AnyDesk not working with 'anydesk' terminated by signal SIGSEGV (Address boundary error)
Hi,
i am facing a problem with fresh installation for garuda-dr460nized-linux-zen-230929.iso
i install anydesk-bin but it won’t start with error ‘anydesk’ terminated by signal SIGSEGV (Address boundary error) from terminal
here is
Kernel: 6.5.5-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=00fa6e16-fc91-4c88-bd10-ee4341ecb07a rw rootflags=subvol=@
quiet resume=UUID=31c13878-2a09-4276-8f0c-298dd5deceb5 loglevel=3 ibt=off
Desktop: KDE Plasma v: 5.27.8 tk: Qt v: 5.15.10 wm: kwin_wayland vt: 1
Type: Laptop System: LENOVO product: 20X2S0JW00 v: ThinkPad L14 Gen 2
Mobo: LENOVO model: 20X2S0JW00 serial: <superuser required> UEFI: LENOVO
v: R1JET63W (1.63 ) date: 06/27/2023
ID-1: BAT0 charge: 41.8 Wh (100.0%) condition: 41.8/45.7 Wh (91.3%)
power: 5.9 W volts: 12.4 min: 11.1 model: SMP 5B10W13896 type: Li-poly
serial: <filter> status: charging cycles: 179
Info: model: 11th Gen Intel Core i7-1165G7 bits: 64 type: MT MCP
microcode: 0xAC
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 1026 high: 1561 min/max: 400/4700 scaling:
driver: intel_pstate governor: powersave cores: 1: 1008 2: 1413 3: 674
4: 813 5: 1220 6: 400 7: 1561 8: 1125 bogomips: 44851
Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: Lenovo
driver: i915 v: kernel arch: Gen-12.1 process: Intel 10nm built: 2020-21
ports: active: DP-5,DP-6 off: eDP-1 empty: DP-1, DP-2, DP-3, DP-4, DP-7,
HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:9a49 class-ID: 0300
Device-2: Bison Integrated Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-7:3 chip-ID: 5986:2137
class-ID: 0e02
compositor: kwin_wayland driver: N/A d-rect: 3840x1080 display-ID: 0
Monitor-1: DP-5 pos: right res: 1920x1080 size: N/A modes: N/A
Monitor-2: DP-6 pos: primary,left res: 1920x1080 size: N/A modes: N/A
drv: iris inactive: gbm
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 23.2.1-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Xe Graphics (TGL GT2)
device-ID: 8086:9a49 memory: 14.93 GiB unified: yes display-ID: :1.0
API: Vulkan v: 1.3.264 layers: 3 device: 0 type: integrated-gpu name: Intel
Xe Graphics (TGL GT2) driver: mesa intel v: 23.2.1-arch1.1
device-ID: 8086:9a49 surfaces: xcb,xlib,wayland device: 1 type: cpu
v: 23.2.1-arch1.1 (LLVM 16.0.6) device-ID: 10005:0000
Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: Lenovo
chip-ID: 8086:a0c8 class-ID: 0401
Device-2: Lenovo ThinkPad USB-C Dock Gen2 USB Audio
lanes: 1 mode: 1.1 bus-ID: 3-6.3.3.2:8 chip-ID: 17ef:a396 class-ID: 0300
API: ALSA v: k6.5.5-zen1-1-zen status: kernel-api tools: N/A
Device-1: Intel Ethernet I219-V vendor: Lenovo driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15fc class-ID: 0200
vendor: Lenovo driver: mt7921e v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1
bus-ID: 09:00.0 chip-ID: 14c3:7961 class-ID: 0280
IF: wlan0 state: up mac: <filter>
Device-3: Lenovo USB-C Dock Ethernet driver: r8152 type: USB rev: 3.0
speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 2-3.1:3 chip-ID: 17ef:a387
IF: enp0s13f0u3u1 state: down mac: <filter>
Device-1: Foxconn / Hon Hai MediaTek Bluetooth Adapter driver: btusb v: 0.8
type: USB rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-10:4
chip-ID: 0489:e0cd class-ID: e001 serial: <filter>
Report: btmgmt ID: hci0 rfk-id: 1 state: up address: <filter> bt-v: 5.2
lmp-v: 11 status: discoverable: no pairing: no class-ID: 7c010c
Local Storage: total: 476.94 GiB used: 1.68 TiB (361.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: KIOXIA model: N/A
lanes: 4 tech: SSD serial: <filter> fw-rev: 1108ANLA temp: 36.9 C
ID-1: / raw-size: 459.83 GiB size: 459.83 GiB (100.00%)
used: 6.25 GiB (1.4%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 459.83 GiB size: 459.83 GiB (100.00%)
ID-4: /var/log raw-size: 459.83 GiB size: 459.83 GiB (100.00%)
ID-5: /var/tmp raw-size: 459.83 GiB size: 459.83 GiB (100.00%)
ID-1: swap-1 type: partition size: 16.81 GiB used: 0 KiB (0.0%)
ID-2: swap-2 type: zram size: 15.29 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 51.0 C mobo: N/A
Fan Speeds (rpm): fan-1: 3436 fan-2: 3436
Processes: 279 Uptime: 1h 15m wakeups: 6 Memory: total: 16 GiB note: est.
available: 15.29 GiB used: 6.65 GiB (43.5%) Init: systemd v: 254
pm: pacman pkgs: 1377 libs: 400 tools: octopi,pamac,paru,yay Shell: fish
v: 3.6.1 running-in: konsole inxi: 3.3.30
head: cannot open '/var/log/pacman.log' for reading: No such file or directory
System install date:
Last full system update: 2023-10-02 ↻
Failed units:            nmb.service
anyhelp
That ‘swoosh’ indicates you’re in need of a reboot first. Please do so, then indicate whether it impacted your problem.
can you check if you pull the anydesk client from aur instead of chaotic-aur it makes any difference?
paru -S aur/anydesk-bin
also attach the logs the app generates when launched from terminal.
btw, while going through the repos I came across this
chaotic-aur/remmina-plugin-anydesk-git 20200414-1.2
A protocol plugin for Remmina to launch an Anydesk connection.
extra/remmina 1:1.4.33-1
remote desktop client written in GTK+
:eyes: seems like remmina is worth checking out if anydesk doesn’t work (I personally haven’t tried it, just recommended it given that is has plugin to launch anydesk connection which is fascinating).
or you could also try rustdesk (heard it’s good from a few people).
There is already locked post with the same problem. Solution to this was found on Manjaro forum: you need to remove appmenu-gtk-module package.
