sudo pacman -S anydesk
[sudo] password for shmuel:
resolving dependencies...
warning: cannot resolve "gtkglext", a dependency of "anydesk-bin"
:: The following package cannot be upgraded due to unresolvable dependencies:
anydesk-bin
I get the same error with the AUR package.
my system info:
inxi -F
Host: shmuel-garuda Kernel: 6.10.3-zen1-1-zen arch: x86_64 bits: 64
Desktop: KDE Plasma v: 6.1.3 Distro: Garuda Linux
Type: Desktop Mobo: ASUSTeK model: PRIME B365M-A v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 2208
date: 07/09/2021
ID-1: hidpp_battery_0 charge: 46% condition: N/A
Info: 8-core model: Intel Core i7-9700 bits: 64 type: MCP cache: L2: 2 MiB
Speed (MHz): avg: 800 min/max: 800/4700 cores: 1: 800 2: 800 3: 800 4: 800
5: 800 6: 800 7: 800 8: 800
Device-1: Intel CoffeeLake-S GT2 [UHD Graphics 630] driver: i915 v: kernel
Device-2: USB C Video Adaptor driver: N/A type: USB
Device-3: Microdia USB Live camera driver: snd-usb-audio,uvcvideo
type: USB
compositor: kwin_wayland driver: X: loaded: modesetting dri: iris gpu: i915
resolution: 1: 1920x1080 2: 1920x1080
API: EGL v: 1.5 drivers: iris,swrast
platforms: gbm,wayland,x11,surfaceless,device
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.1.5-arch1.1
renderer: Mesa Intel UHD Graphics 630 (CFL GT2)
API: Vulkan v: 1.3.279 drivers: intel,llvmpipe surfaces: xcb,xlib,wayland
Device-1: Intel 200 Series PCH HD Audio driver: snd_hda_intel
Device-2: Microdia USB Live camera driver: snd-usb-audio,uvcvideo
type: USB
API: ALSA v: k6.10.3-zen1-1-zen status: kernel-api
Server-1: PipeWire v: 1.2.2 status: active
driver: r8169
IF: enp3s0 state: up speed: 1000 Mbps duplex: full mac: a8:5e:45:e2:87:3c
Device-2: Realtek RTL8153 Gigabit Ethernet Adapter driver: r8152 type: USB
IF: enp0s20f0u3u1 state: down mac: 00:e0:4c:68:51:92
type: USB
Report: btmgmt ID: hci0 state: up address: 00:1A:7D:DA:71:13 bt-v: 4.0
Local Storage: total: 2.26 TiB used: 968.87 GiB (41.9%)
ID-1: /dev/sda vendor: Kingston model: SA400S37480G size: 447.13 GiB
ID-2: /dev/sdb vendor: Toshiba model: HDWD120 size: 1.82 TiB
ID-1: / size: 42.45 GiB used: 11.91 GiB (28.1%) fs: btrfs dev: /dev/sda4
ID-2: /boot/efi size: 98.4 MiB used: 27.4 MiB (27.8%) fs: vfat
dev: /dev/sda1
ID-3: /home size: 42.45 GiB used: 11.91 GiB (28.1%) fs: btrfs
dev: /dev/sda4
ID-4: /var/log size: 42.45 GiB used: 11.91 GiB (28.1%) fs: btrfs
dev: /dev/sda4
ID-5: /var/tmp size: 42.45 GiB used: 11.91 GiB (28.1%) fs: btrfs
dev: /dev/sda4
ID-1: swap-1 type: zram size: 15.49 GiB used: 367.2 MiB (2.3%)
System Temperatures: cpu: 33.0 C mobo: N/A
Memory: total: 16 GiB available: 15.49 GiB used: 11.96 GiB (77.2%)
Processes: 302 Uptime: 5h 33m Shell: fish inxi: 3.3.35
I was able to install the missing dependency gtkglext by git clone.
git clone https://aur.archlinux.org/gtkglext.git
Strange that it didnât work the usual way.
So now I have Anydesk installed, but it does not launch.
error:
anydesk
(anydesk:7312): Gtk-WARNING **: 18:01:30.367: Unable to locate theme engine in module_path: "adwaita",
(anydesk:7312): Gtk-WARNING **: 18:01:30.368: Unable to locate theme engine in module_path: "murrine",
(anydesk:7312): Gtk-WARNING **: 18:01:30.369: Unable to locate theme engine in module_path: "murrine",
(anydesk:7320): Gtk-WARNING **: 18:01:30.414: Unable to locate theme engine in module_path: "adwaita",
(anydesk:7320): Gtk-WARNING **: 18:01:30.415: Unable to locate theme engine in module_path: "murrine",
(anydesk:7320): Gtk-WARNING **: 18:01:30.416: Unable to locate theme engine in module_path: "murrine",
fish: Job 1, 'anydesk' terminated by signal SIGSEGV (Address boundary error)
Ah yes, had the same issue yesterday but ignored it and simply did not install it.
Also because of the âmanual wayâ what you tried is error-prone, and I simply wait for my pacman to do the âmagicâ and fix it some at some time.
Glad to hear it worked for you, but it didnât work for me.
https://aur.archlinux.org/packages/gtkglext
apparently the package was moved to the AUR so you need to install it from there, might need the base-devel package to build it.
I used reflector-simple to choose different countries. This solved the installation issues.
But Anydesk still fails to launch. This is the error:
anydesk
(anydesk:38033): Gtk-WARNING **: 09:46:21.891: Unable to locate theme engine in module_path: "murrine",
(anydesk:38033): Gtk-WARNING **: 09:46:21.892: Unable to locate theme engine in module_path: "murrine",
(anydesk:38041): Gtk-WARNING **: 09:46:21.935: Unable to locate theme engine in module_path: "murrine",
So I installed gtk-engine-murrine (the whole issue is probably related to the sweet Plasma theme and icons that D460nized uses)
and then I got a nice new error:
But there was already a thread about that:
Hi,
i am facing a problem with fresh installation for garuda-dr460nized-linux-zen-230929.iso
i install anydesk-bin but it wonât start with error âanydeskâ terminated by signal SIGSEGV (Address boundary error) from terminal
here is
Kernel: 6.5.5-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=00fa6e16-fc91-4c88-bd10-ee4341ecb07a rw rootflags=subvol=@
quiet resume=UUID=3âŚ
I followed the advice given there, to remove the package appmenu-gtk-module and now Anydesk launches correctly.
system
Closed
9 August 2024 07:36
9
